Question about Maytag Refrigerators
Refrigerator not getting cold
Freezer is freezing but refrigerator is not cooling
  • 396 Answers
Refrigerators and Freezer combination units have one common compressor and coolant for both units. If the refrigerator section is not getting cold I would check the following.
The cold zone is not blocked by a bag or box? The cold zone would be the coldest part of the refrigerator which vents the cold air from the freezer to the refrigerator.
Is the fan working on the refrigerator to vent the cold air to the refrigerator? You should be able to hear it when you hold the door switch.
The thermostat is not working which I have found most common is the thermister is not registering the correct temperature causing the fan not to turn on.
Posted on Jul 14, 2009
tbirdfan1
  • 3051 Answers
SOURCE: refrigerator not cooling - freezer is very cold
Hello there:
There are several different things that could make your refrigerator not cool properly.
I have compiled a list of things that you should check out and how to check them ok
It's not cool If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running. First, answer these questions: Is the refrigerator completely dead? If so, Is the thermostat knob turned to the proper setting? If not, reset it. Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these: The compressor The Thermostat The overload, relay, or capacitor The defrost timer The condenser fan motor Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas: Evaporator coils Condenser Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
I will continue the rest of the post in a seperate post to allow for full detailed instructins
Posted on Apr 15, 2010
Sea Breeze
  • 4655 Answers
SOURCE: refrigerator does not cool and the freezer does not freese.
Want you to check the back panel in the freezer is ice on the panel. I need to decide if you have a defrost problem or something else. Could you look for the model number so I can help you better, Thanks, Sea Breeze
Posted on Jul 27, 2009
SOURCE: not cooling or freezing
bimetal switch not working. change it.
Posted on Aug 02, 2009
SOURCE: refrigerator is not cooling
Our model is GLTT20V8A.
Freezer which is upper portion is working but lower refrigerator not cooling.A little water is also dripping from where the air comes in the refrigerator portion
After being turned off for 8 weeks,when it was switched on,it did work for a couple of days only.
Posted on Aug 11, 2010
heatman101
  • 43501 Answers
SOURCE: Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhkgjd
Posted on Sep 29, 2010
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Freezer section not freezing. It is just cold. Refrigerator part working fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Mar 18, 2011 | GE Refrigerators
The freezer coil freezes up then the rifregerator section does not get cold
heatman101
Nov 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My frost free freezer stops freezing although it stays cold and then I have to switch it off for more than a day before it starts freezing again
heatman101
Nov 25, 2010 | Whirlpool Refrigerators
KENNMORE REFRIGERATOR WONT GET COLD BUT FREEZER FREEZES
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Nov 21, 2010 | Refrigerators
Refrigerator does not keep cold. Motor runs and freezer does freeze.
heatman101
Oct 19, 2010 | GE GTS22KBP Top Freezer Refrigerator
Not getting cold fridge or freezer side but at the bottom of the freezer its freezing
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 06, 2010 | Amana Refrigerators
Bottom is freezing properly but, the top refrigerator is not getting cold
heatman101
Oct 03, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer freezes, fridge not cold, smells very exhaust like
heatman101
Jul 20, 2010 | Danby (DAR604BLS) Refrigerator
Refrigerators Logo
1,347 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
