Question about Sony Playstation 3 (PS3) Console
Ps3 hdmi-av i ve always played with the hdmi cable on hdmi tv what gives no problem,now i am on my work and took my ps 3 with and try to connect it with the av cable but i get no picture ore sound,probably the settings are stil in hdmi mode how can i reset them back to av without seeing anything on the sreen
  • 5 more comments
  • chillahb Nov 21, 2007
    what has a local tv shop to do with it?
  • chillahb Nov 22, 2007
    I owe you one danny
  • franzj Jan 03, 2008
    I have this same problem, but when I re-boot as indicated, it does not solve the problem. I was using AV, brought it to a TV that has HDMI, used HDMI, and now want to go back to AV, and its not working all of a sudden.
    Any ideas?
  • age007 Jan 03, 2008
    no screen or if i do get ps3 working,screen goes green and freezes. tried everything..
  • danfish Oct 26, 2008
    i would like to know the key strokes to change from hdmi to av. i brought my ps3 to work and i cant see anything on the screen. if someone could tell me, maybe i could do it blind.
  • Anonymous Jan 05, 2009
    Thanks so much!!!!! This helped out immensely!! My son is very grateful
  • Anonymous Jan 28, 2009
    i the ps3 hooked up to an hdtv and wanted to hook it up to av but no picture.
I currently have the exact same problem...i always play HDMI but i went home from college for thanksgiving and wanted to play on a regular AV jack TV, hooked up, and have no picture whatsoever...and i think it's because of the settings on the PS3 since it's set to send out an HD signal...Well i found this straight from Playstation3.com, on the support/troubleshooting section
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution."
Hope it helps =)
Posted on Nov 22, 2007
  • 51 Answers
You can't you have to got to a hdmi tv ....try a local tv shop they may help u
Posted on Nov 20, 2007
Awesome! Thank you so much, the holding down the on button worked and saved me much pain.
Posted on Oct 30, 2008
You frign rule thanx for the info.
Posted on Aug 30, 2008
When you plug in the console hold down the on button for a while until you hear it beep. this will reset the av settings and work on any tv.
Posted on Jun 02, 2008
Works for me.. tks danny
Posted on Mar 22, 2008
My PS 3 comes on but no display on the TV. I've
Stupid question i know ,buut, have you pressed AV on your TV remote !!
Jul 16, 2012 | Sony Playstation 3 (PS3) Console
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have an 52 inch lg5000 tv . it supposed to be full hd. i ve tried to connect my play station 3 via hdmi cable but the only thing i get is the no signal sigh on the screen i ve tried everything . is my tv...
plug the ps in with power cable only no hdmi. When turning on Hold down the power button until you hear a second set of beeps you have now reset the video settings. Turn the console off and plug in your hdmi and switch back on it should now work.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
PS3 HDMI - Sony Bravi KDL-40V2000 Problem
  • Have your ps32_bing.gif in standby mode (red light).
  • Now, press andhold the power button in the front down. Your ps3 will beep twice. Letit go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
May 08, 2010 | Sony Playstation 3 (PS3) Console
PS3: No image or sound.
the power unit probably got damaged also try another tv and look for your proof of purchase you mite still get it replased for free either from the store you bought from or SONY.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 doesn't connect to tv
Try holding down the power button for 3-4 seconds when you turn it on.
This should allow you to reset the AV inputs on the ps3
Aug 23, 2009 | Sony Playstation 3 (PS3) Console
Need Help
try connecting A/V rca cable first. go to ur diplay settings and then to video output settings in it select av multi. don't use HDMI settings let it automatically ask u when u plug in hdmi cable. Then switch to HDMI cable. I had a problem like this before with a ps3 that i had bought used. hdmi was set up and it took forever to set it up with rca cords. took many times power on and offs and unplugging video cords for it to reset. . not sure. Now when u plug in your hdmi on any tv it should automatically set up. and you have settings for a/v as backup. the other thing is it could be the just the port or cable.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
Av connections not giving signal to tv
you have to manually change the output in the settings menu back to ANALOG Using an HDMI TV or monitor 1st, when you select RCA, or AV output and restart, it will work, but when you switch back, you have to change it (back to HDMI output) on the analog monitor, or use analog TV inputs, then reboot PS3 and connect HDMI.
I do not know why Sony did not make this switch automatic and self scanning on boot, but alas I have had the same issue, so I know this is your problem, not the AV cables.
Please give a fixya rating if you find this solves your problem, Thanks for the question
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
PS 3 Hookup to Sony Grand Wega
this is a very simple fix leave cords in your sony with ps3 on standby hold the power button on ps3 itself down for 10sec your ps3 will switch back to av cables
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Ps and TV not connecting using av cable
when you turn on the ps3 hold the power button till the system beeps
Nov 15, 2008 | Sony PlayStation® 3 (60 GB) Console
Sony Playstation 3 (PS3) Console Logo
4,716 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
