Question about Samson C01U - USB Studio Condenser Microphone Consumer Microphone
Why is it suddenly way too quiet?
So I've been using the same setup for months: My Samson c01u mic plugged into one of the USB ports of my Dell laptop, running Windows 10, and recording in Audacity. The recording volume is set at 52. Usually, this records just fine, with very little background noise and a very clear recording. However, when I plugged in my mic today and started recording, it was so quiet that it was nothing more than a single line in Audacity, and I could hardly hear my voice at all, let alone what I was saying. Have tried several ways to fix it, none have worked. I tried a few different things to fix it, including changing the volume (anything under 80 is far too quiet, and anything 80 and up picks up far too much background noise and is way too loud), and making sure the default format matched Audacity's (it did). My mic still isn't working properly, and I have no idea how to fix it.
  • PBandJ
    PBandJ Jul 04, 2016
    Are you sure you're adjusting the gain under the Recording Properties and not the Microphone slider under Playback Properties?
    New Friend:
    Problem Solver:
  • 8 Answers
Try a different mic to see if problem follows. If yes then it is a setting. If not then the mic is bad and needs to be sent to mfg or get a new one.
Posted on Oct 15, 2016
2 Suggested Answers
SOURCE:
  • 5603 Answers
SOURCE: whistling background noise with Samson C01U USB condenser mic
Welcome to the world of STUDIO microphones. Super quality BUT you must have a studio to use them. You can't have any local speaker playing into them. You often use headphones lest your monitor speakers will feedback. At the high frequency capability of these mics, you can fry your amps with oscillations above what you can hear!
Posted on Sep 30, 2009
Why does my computer tell me my cou1 mic has malfunctioned everytime I plug it into the usb port?
Sounds like a defective mic. Test it on another computer, with another USB cable, and if it still doesn't work, call customer service and they'll send a replacement.
May 21, 2014 | Samson C01U Consumer Microphone
I have a samson c01u and using audacity. i set the input level in the control panel to 100 and also in audacity, but the the volume is still too low. i can barely hear my voice. what do i do?
1. Did you select Left channel only in Audacity for the track you're recording?
2. Maybe it's a defective mic. Try it on another computer/software/USB cable/USB port and if it still doesn't work get Samson to replace it.
Apr 05, 2014 | Samson C01U Consumer Microphone
My Samson C01U microphone doesnt seem to be working. the green light doesnt turn on when i plug it into the usb port of my computer. I have windows vista. Is it not compatible?? The computer says the...
Sorry this isn't a solution but just letting you know I'm having the same trouble, the funny thing is mine was working a couple of months back and now its not, it's driving me crazy.
May 19, 2011 | Samson C01U Consumer Microphone
I use the samson C01U usb microphone on my macbook pro for almost 4 years. Now I recently updated to mac os 10.6.6 (latest update) and Samson soft pre won't start up anymore. I can't configure the mic...
1. Try reinstalling the softpre software.
2. Read through their FAQ at: http://samsontech.com/products/productFAQs.cfm?prodID=1810&brandID=2
3. Contact samson directly at [email protected] with your problem.
Mar 03, 2011 | Samson C01U - USB Studio Condenser...
Whistling background noise with Samson C01U USB condenser mic
Sep 28, 2009 | Samson C01U - USB Studio Condenser...
Samson C01U USB mic not working on my PC.
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Feb 25, 2009 | Samson Audio C01upak C01u Microphone and...
Switched from a g4 PowerPC to a g5 Intel Imac and now Mic has a lot of digital hiss
the Samson C01U picks up the noises running inside the computer, or laptop whichever you have. You can't change that. But if you want to get rid of it. I use Cool Edit Pro. There's this effect we have for Noise Reduction. I won't go further on unless you have this program, or something similar. But basically it takes out any unwanted static
Aug 30, 2008 | Samson C01U - USB Studio Condenser...
Problem with Samson CO1U
Here are some instructions relayed from someone who was able to fix a similar problme with help from Samson tech support:
The C01U is a WAV device. Therefore, adjusting the slider for your default MIC input level on the volume control applet does not adjust the gain on the C01U. You access the actual volume control for the C01U as follows:
Start, Settings, Control Panel, Sounds and Audio Devices
Click on Audio tab.
Under "Sound Recording", insure that Default Device is selected as Samson C01U.
Once Samson C01U is selected as Default Recording Device, click on the Volume button just below the name. A new window will pop up, with a vertical slider. This window will be labelled "WAVE IN", however it actually does control the MIC volume for the C01U.
The key here seems to be that the USB device that represents the Microphone input (as far as Windows is concerned) is not a traditional microphone, but (as mentioned above) a WAV-IN device.
Jan 03, 2008 | Samson C01U Consumer Microphone
Playback only on left speaker
The quick, easy solution is to change your microphone to mono recording. In the attached YouTube clip, I'll show you how to do that.
The short and simple is to go to your Mac HD -> Applications -> Utilities -> Audio MIDI Setup. Select your C01U USB device, and set it to 1ch 16bit. This will set the microphone to record in mono, equally over both speakers.
Nov 26, 2007 | Samson C01U Consumer Microphone
Samson C01U - USB Studio Condenser Microphone Consumer Microphone Logo
559 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
