Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
How do I take out the pilot generator I cannot get at the to screws. the spark insolator is in the way?
    Scholar:
  • 91 Answers
With most heaters I disconnect the pilot tubing out of the valve, and the wires after noting where they go. Then I lift the burner, or burner assemblies that the pilot assembly is attached to. Lift it in such a way that the back of the burner goes up first, then you can lift the part closest to you just enough toget it over the orifice, then move it toward the bottom and slide it out. It may take a little patience so take it slow and easy. Good Luck
Posted on Jul 14, 2009
Bosch 1600 h not lighting pilot light
If your getting a spark the generator should be ok I would clean the pilot injector and re try
Nov 16, 2014 | Bosch 1600H-LP Liquid Propane AquaStar...
How remove a pilot generator from a minimax ch 200m
shut off gas supply. undo gas line union. remove wiring from gas valve. undo burner tray support screws. slide burner tray out. remove pilot generator leads from gas valve. pull out pilot generator from pilot assembly. then re assemble
Aug 17, 2014 | Pool & Spa
What is a pilot generator
Simply put, a pilot generator is a thermopile that generates millivolt power to operate a gas valve.
However, on your convection oven, yours operates on an electronic spark, which is generated by an electronic ignition control module.
Jul 29, 2014 | Vulcan SG4D Gas Single Oven
2003 yz450f too lean backfiring on deacceleration
clockwise is rich & cc is lean which way are you adjusting?
clean the small air port in carb with adjustment screw removed.
Screw should be set 1 1/2 turns fron light seated position.
Nov 21, 2013 | Yamaha 2003 Yz450f Yz450 Yz Wr 450 Stator...
2003 yz450f popping on deacceleration too lean
wots the colour of the plug after its had a good run? is the exhaust gasket on the head leaking as this can cause this ? have you coated the air filter with a film of oil as this is required and also stops dirt passing through it ? correct spark plug and gap ? timing set correctly ?
How to check a thermopile generator
Log in to the Honeywell internet site and ask the question using yur model generator! It is probably supposed to produce a spark that may be regulated.
Dec 24, 2012 | Honeywell Q313a 750 Millivolt Thermopile /...
Heater will not stay lit!!!
Lets start with safety. Check your vent pipe for obstructions, mainly outside at the vent cap. The safety of this unit will not allow it to operate if there is anything blocking the vent. If all is OK, then next we will light and observe the pilot with it on the pilot setting on gas valve. The pilot flame should consume the tip of the generator point by 1/2 to 5/8". If it does not, then screw off the pilot adjust screw cover on the gas valve. This is clearly marked on the top of the valve. Inside you will have a much smaller screw. Turn it counter clockwise to raise the pilot level, clockwise to decrease. Never consume more than 5/8" of the generator tip. Hopefully your problem will be resolved here at this step. If however it is OK, then take a millivolt meter and read the generator millivolts, at the gas valve with the thermostat contacts closed. It should read 140 millivolts. You need this much power to properly operate the heater. If it is lower than 140, then replace the pilot generator....Rob Just a note...Do not remove or take apart any part of the Gas valve, other than the pilot adjust screw cover...Good Luck.
Dec 29, 2009 | Williams 3003622 Ceramic Wall Mounted...
Main burner will not light. pilot has now gone out
shut off the gas at the gas **** and gas valve. the pilot tube is held in place by a 7/16 compression nut. remove it then remove the 2 screws for the thermopile "generator". follow the pilot tube and the pilot assembly should be held in by one or two screws. usually you don't have to remove the main burners. hopefully this helps
Jun 14, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pool heater pilot lights, goes out when heat called for
No, that would just cause you to have huge flame. There is another high pressure switch located next to the flame sensor/ pilot genator that can cause this problem it is the size of a quarter and is screwed down with 2 phillip head screws
May 27, 2009 | Heating & Cooling
Crosley gas dryer
the pilot should be located in close proximety to the main burner. the ignition may be one of two devices - an electronic spark type ignition or what is called a hot rail glo-bar. the flame detector has a millivolt generator which generates a 750 millivolt current after it detects the pilot flame and gives a signal to the main valve to open.
Aug 20, 2007 | Crosley CDG6000 Gas Dryer
Heating & Cooling Logo
142 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
