Question about Car Audio & Video
Long wave car radio get interference from other electric of car
It listen all right as long as i 'm not using my windscreen wiper, ventilateur of the car or light. If i do i can't hear a thing.
Would that come from the arial?
or would it be an electric fault?
  • 53 Answers
That would be cause from a ground issue.
Posted on Jul 14, 2009
Citroen relay 2011 i have no wipers windows or mirrors and the battery drains in about 4 days ??? otherwise faultless , any ideas , many thanks
Windscreen wipers not working after jump starting vehicle.
Affected vehicles
  • All models.
Problem
Cause
  • Windscreen wiper motor and engine wiring harness damage caused by jump starting vehicle using incorrect earth point.
Remedy
Parts Earth point warning label
  • Carry out electrical, mechanical and component tests (as applicable) to eliminate any other possible cause(s).
  • If no fault(s) found: Replace windscreen wiper motor and engine wiring harness.
  • Attach earth point warning label Fig.126139.1.
Nov 30, 2016 | Citroen Cars & Trucks
Tip
How to repair windscreen wipers going slow and/or stopping !
First you must diagnose why windscreen wipers going slow and/or stopping.
In order to find out the cause of wipers stopping you can try follows: 1. Carefully extract the wiper arms from their axles (two pieces). In some cases you need to use an extracting tool. Heed of the windscreen !!! 2. Disassemble the plastic covers from the bottom of the windscreen. 3. With the bonnet up you can start the engine, (transmission in "N" or "P" position and parking brake on). Now you must switch on the control lever of the wipers, and go to the engine compartment. If the wiper motor runs let the wiper motor running for a few minutes and switch off. Go to the step 4. If the wiper motor do not runs you must check first the electrical feeding of the motor. It is necessary to unscrew three bolts of the mechanism and disconnect the electrical coupling (difficult assurance). If the electrical feeding is OK you must replace the motor - steps 5, 6, 7. If not you must check electrical connections, the control switch of wipers and electric cables. 4. Now you must check the two bearings of wiper mechanism with your hand. In the most cases the left bearing is out of order (is very hot). This is the most encounter fault of the wipers running at Audi. 5. For have enough space to manipulation the wiper motor together with their mechanism you must extract the plastic cover of the engine computer box, and extract also the box screws. Then you can move slowly the engine computer box, just for a few milimeters. 6. You must disconnect the electrical coupling of the motor (difficult assurance), unscrew three bolts of the mechanism and extract together with the motor. You must move them slowly between windscreen and engine computer box until the wiper motor go out together with the mechanism. This is the most difficult operation! 7. Now you can repair the bearings, replace entire wiper mechanism or replace the wiper motor. It is not very simply, but it works.
Refit all in reverse order.
on Dec 04, 2009 | Audi A4 Cars & Trucks
Audi a4 windscreen wipers operating slowly
How to change a wiper assembly & repair wiper mechanism on 2002 Audi A4
First time you must diagnose why windscreen wipers going slow and/or stopping.
3. With the bonnet up you can start the engine, (transmission in "N" or "P" position and parking brake on). Now you must switch on the control lever of the wipers, and go to the engine compartment. If the wiper motor runs let the wiper motor running for a few minutes and switch off. Go to the step 4. If the wiper motor do not runs you must check first the electrical feeding of the motor. It is necessary to unscrew three bolts of the mechanism and disconnect the electrical coupling (difficult assurance). If the electrical feeding is OK you must replace the motor - steps 5, 6, 7. If not, you must check electrical connections, the control switch of wipers and electric cables.
Jun 13, 2011 | 2002 Audi A4
Windscreen wipers not working on my vw passat 2005 '05' but washers are working!
If the windscreen wipers fuse is good:
4. Now you must check the two bearings of wiper mechanism with your hand. In the most cases the left bearing is out of order (is very hot). This is the most encounter fault of the wipers.
Apr 14, 2011 | 2005 Volkswagen Passat
Need to chage wiper arm on audi quattro how do i get the old one off?
Carefully extract the wiper arm out from the axle. In some cases you need to use an extracting tool. Heed of the windscreen !!!
How to change a wiper motor & repair wiper mechanism on Audi A4
Jan 22, 2011 | Audi A4 Cars & Trucks
2004 audi a4 wipers are scratching windscreen when on; i have replaced them twice but it makes no difference; help!
First time you must diagnose why windscreen wipers going slow and scratching windscreen.
Dec 11, 2010 | 2004 Audi A4
My front wipers on A4 audi have been slow eversince windscreen was replace a couple of months ago. Obviously this time of year they have been little used but this morning have little power and stop dead on...
Sep 22, 2010 | Audi A4 Cars & Trucks
My 2004 audi a4 windscreen wipers move across the windscreen very slowly then stop.they will then start up again and move slowly.sometimes they dont start first time and when they do their is only 1 speed-...
Sep 06, 2010 | 2002 Audi A4
Windscreen wipers only go half way
wipers stop halfway up windscreen
May 24, 2010 | 1999 Volkswagen Passat
BMW E39 Radio Interference on Medium wave
This is a signal strength issue.
Jun 28, 2017 | Car Audio & Video
Car Audio & Video Logo
125 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
