Question about kawasaki KDX126FS Men's Dual Suspension Mountain Bicycle
It was rolled & turned back over the wrong direction frying the fuel injector. Fuel injector replaced-will not start now...help?
  • 867 Answers
Please re-explain what happened, this makes no sense.
Posted on Jul 14, 2009
Second roll over to start engine when it is cold
If a repair shop did the cleaning & tested
some how to tell you that,then the injectors
have to come out & be ultra sonic cleaned
Fairly new vehicle for those issues
Try a different shop
The only reason to replace the fuel pump was
if it failed completely
Car is too new to need spark plug wires,was the ignition
system even tested & was fuel pressure tested?
Have to look at fuel trim on a scan tool also.
Jul 26, 2013 | Cars & Trucks
Impala keeps turning off wile driving
What I can tell you-- is that the egr valve,fuel injectors,crank sensor,
maf sensor-- never failed all at once or at all
That tells me three things
Either nothing was tested
You have no idea what was done & paid for it
Or you installed a lot of parts for no reason
What you can do is find a really good & honest repair
shop & start at the beginning & properly diagnose &
resolve all the cars issues
Had that been done in the beginning, it may have cost
less than all the wasted parts that went in so far for no reason
Dec 13, 2012 | Chevrolet Cars & Trucks
1990 grand marquis has 40 psi to fuel rail. Injectors dont seem to open. Car wount start. Car starts and runs when fuel is sprayed directly into intake.
A lot of cars, trucks, SUV's, Toyota 4x4's will not start , until COMPLETELY assembled. I have left off just the last air boot between the filter & intake throttle body, & NOTHING. Then sprayed a touch of "starting fluid" & Varooom. It came to life. I checked fuel rail, it checked out, still nothing. I gort angry, had picked up the vehicle cheap, for a quick "flip" for some extra money while the wife was hospitalized. I didn't have any more time to fool with it. Put the boot back on between the filter & throttle body. Put a For Sale sign on it. Turned the key....to turn the whell to roll it down into the yard, & it fired & ran. After scratching my head a while, I took the boot off, NOTHING ELSE, no start.sure it is completely assembled.
Sep 08, 2011 | 1990 Mercury Grand Marquis
Trying to work on my friend's 2003 Pontiac Vibe after she had a complete engine failure. We replaced the engine with a salvage & had it running fine when it was up on jacks. After it was let down,...
Where i would start with the injectors shorting out may have shorted out your ecm " computer" This will cause Everything you listed. You can reset just need to contact dealer and find out you reset on this kind of vechical.But i would guess it's fryed with all the short's , Best of luck to you. I i can help any futher just ask, I'll do my best.
Apr 09, 2011 | 2003 Pontiac Vibe
1986 Jaguar XJ6 Won't start. rolls over but that is it. replaced fuel pump relay and fuel pump. seems to have fuel at pump inlet, nothing comes out the outlet. I am lost. car ran out of gas before this...
if your fuel pump and relay are new, how about your fuel filter, if your fuel pump is working but no fuel turns out, check fuel pump polarity, if ok, there will be a clogging in fuel lines, take a high pressure air and plug it to fuel outlet in fuel lines test port, allow air to go back up to fuel tank and observe if the air goes, if not, check or change fuel line, if the air goes to tank, direct your fuel relay pin 30 and 87 and check if the fuel runs to the injectors, if not, change a good fuel pump
Jun 27, 2010 | 1990 Jaguar XJ6
Diesel 1989 F-250 set too long and will roll over
You may have to bleed the fuel system. There may be a very small air leak in the fuel supply line and after a long time idle, the fuel seeps bac into the tank, leaving an air lock in the pipe. When you go to start, this air makes its way into your injection pump & needs to be bled out before the engine will start. Begin from your fuel filter bleed valve, next the injection pump using the primer pump to transfer the fuel. Next loosen off the injector pipes and crank the engine over until fuel sprays form all the joints. Tighten injector pipes and start. It may run a bit rough for to begin with, but will soon even out. If it doesn't start, repeat bleeding of injectors.
Mar 13, 2010 | 1989 Ford F 250
All four injectors stopped working
Try the carb cleaner fluid by mixing it with the fuel or spray it at the intake. After cranking the engine a few times, wait for a while and if the engine refuses to start, get some young men to try & start it by rolling the vehicle & turn on the ignition(i.e. if it has has manual gear shifting) till the carb cleaner has got a chance of forced into the injector to clean the nozzles. If this fails then it(injectors) cleaned by maul removal & cleaning/replacing the injector nozzle tips by a qualified mechanic....sodeep
Aug 18, 2009 | 1992 Nissan 240SX Fastback
Fuel injectors not working...
check fuses,you could have fried PCM
Jul 04, 2008 | 1989 Chevrolet C/K 2500
FUEL NOT GOING TO INJECTOR
check fuel pump, fuel pump relay, roll over switch or fuel pressure regulator, lastly, check fuel filter.
Jun 26, 2008 | 1999 Oldsmobile Alero
kawasaki KDX126FS Men's Dual Suspension Mountain Bicycle Logo
35 people viewed this question
Top kawasaki Cycling Experts
Greg White
Level 1 Expert
Jeffrey Turcotte
Jeffrey Turcotte
ray gallant
Are you a kawasaki Cycling Expert? Answer questions, earn points and help others
