Question about GE Refrigerators
Defrost cycle not defrosting
I have a 5 year old GE Side-by-side fridge (model TFX20JABK). The defrost cycle seems to be turning on couple of times a day, but not defrosting. As a result i have to completely defrost entire fridge once a month. Pls. help
    Brigadier General:
  • 8,619 Answers
Hi
Please check the defrost timer at the back of your refrigerator and also check the defrost thermostat. Defrost thermostat wiring(part #240) could be loose. You'll need to remove the back panel, held in place by 5 screws. Locate the defrost thermostat and disconnect it from the wire connection to another part. Due to the connection requirement, you may need to cut the wires from the original part and splice it with the connector with wires to the new part. After securing the spliced wires and covering in electrical tape, replace the panel and all the screws.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Posted on Jul 14, 2009
The GE side by side is roughly 10 years old and when the turbo cool bin is on it makes a rattle noise every 5 mins. like a toy gun sound. I turn it off and it stops. It only happens when the bottom bin...
It's freezer fan hitting with your bin drawer when it's over ice formed behind the freezer. It's due to malfunction of defrosting. Keep 5 degree thermostat setting. And check thermostat by turning counter clock wise. If shuts off the fridge, it's working. If not replace thermostat. Check defrost timer set in proper setting. Once defrost cycle is good, no banging sound will be there. Thanks.
Feb 01, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
Feb 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer & fridge warms up on average every 6-8 weeks. Remedy turn off and leave 24 plus hours with doors open. On turning on the fridge and freezer cool down again to operating temperature....
Good day,
That's too long a period, for a normal. defrost system failure.
You'll have to wait until it quits, then remove the rear panel and look for ice (not frost) building up somewhere in the freezer compartment.
I have solved similar problems on this model, by replacing the defrost thermostat with a GE 60 degree thermostat, and a WR9X330 GE 6 hour defrost timer to get this model to defrost completely.
It's also possible that the refrigerant charge is slightly low, causing the defrost thermostat not to reach a cold enough temperature to perform a good defrost cycle. (building ice over a long period of time).
Make sure Freon 12 was used when replacing the compressor.
Some substitutes caused the evaporator coil to act as if it was
slightly low on charge.
Nov 08, 2009 | Westinghouse Refrigerators
I have a GE side by side refrigerator that keeps blowing the defrost heater element. MODEL # TFT22JWDA WW SERIAL # TZ264141 I bought it from a GE dealer about 5-6 years ago. It ran fine for 3 years,...
In my GE side-by-side there is a defrost temp sensor located near the top of the evaporator coil. I think the control board uses that temp sensor to know when it should be done defrosting.
On the schematic of my fridge (link below), the defrost thermistor is part number 240 in the diagram (not part number 241, which is a different temp sensor located adjacent to the one you want)
http://www.partselect.com/ModelFrames.aspx?ModelID=361233&ModelNum=GSS20IEMDWW&mfgModelNum=&ManufactureID=2&Selected=00113321i06&Position=2&mfg=GE&Type=&Mark=2
I don't know why the defrost element would fail immediately other than incorrect supply voltage or just a bad defrost element.
Jul 28, 2009 | Refrigerators
Everything in freezer defrosted
the defrost has a timmer you mite have to chang it ok
May 14, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Freezer side blowing all the time and fridge side is warm with no cooling on amana side by side unpluged and defosted with hair dryer and it worked for a couple days then went back warm in fridge side...
You have a defrost issue.
Adaptive defrost control.
Defrost thermostat.
Defrost heater.
These are the only 3 parts involved.
If there was a model number I could be more help.
Feb 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
GE Side By side doesn't cool and freexer frosts up
Most common problem on GE's is the defrost heater(s) has gone bad. They are a glass tube and when they go bad the tube will have a burnt or black color to it. A good heater will be clear. I bet that is your problem. Seems to be the problem about 90% of the time on GE not defrosting.
Jun 29, 2008 | GE GSS20IEP Side by Side Refrigerator
GE side by side fridge not cooling, can't adjust temp control
Most likely it's not defrosting, many GE fridges need new defrost heaters every couple of years.
Jun 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frequent frosting over
replace the defrost heater thermostat
PLEASE RATE THIS !
Jun 09, 2008 | Refrigerators
Refrigerators Logo
173 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
