Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
REGULAR DETERGENT ON HE PLUS
MY HUSBAND PUT REGULAR DETERGENT ON MY HE PLUS
  • 4 Answers
Regular detergent causes the washer to make too much suds. Use HE detergent unless you want to fry your washer. You can use regular detergent as long as you use a small amount.
Posted on Jul 31, 2009
5d fault what does it mean?
The 5d (or Sd) error code indicate that the control detected a suds lock or overdose of detergent during the drain or spin phases of the cycle. This is usually caused by overuse of detergent. It can also be caused by using regular detergent instead of HE (High Efficiency) detergent. After the excessive suds dissipate, you can normally clear the fault code and then run a drain/spin to finish the load of laundry.
If you detect no excessive suds, this fault code could be caused by a clogged drain system or a failed water level pressure switch.
Feb 15, 2015 | Kenmore HE2 Plus Front Load Washer
What is HE detergents
Special low sud detergent designed for high efeciency HE machines.
Feb 08, 2013 | Maytag NFW7200TW Front Load Washer
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Can you use regulure detergent instead of the HD kind? The type of maytags I purchased are MEDE500VW and MHWE450WW washer
High Efficiency detergent is strongly recommended for front-load washers. This detergent is a "low sudsing" detergent as opposed to the regular detergent. If you use regular detergent is a front-load unit, you may have issues down the road!
Apr 13, 2010 | Maytag MEDE500W Dryer
DETERGENT IN THE AREA FOR RINSE AGENT
Fill dispenser with boiling hot water and run through rinse cylce only. The say to your husband "Really?"
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 25, 2009 | LG LDS4821ST Stainless Steel 24 in....
My washer has E:13 on the display. I called Bosch
According to the service manual, you should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. I would run the short wash or refresh cycle without detergent and hopefully your lines will clear. I have also read that if this persists, powder HE detergent is better to use instead of the liquid because of certain chemicals contained in the liquids that cause it to congeal in some front loader drainage pipes. I hope this helps.
Jul 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
How much detergent that is not HE can I use?
It is strongly recommended that you DO NOT use regular detergent in an HE washer. The regular detergent is formulated for a wash tub capacity of 35 gallons. A High Efficiency washer, such as yours, only uses 5 to 7 gallons of water per load. You can potentially cause premature failure of the gaskets and seals, as well as drain pump problems by using a higher concentration of detergent. In addition, you may end up with residual soap left retained in your clothing which can cause skin irritation. So...if you do the math, you would have to use about 1/5th the amount of soap you would normally use. However, if this is a new washer, you will void the manufacturers warranty if it discovered that you purposely used improper detergent. There is a disclaimer in the Owner/Operators Manual that should explain this. I hope you find this information helpful.
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
What to use in my washer?
If your washer is rated for HE detergent, then you're supposed to use HE detergent. The reason being is that HE detergent is concentrated and specifically made for washing machines that use LESS water than conventional washers. Regular detergents are formulated for machines that use about 35 gallons of water for a full wash tub. If you use that same soap in a washer that only uses 5 to 7 gallons of water, you are in affect putting a higher concentration of soap in your new washer. Originally, manufacturers of HE machines stated that you could use regular detergents as long as you cut back on the amount. They later retracted that statement, because regular detergents were damaging the HE washers. You should review your warranty closely. Most newer models now have a disclaimer that states if you use the wrong detergent in your new washer, the warranty becomes null and void. I hope this answers any questions you may have.
Feb 28, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
148 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
