Question about Poulan 12" Electric Twist N Edge Plus Trimmer, No Tools Needed
How do i replace a spool on the weedeater xt110. I cannot seem to get the spool to release and I do not have the owner's manual.
Just line up the two arrows across from each other to those on the the spool housing on the bottom of the spool. Then grip the bump knob and pull straight out. It takes a good grip and some force, but it usually gives way.
Posted on Sep 26, 2009
How can I fix my weedeater when the line does not advance when I bump the head
There is a small gear mechanism under the spool which is usually plastic. If it get damaged the line will either not release or release too much. Unfortunately I cannot find a picture to include.
Jan 11, 2018 | Weedeater Garden
Manual for Rt112 weedeater I ordered parts for my weedeater. RT112 They sent a spring, a funny looking four-pronged clip and the black round spool with blue plastic string wrapped around it. I thought I...
Hi and welcome to FixYa, I am Kelly (almost old at 56)
I looked up your parts and have come to the conclusion that you have items 13, 14 and 15 of this link:
http://www.ereplacementparts.com/images/poulan/RT112_.pdf
Watch the video in this link:
http://www.ehow.com/video_4426520_learn-spool-weed-eater.html
it should help you.
I found the manual here:
http://lawnandgarden.manualsonline.com/manuals/mfg/weed_eater/rt110_rt112.html
SEE PAGE 7 of the above manual. Includes pictures. Try pressing in and rotating the spool to remove it.
1. Disconnect the unit from the power
source.
2. Remove the spool by firmly pulling on the
tap button.
3. Clean entire surface of hub and spool.
4. Replace with a pre-wound spool or cut a
length of 30 feet of 0.065! (1.65 mm) diameter
Weed Eaterr brand line. Use of
heavier lines could overload and damage
unit.
WARNING: Never use wire, rope,
string, etc., which can break off and become a
dangerous missile.
5. Insert one end of the line about 1/2 inch (1
cm) into the small hole inside the spool.
6. Wind the line evenly and tightly onto the
spool. Wind in the direction of the arrow
found on the spool.
7. Push the line into the notch, leaving 3 to 5
inches (7 -- 12 cm) unwound.
8. Insert the line into the exit hole in the hub
as shown in the illustration.
9. Align the notch with the line exit hole.
10. Push the spool into the hub until it snaps
into place.
11. Pull on the line extending outside the hub
to release it from the notch; otherwise, the
unit will not function properly.
Thanks for choosing FixYa,
Kelly
Jun 19, 2011 | Poulan Garden
I have an 1100 TORO Weedeater with the "push tabs" to remove the spool. Thru use/mis-use, the "tabs" are all the way in and the spool will not release. There is still line on the reel...
All I know to help you would be parts replacement as plastic parts are wear items and have to be replaced. Here is a parts w/diagrams breakdown of the 1981 model year Toro 1100 trimmer. I hope this can be of help. You can order parts here to replace your "worn out" string head and spool.
http://www.partstree.com/parts/?lc=toro_consumer&mn=51300%2C+1100+Electric+Trimmer%2C+1981+%28SN+1000001-1999999%29
May 12, 2011 | Toro Electric Trimmer
How to install replacement line for a Ryobi 18v weedeater
The long bolt coming down at the end shaft like place reel over bolt then turn back and forth slowly while pushing upward and it should lock in and take knob or bolt at end and tighten to the right.
Jul 05, 2010 | Ryobi Garden
Removing spool on weedeater SG11 Electic
Pull on the tap head. Straight out. Hard. Here's the Weedeater manual. http://72.3.225.179/manuals/545117522e.pdf The spool should just pull out, its held in by 2 clips, royate it till it pops up then pull it out, with a wiggling motion, Grasp firmly and pull straight out....per tech support from 800 number on machine.
May 14, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Restring a Weedeater Max TE475Y
Google it,,,,you will find it.
Apr 27, 2010 | Garden
Can't get weedeater spool head loose to change the line.
there is three types of heads push, screw, and snap. The screw type have a big ball looking thing on the bottom that when pressed lets the line out. the snap kind are verry distinctive they slid in and two tongs snap in to place you will be able to see them on the out side. the push head just push in and turn.
Jul 23, 2009 | Garden
Replaceing string spool
if its the newer weedeater brand
All you need to do is grab the bump knob end and pull it straight off no turning
wind your line in the direction the arrows on the spool shows you
to put back insert line or lines into the holes and snap back on
be sure the spool is able to move up and down freely after install
May 26, 2009 | Garden
Replace line in poulan electric weedeater model xt110 twist'n plu
Dear FixYa Fan, Friday 2-20-2009 10:44pm EST (USA)
RE: Poulan Lawn Trimmers
Poulan Lawn Trimmer FAQ @
http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html
Dear fitzknight: You will find instructions for putting line on your trimmer at this link http://www.ordertree.com/cms/Poulan+Trimmer%2c+Blower+%26+Edger+FAQ/241.html#changeline click on the http line preceding but please rate me 1st or come back and rate me before you close this or the Poulan Site!
Thank You,
jackiaria
Feb 21, 2009 | Poulan 12" Electric Twist N Edge Plus...
Poulan 12" Electric Twist N Edge Plus Trimmer, No Tools Needed Logo
3,303 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
