Question about Kenmore Dryers
Dryer no longer comes on - Kenmore Dryers
    Genius:
  • 1,122 Answers
Main fuse behind back panel or door switch?mike
Posted on Jul 19, 2009
Make dryer hotter
Rather than make it hotter, check other things.
The longer the vent line is, the longer it will take to dry.
Also, most vent lines have a flapper outside that closes off when not in use to prevent cold air and critters from coming in.
Check to make sure that it's operating (opening) properly.
Also, no sharp bends in the vent line coming from the dryer to the vent ducting in the wall.
Finally, if it's an electric dryer, you could try one of these:
http://ecx.images-amazon.com/images/I/41wvQPrjFbL.jpg
To prevent lint from flying through the air, the inlet hose (from the dryer) go into water that is poured inside unit, trapping the lint that comes out the vent hose.
DO NOT USE WITH A GAS DRYER!
Jan 20, 2014 | Dryers
Takes longer to dry clothes
Most of the time when your dryer is taking longer and longer to dry the clothes it is due to a clogged dryer vent. Just take the vent off and clean it. If the dryer cannot vent it cannot circulate the air inside the dryer
Jul 15, 2011 | Amana Maytag Dryer Lint Filter Screen...
Dryer is running longer than usual, it's tumbling,
no make listed here...I would pull the hose off the back of dryer and see if a lot of air is blowing out of vent. if not, heres your answer a clogged filter area ..if air blowing out leave vent hose off and dry clothes with vent off for one cycle. if clothes dry with vent hose off..you have a venting issue and need your vent cleaned out...
May 15, 2010 | Dryers
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
The dryer will no longer dry. the last time i used the dryer within 5 minutes there was a burning smell , and now the dry will no longer dry my clothes. every time that i use the dryer i always clean out...
Most likely your venting is kinked or clogged.  First check at the back or your dryer for kinks.  If it is not clogged then check outside your house where the venting comes out with the dryer running if you feel strong airflow then the venting is clear.
Oct 25, 2009 | Dryers
Dryers stopped working during cycle
My dryer stopped working during a cycle last night and won't start again. The light is no longer coming on either. The first thing I checked was the circuit breaker which was fine. Can anyone tell me other possibilities? What is the anser
Jul 17, 2009 | Magic Chef CYE4000AWW Electric Dryer
Heat no longer works
Is this a gas model? Does the glow coil get bright orange then go dark? You would want to measure the current on the glow coil if this is the case. It could be a weak glow bar/coil or bad coils on the burner. This all assumes the thermostat is sending full voltage to the burner. Please do not hesitate to ask more questions.
Eric
Jun 10, 2009 | Whirlpool LGR5636L Gas Dryer
Clothes take longer to dry
The first thing to check on would be your ventillation. Check at the outside of the house to make sure you have a strong amount of airflow coming out of the vent. Should blow pretty hard. If not you need to get your vents cleaned and also make sure the duct behind the dryer is not crushed. Hope this helps. Dave www.washermd.com
Dec 16, 2008 | Whirlpool Dryers
GE Prodigy Electric Dryer not getting hot
The exhaust hose in the back will not affect whether the dryer will heat. The hose just removes the used hot air to a place outside your house. I assume dryer drum spins, but you get no heat. If the dryer has gotten a few years of use, I suspect that the heating element has gone bad. Have you noticed that it has taken longer and longer to dry clothes than it used to? If so, most probably the element is bad. The element is not unlike a heating element in an electric stove, and is housed in a duct inside the dryer.
Mar 10, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
32 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
