Hi Sebastian, not sure what you are looking for please email me at [email protected] so that I can be of better assistance, JT
SOURCE: i have a onkyo tx-sr506 receiver that turns it self off
This unit is in protect mode. This means that a problem was detected and the unit has shutdown to prevent further damage. The most common cause of this is failed output transistors. Plan on $20-$40 for parts for this repair.
Dan
SOURCE: my onkyo tx-sr506 amplifier keeps changing its
If this is a relay driven switching scheme then it is probably a stuck contact.
SOURCE: I have an onkyo tx-sr506 and the system shuts off
Check speakers for distorted or dead drivers . Disconnect and repair. receiver will blown if not disconnected.
SOURCE: I need to know if
Yes it is. The easiest way to go about this is to get a stereo mini male to left and right male rca cable. Connect the stereo mini end into your ipod, and the left and right male RCA end into an available input on your reciever. Change the input on the reciever to correspond with the input you connected to. Ensure your ipod is powered on and playing with the volume turned up. This set up will play through your reciever but will not charge your ipod. If you want it to charge while playing, than you will need to get a dock.
