Question about Leupold Wind River RB800C Rangefinder
Battery goes flat after less than 10 uses
It says in the manual that you should be able to use the range finder upto 3000 times. My battery seemed to go flat after about 500 uses and as with other uses here my new battery has gone flat after less than 10 uses. If anyone has found a solution it would be much appreciated
Shaun
    Sniper:
  • 73 Answers
You will find that 3000 uses is only under test conditions at a certain temperature level etc. If your battery only lasts ten uses then the unit has a problem and needs to go to the manufacturer. 500 to a thousand is more realistic figure. If its cold where you live or use it expect the lower end of performance out of your batteries.
Posted on Jul 31, 2009
Blurred numbers on Bushnell range finder.What's the problem?
Bushnell V3 display question - Toronto Golf Nuts - Greater Toronto ...
www.torontogolfnuts.com > Golf Discussion Forum > Golf Gear & Equipment
Apr 8, 2014 - 22 posts - ‎3 authors
Bushnell V3 display question Golf Gear & Equipment. ... When I start it, the numbers are clear but it does not stay like that the whole time. ... Yea I used that and turned all the way counterclockwise (all the way clockwise was very blurry). .... to read and drive and has a real problem using my rangefinder.
Bushnell blurry display Rangefinders Questions & Answers (with ...
www.fixya.com > Forum > Tags > blurry display > Rangefinders display the display appears but does not display yardage Here is the link to the instruction manual if you need it; ... Sight target needs adjustment When i look ...
DIY Fix For A Malfunctioning Rangefinder On The Cheap
fardevice.com/diy-fix-for-a-malfunctioning-rangefinder/ 4 Common Malfunctioning Rangefinder Encountered (and How to Fix Them), or blank ... Bushnell Tour V3 Jolt Standard Edition Golf Laser Rangefinder .... This could be rooted to a blurry focus lens or laser output, so it's really important to ...
Bushnell - I am having difficulty seeing through my scope, all images ...
bushnell.com/global/customer.../i-am-having-difficulty-seeing-through-my-scope,-al I am having difficulty seeing through my scope, all images seem blurry. How can I properly focus ... What battery does my rangefinder take? All my pictures are ...
Bushnell Golf - Bushnell Golf
bushnellgolf.com/ The undisputed #1 Laser Rangefinder in golf ... Bushnell Tour Domination. The #1 Rangefinder in Professional Golf For Over A Decade. Learn More. The #1 ...
Bushnell Tour Z6 Laser Rangefinder - Review - MyGolfSpy.com
https://www.mygolfspy.com/bushnell-tour-z6-laser-rangefinder-review/ 6 posts - ‎4 authors
The Final Contender In The Rangefinder Round Up: The Bushnell Tour Z6 ... Our second entrant is the Callaway RAZR Rangefinder dropped a .... I have near perfect eyesight, but when target is clear, number is blurred and vice ...
Blurry vision Range finders - GPS/Range Finders/Mobile Apps - GolfWRX
www.golfwrx.com > ... > Equipment > GPS/Range Finders/Mobile Apps May 14, 2015 - 5 posts - ‎5 authors
What causes a range finder to have blurry vision through lens? Im looking to purchase a used Bushnell tour v2 in a couple minutes and I've ... Which Laser Rangefinder
2 Aug 2014
Pro 1M Slope = Bad, Bushnell = Good
1 Aug 2013
Problems with Bushnell Pinseeker 1500?
24 Jan 2009
More results from www.golfwrx.com
Jan 07, 2017 | Bushnell Optics
Battery replacement for golf buddy range finder
Ask on Internet , All cell types available , even advises you on different make & types, See if you can get old Battery out of Buddy Range Finder,
Mar 14, 2015 | GolfBuddy Golf Buddy - dsc-gb200 - Golf...
I have bought aircooler with 115 watt and 230 V to my home. I am residing in a flat system in Delhi. The question is whenever the power line goes off, our home is provided electricity supply with power...
As long as the power supply delivers 230 V and AC- alternating current, which I guess the cooler runs with, there should be no problem using the cooler. You might need to check how much power(= amount of watts) the power system delivers. 115 w is not extremely high power consuption. It is 10 times less than a hair dryer, tostaer or similar.
Power backup systems often have less power and often are aimed to just supply enough power to keep the most important equipment running. An overloaded power supply will deliver lower voltage. Too low voltage might in many cases harm electical equipment, especially if used over longer times.
If the backup system is only battery based it may be good to use less energy consuming equipment to extend the backup time. Most likely is the backup system based on diesel engines in larger building complexes. They are normally dimensioned to supply regular consumtione used in the building.
Check how much power (=watt) you can use from the power supply, or is allowed to use from the landlord/service technician.
Summary:
Check that 230 voltage and AC is delivered. Then you can use the cooler.
Keep cool
/zeb0zeb0
May 13, 2011 | Kitchen Ranges
My 97 chevy lumina had a lifter ticking I changed oil now sounds like all of them are tapping like crazy. it has oil light so I dont know how much oil pressure it has light goes off when started.
did you use an engine flushing agent ? if not try one, also you should be using a 10/40 semi synthetic oil for the age of car,then after refilling take revs upto 3000 for about 30 secs,(when hot)if that dont cure it then start looking at oil pump(more costly last)
Apr 14, 2010 | 1997 Chevrolet Lumina
Screen Goes Green, with Lines and jumps. 42LG30 1080p TV.
The TV is under a LG factory 1 year warranty.
Unless you bought a refurbished unit which has a 30 day warranty.
Contact LG @ 1 800 243-0000 for warranty repairs.
Be sure to have the...
Date of purchase
Model#
Serial#
And Product code.
The information is on the back of the TV or on a small white tag
on the side of the TV.
Jan 09, 2010 | LG 42LG30 42 in. LCD HDTV
I need a owners manual for bushnell 4-12x42 scope/range finder
Hi :) For some reason your manual and device was under the range finder section (i figure it would be under rifle scopes with a range finder section
Click Here to view your manual
NOTE to view this manual you will need a PDF viewer on your computer if you do not have Adobe,
there is a free ware software PDF viewer called Foxit v3 Build 1560 that you can download Here from their site
If you need any help comment
please rate this as fixya! ;)
Brad
Mar 27, 2009 | Barska Optics Barska 10-40x50 Ao Varmint...
Increase range for remote starter on 2007 grand prix
Try changing the battery in the key fog. If that doesn't work you can try finding an aftermarket key fog with a greater range. It is probably just default range.
Jan 16, 2009 | 2007 Pontiac Grand Prix GXP Sedan
My battery light came on while driving. In the manual it is short and sweet...says could be charging device problem. Battery is less that six months old. What is the range of possible problems
The most likely problem is your alternator, but you can check with a volt meter to ensure that is your problem. Start your truck (use a battery charger or jump to start it if you need to) and put your meter on the battery post's. If your reading 13volts or so your alternator is working and maintaing voltage, however if your reading starts dropping to 10 or less(may take a few moments to drop) then it's probably your alternator. You can also check your battery's voltage before starting your vechile, if the voltage increases after you start the vechile then it seem to be charging.
Here's a start for you, hope this helps
Jun 26, 2008 | 1997 Chevrolet C2500
Inaccurate yardages
Hmm your Bushnell has one year warranty send it back to company under warranty for repair.
Nov 12, 2007 | Bushnell Elite 20-5100 Rangefinder
Leupold Wind River RB800C Rangefinder Logo
309 people viewed this question
Top Leupold Optics Experts
ray gallant
Bill Boyd
Are you a Leupold Optic Expert? Answer questions, earn points and help others
