Question about New World G70m Gas Double Oven
My grill won't light
I have a New World gas double oven and the ignition on the grill is sparking but there is no gas coming through but the oven is working fine. Can you advise me please on what to do.
  • 1 more comment
  • a_browne Jul 14, 2009
    Yes i had read the manual and it wasn't much help, thanks for the advice.
  • Anonymous Mar 19, 2014
    OVEN AND GRILL IGNITION NOT WORKING
    Scholar:
  • 83 Answers
Hi
Forgive me for asking this, but you have read the instructions haven't you?
If you have, and it's still not working, then the likelihood is that there is a fault, this could be one of the following:
Faulty solenoid valve to grill (some grills had a safety button fitted to stop you from closing the door if the grill was being used)
Blocked pipe inside unit
Either way you need to get a qualified gas engineer to take a look at it, if it's under warrranty call the manufacturers first!
I hope this helps
Steve :)
Posted on Jul 14, 2009
Why does grill ignition click when bottom oven lit
ignition probably serves both, if clicking when not lighting, fault or sticking button
Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
Oven and grill do not ignite appears to be no gas coming through either
check with multi meter ur oven safety gas valve and more than likely ur igniter switch? although the oven safety gas valve dont commonly go out it may somehow have shut off the gas as it has an on/off button usually red in color that can be tripped? check to see if its in off position
Mar 06, 2015 | New World G70m Gas Double Oven
The ignition continues after gas lights on new world elegance/cooker and grill
The igniter will glow orange while the oven is on. This is NORMAL. If it went out the burner would not come back on when the thermostat calls for heat .
Aug 18, 2014 | New World G90m Gas Double Oven
Cannon double oven
The quality of new stuff is not as good at the old, but they are shiny and clean to start with.
With the upper burners, they have just a standard gas igniter, but you say there is no gas. This can only be cause by two things, but most likely a blocked jet for some reason. The only other reason is a faulty control.
The grill is the same, some share igniters, some have one for each of the three department, hobs, grill, ovens.
So your choice is buy a new one or get a service engineer in. It is gas, so you shouldn't really work on this on your own for safety reasons.
Feb 02, 2018 | Ovens
New World G90m grill turns off - overheating?
Its a good chance its the thermal control board to the fan (PCB),if faulty it doesnt allow fan to reach correct speed thus overheating.
Hope this helps
Feb 05, 2012 | New World G90m Gas Double Oven
Grill ignition spark persists when oven on ! how to remidy the problem ?
New electrode or a short on the spark box or electrode out of postion
Oct 31, 2011 | New World G90m Gas Double Oven
Mad gas flame at back of New World G70M
HI it could be agas pressure problem meter pressure too high get the gas company to check it out for you
Feb 04, 2010 | New World G70m Gas Double Oven
I have had 3 engineers out to try and fix my stoves 720gra cooker and has changed all the printed circuit boards ,and all other parts but still the top oven and grill doesnt work and has now been classed...
check the voltage on the spark generator,should be 240dc or 110 ac.
or it could be the harness(wires fron spark generator to ignition) to check harness do a continuity test,an electricion will know,or get a electirc tester and do it with the instructions.
Oct 01, 2009 | Stoves Premier 720GRa Gas Double Oven
Grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Aug 21, 2009 | New World G70m Gas Double Oven
Hotpoint dy230gx
it is normal for the grill electrode to spark as well when lighting main oven - i assume you don't mean that the grill lights - just sparks
Jun 29, 2008 | Hotpoint SY21 Style Line Gas Single Oven
New World G70m Gas Double Oven Logo
822 people viewed this question
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
