Just makes terrible fringing noise but will drive in 4 wheel drive but makes a clanking sound
SOURCE: wheels making binding noises when turning
I have this same problem with my 1996 Subaru Legacy 2.2 Wagon. There is a Subaru Service Bulletin #16-62-97 dated 5/16/97 with a Subject entitled "Transfer Clutch Binding And/Or Bucking On Turns". There is also an important follow-up to it numbered 16-64-99 dated 09/15/99 entitled "Revised Transfer Clutch Assembly Replacement Procedures" that should also be used should you decide to go ahead with the transfer clutch replacement.
I just got these Service Bulletins from my mechanic who got them from a Subaru dealer.
The estimate was about $700-$1000 to fix. This is more than likely the cause of the binding problem on slow, sharp turns.
Dan Hunt
Danbury, CT
SOURCE: My 2004 F-150 2WD is making a clanking noise on front left tire
The sway bar linkage probably came undone on one of the sides. Wikipedia has a picture of what your sway bar linkage may look like:
http://en.wikipedia.org/wiki/Sway_bar
That is a picture of a Porsche sway bar, but the idea is the same. Make sure all bolts are tight and that one end is not missing the linkage that connects it to the spring/strut. The grinding of the brakes may be the sound of the linkage piece touching the rotor. Sway bar is a logical solution to both issues.
If that doesn't fix the issue, put the front end of the truck on blocks or jack stands and have somebody wiggle the tire up/down and side to side while you inspect the mechanical components underneath. Other things to check may be the ball joints, tie rod ends and suspension bits.
SOURCE: Noise in front end 2002 zr2 blazer
Two things maybe your problem:1 .Front axle actuator to engage 4wd is not releasing. 2. Front axle u-joint needs replacing. Lift car on jacks with front end off ground. Then spin tires by hand as fast as you can and see if you hear the noise and where it is coming from ( spin in both directions).
Testimonial: "Thank you! It was the actuator that was causing the problem."
SOURCE: GMC '91 Jimmy, Transfer case. When in two wheel
Yeah your right about waer but you might be blaming the wrong part. With the truck up on jack stands ( all wheels off the ground) have a helper drive the truck at the speeds that make the most noise you'll find it in the front axel or fround U joints or drive shaft splines ( drive shaft jumping ) You watch the parts moving and the joints or the cable that shifts the ront axel in and out not moving all the way it uses a vacume motor under the battery that has a cable going to the front axel. the clutches that are in the front axel have clips on them that hold the side gears that engage and disingage as you turn it on and off the clips break get lost fall off were out and let the side gears do as they please and they runinto each other a click and pop/ the cable and the shift fork that move them also fail but not htat much as the cable fails and the vacume leak pulls on a spring in two wheel and it may not be pulling hard enough/
Testimonial: "He's an Expert!"
SOURCE: 1994 ford ranger 4x4 hubs make grinding/clicking noise after taken out of four wheel drive
I think yours has the automatic locking hubs that slide over the the rotor hub. If this is the case than what has probably happened is a u-joint has gone bad and wiped out that auto hub.
Be prepared for some sticker shock on those hubs. they are not cheap. The usual fix for this is to replace the front axle ujoints and what ever hub is making the noise, hopefully just one.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
