Question about Sony Cyber-shot DSC-W55 Digital Camera
Pentax ist D L2 colour problem
My camera has started producing mottled discoloration especially in darker colors the colors that show are brown red tones & pic loses clarity.
any ideas, this did not happen when I first got the camera
  • 2,985 Answers
Re: pentax ist D L2 colour problem
If this is a recent purchase it should be returned to the vendor for replacement or contact the the makers support site for advice.
If it is an older camera then simply purchasing a new on will almost certainly be more economic than going for a repair- with the bonus of having the latest specifications.
Posted on Nov 17, 2007
0 characters
3 Points
Pentax ist d keeps saying delete after each picture i take before picture is shown
You can try to reset camera settings to default from the menu.
And fimware update could help if the software causes the problem.
SD card write protection lock also should be off.
Jul 27, 2013 | Pentax *ist D Digital Camera
Every time i take a picture it is much darker than what i see through the view finder. Help!
You could set your "exposure compensation" to a higher setting for brighter pictures.
Oct 27, 2010 | Pentax *ist DS Digital Camera
The indicator shows low battery after 2-3 shots. (batteries 3800 MAh are fully charged)
This seems to be a problem with the ist line. My istD does the same thing. Turning it on and off a few times helps with mine. Pentax has no solution.
Sep 24, 2010 | Pentax *ist DL Digital Camera
Blotches on images especially images with a light background eg.
This is probably due to dust or other foreign matter on the CCD. Look at the Pentax *ist DL manual under "CCD cleaning" or "sensor cleaning" for instructions.
There is a "sensor cleaning" mode in the Set-up menu that will lock the mirror up so you can inspect/clean the CCD sensor.
Jul 10, 2010 | Pentax *ist DL Digital Camera
Pink pictures
Have you tried changing the White Balance. You can access this by switching on the camera, pressing the Fn button and then the left arrow.
Jan 11, 2009 | Pentax *ist D Digital Camera
First make sure the camera is not set to No Flash on the shooting mode dial.Also, in P, Tv, Av or M modes the flash reverts to manual and must be raised manually by pressing the button next to the viewfinder.
Jan 11, 2008 | Pentax *ist DS Digital Camera
Distorted color on image
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says. "You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
Mar 20, 2007 | Pentax Optio 555 Digital Camera
Petax ist DL Focus
It could be that your lighting situation inside is darker than in the store. Since the Pentax *st DL does not have an anti-shake sensor like other new cameras, it could be telling you that the low level light will not support the aperture setting you have to acuratley stay focused.
Try using a tripod and a lower aperture setting.
Sep 08, 2005 | Pentax *ist DL Digital Camera
Color shift problem with 330GS
This is because the RGB filters in the camera are not perfect, and there is no one "green" colour. The green pixels pick up a wide band of colours, and are somewhat sensitive even to red and blue, especially near where green shades into red.
Sep 08, 2005 | Pentax Optio 330GS Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
