Konica 3135 with error code 45-1? - Office Equipment & Supplies
  • 145 Answers
F45-1 shortly after power up.
Solution:
PROBABLE CAUSES:
1. The ADU driver board has failed, causing a loss of 24V DC to the lens drive motor (M7).
Disconnect CN151 from the main CB, if the copier powers up the ADU driver board is at fault. Verify that the side guide drive motor (M502), and the rear guide drive motor (M503) are not faulty. If necessary replace any faulty components, then the ADU driver board (p/n 12JA-9010).
2. The AC driver board is not providing 24V DC for the lens drive motor (M7) or the mirror drive motor (M8).
Replace the AC driver board (p/n 25JE-9016).
3. The pulley on the adjustable motor assembly cracks, causing no drive to the second V-frame.
Order the new-style adjustable motor assembly, (p/n 25BA-7404).
Note: Order the adjust drive (B) panel assembly (p/n 5400-6331) at the same time. The new motor will not mount to the old-style plate. Both parts must be replaced at the same time. Machines with serial number 25ME02578, and above have the new style parts.
4. There is a loose wire on the main CB.
Reseat CN30-B12 (mirror home) on the main CB. This signal is used to inform the DCDB when the mirror drive motor (M8) is in the home position.
this infotmation is very technical..hope you are a technician..check you optic wire and make sure the optic moves smoothly no binding .look for signs of wear on the optic cable..good luck
Posted on Jul 16, 2009
How do I fix error code p51 on Konica 3135 copier
P51 means "key switch OPEN", look to the right side check the continuity of the Sw.
Dec 04, 2014 | Konica Minolta Konica 2125 3135 4145...
Konica 3135 autofeeder F60 error
this error code means the interlock switch ms301 has failed or it could be the radf control board or the harness for ms301 it is almost impossible to find parts for these machines now. they are on the konica obsolete list sorry and good luck
Dec 03, 2009 | Office Equipment & Supplies
How do you fix a F 86 error code on a konica 3135 copier?
This error code not exist .Please tell me precise your problems and your error code.
Dec 02, 2009 | Konica Minolta Office Equipment & Supplies
Error message 45-1 is being display on Konica Copier model 3135
most often what i have seen the cause of this problem is the lens motor pulley gets a crack in it which causes the pulley not to turn when the motor turns i have had some luck with pulling the pulley off the shaft and putting a drop of super glue on it then put it back on the shaft and it will hold for a while but the bad news is they dont make parts for this machine anymore so the time is near for this machine to be replaced sorry
Nov 27, 2009 | Konica Minolta Office Equipment & Supplies
Konica 3135 error code f 43 ( exposure lamp)
The exposure lamp is located in the scanning area beneath the glass. If you choose to do it yourself you can purchase a lamp here
https://www.interlight.biz/light-bulb/252254045&ID=FROOGLE-US
You can get the manual here
http://www.service-manual.net
Be sure to follow the steps closely it is easy to do more damage than good in that area if you try to wing it. Good Luck
Apr 20, 2009 | Toshiba E-Studio 161 Copier
Konica 3135 Copier Code F 36
Well, I'm sorry to say that you're going to need a tech for this problem. You have a fuser problem...either a blown fuse, heater lamp, thermistor, or something...whatever the cause, the fuser is not heating up. And the code can only be reset within service mode, once the problem is repaired.
Feb 25, 2009 | Konica Minolta Office Equipment & Supplies
Konica 3135 error code 41
41-3 Error Code is an Optical return problem. The Scanner is not returning back to home position like it should.
A common problem with this model machine is a small black gear on the drive motor cracks or ovals out. If you can locate this gear, you can try placing a drop of super glue on it and see if it will hold. This works if the gear is ovaled out. If it is cracked or split then you will need to replace this gear.
Hope this helps a little.
Feel free to post another question if you need more help.
Good luck,
Mac =)
Jun 26, 2008 | Office Equipment & Supplies
Copier: Konica 3135 p.81 Insert key counter
you have to be in the service mode.To be exact the 25 Mode.To enter turn power off,Hold down the "2"&"5"keys while turning power on.Then press the "p"key.Change the number you see to 57. So now you should see P57in the display.Then change the value from 1 to 0,then press Print.That holds it in memory.Then just turn off and back on.
Oct 16, 2007 | Office Equipment & Supplies
173 people viewed this question
jasbo
jasbo
