Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Steam Washer: 1.5 year old. Got an F 35 Flashing error message at end of spin cycle. I can't determine if it won't drain (the clothes are very wet) or it won't drain. I was able to put it into drain and spin mode but the same thing happens.
    Top Expert:
  • Whirlpool Master
  • 75,051 Answers
F35 ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is a malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Found at this link:
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
Posted on Jul 14, 2009
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
F-35 code My washing machine Whirlpool duet steam machine keeps going into the F-35 Code and stops washing.  I don't have the book.  Please, if anyone knows what this means or how to fix it, my email is...
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Sep 12, 2008 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Washer will not wash cloths ol comes up on at end of cycle
This was built by Whirlpool. Try pushing Pause/Cancel twice to clear the error then see if it will spin out. Make sure the drain hose is not kinked.
Dec 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a duet front load whirlpool washer, I bought it about maybe 8-10 years ago. I'm start to get a error code when I wash on a 28 min cycle spin. The error is 5BR or 56R, it will stop spinning in the...
Hi these are not common codes for a duet. Click HERE for a list of common codes and corrective actions needed.
If you have any further questions please feel free to ask.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Rumbling noise during draining
i know with my fridgeadair it was the pump going out of mine , it would take me 3 spins to get the clothes wrung out enough to put in the dryer.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Close are Too Wet
Are you getting any type of error message on the display?
How long have you had the washer? Have you ever cleaned out the filter?
I also have a Duet (2 years old) and my clothes were not spinning out as well as they once did. I started getting a SUD error message with almost every load and then started getting a F5 message which the manual says it means it's not draining correctly. It never said how to fix it though. Went into the panel underneath washer, found the clean out plug for the drain...it was gross! Cleaned it out, washer works like new again.
Feb 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code
Our new Whirlpool Duet had the same problem after only three months of use. We contacted Whirlpool since the washer is still under warranty. The issue is a "bad pressure switch". The part number is W10156252. Service company replaced the part yesterday, and the washer is working like normal. Whirlpool nor the service company had any explanation why the part would go bad in such a short time. No charge since the washer is under warranty.
WARNING - There must be a shortageWe were initially told that the part was backordered for 2 to 3 weeks. We even tried to obtain the part through other vendors and got the same time frame. Furious with the potential of being without a brand new washer for 3 weeks, we spent many hours on the phone with Whirlpool trying to expedite the part. After some strong encouragement and moving the issue up the chain of customer service, Whirlpool agreed to pull a part from the factory inventory where the washers are built. The only problem is that nobody could tell us when, or if, the new part would be shipped. Suddenly, the part just arrived by FedEx at our house. In all, our washer was inoperable for 1 week. Be persistent. They will tell you over and over there is nothing they can do.
If you negotiate well, Whirlpool will extend your factory warranty for an additional year.
Feb 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
