Question about Mitsubishi VS-60111 60" Rear Projection Television
Colors not right
I tried the auto factory setting and the colors are not right
  • 1,694 Answers
If "colors are not right" means red,green or blue separation =
convergence mis-alignment. That repair requires replacement
of the convergence IC's, a PCB overhaul.Above average tech
ability required...............Do you want step-by- step how to.....?
Posted on Nov 17, 2007
Geek Squad broke my Television
Try these settings:
Picture Mode: Movie
Contrast: 100
Brightness: 44
Sharpness: 20
Color: 50
Tint: 50
Backlight: 7
Color Tone Warm1
Digital NR Auto
Detailed Settings
Black Adjust Low
Dynamic Contrast Low
Gamma -1
Color Space Auto
Edge Enhancement On
xvYCC Off
White Balance
R-Offset 21
G-Offset 20
B-Offset 21
R-Gain 0
G-Gain 21
B-Gain 26
My Color Control
Pink 20
Green 15
Blue 15
White 15
Auto Motion Plus 120hz: Low
Feb 28, 2014 | Samsung UN55C6500VFXZA 55in Led Hdtv 1080p...
How to change the power on default copy mode form color to black & white.
Hello Gary
On the main copy display your device is probably set to the factory defaults which means that when you press reset the device is in "AUTO COLOR". Touch the "AUTO COLOR" tab on the screen and a drop down menu will show. Select "BLACK AND WHITE". Now press the "ADDITIONAL FUNCTIONS"key. Select COPY SETTINGS located at the top right. Scroll down till you see STANDARD SETTINGS and select it. Press STORE. You are fixed!!! Please let FIXYA know I helped. :-) SPINAL
Jun 17, 2011 | Canon imageRUNNER C3380i Color Copier
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
I bought a used canon xs from craigslist. I think a hard lesson learned already. Anyway the camera appears to be in great condition. The problem is whenever I take a picture it does not come out right. ...
The experts at Canon are probably right. But, check the white balance and make sure it is on "auto WB". Go into the camera menu and find "reset" to get the camera back to factory default settings. If it still doesn't work, then you probably need a sensor replacement which can be expensive...maybe more than you paid for the camera.
Dec 24, 2010 | Cameras
I am trying to change color laserjet 2600n back to English and need some assistance. can you help?
Restoring the factory-set defaults
Restoring the factory-set defaults returns all of the settings to the factory defaults.
To restore the factory-set defaults
1 (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press
Use the
2 (LEFT ARROW) or the (RIGHT ARROW) button to select Restore defaults, and then
Use the
press (SELECT).
The device automatically restarts.
Then you need to change the default settings back to what they were.
Oct 19, 2010 | HP Color LaserJet 2600n Printer
Sony Cybershot question
Hello: on the backside (screenside) of the camera, on lower right hand corner there is a hole for the reset button. Use a paper clip to push in to reset the camera back to ALL factory original settings. You will need to manually reset date, time, etc.
Apr 28, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
I am not sure what out of position refers to but if it is a setting in the printer this should fix it.
Restoring the factory-set defaults returns all of the settings to the factory defaults. Restore the factory-set defaults
  1. Use the c00317853.gif (LEFT ARROW) or the c00317858.gif (RIGHT ARROW) button to select Service, and then press c00317851.gif (SELECT).
  2. Use the c00317853.gif (LEFT ARROW) or the c00317858.gif (RIGHT ARROW) button to select Restore defaults, and then press c00317851.gif (SELECT). The device automatically restarts.
  3. Hope this helps
Mar 24, 2009 | HP Color LaserJet 2600n Printer
My scanned color photos
  1. Check the automatic brightness and color settings by doing the following:
  2. Click Settings , click Scan Settings and Preferences , then click Preferences .
  3. Enable or disable (depending on their current state) the Automatically adjust exposure and/or Automatically adjust color settings.
  4. Click OK .
  5. Expand the scan preview by clicking the arrow on the right, and then adjust the Color settings prior to performing a final scan.
  6. Sometimes the scan will pick up reflected colors, try rotating the original 90 degrees and then scan again.
  7. All models except the PSC 1100 and 1200: If the scan still is not right, try resetting the all-in-one back to the factory default settings. Follow these steps to reset the defaults:
  8. Press Setup or Menu depending on your model.
  9. Press the Right Arrow or the Down Arrow until Maintenance or Tools appears in the Display, and then press Enter .
  10. Press the Right Arrow or the Down Arrow until Restore Factory Defaults appears in the Display, and then press Enter .
  11. Reset the all-in-one by unplugging the power cord and then plugging it back in. This will force the all-in-one to recalibrate
Good Luck
Aug 12, 2008 | HP Officejet 5510 All-In-One Thermal...
Negative color
You'd have to indicate here what your current settings are. Otherwise, reset all to factory defaults and try again. Make sure AUTO is selected!
Nov 20, 2007 | Nikon COOLPIX L3 Digital Camera
Colors in QL-711V shifted to green
Hi, I had the same problem and I wrote an email to Nu. They wrote me back that I should use the Factory reset feature which you have to go through the Factory Menu to get to. Instructions to do this are as follows. I got to the menu my first try but it has been a pain to get back to it. I hope it will be easier to access for yours.
Hope this helps
Page 1
You will need to display a gray scale picture which varys from black to white
You will need to display a gray scale picture which varys from black to white. Displaymate 16 grays pattern is good or something like the picture to the right. 1 Press and hold SEL/AUTO and press the power button. Then release the SEL/AUTO button. 2 Press the MENU key to display the factory menu. Sencore 11 gray Pattern 3 Press the and select FACTORY2 menu. Factory2 is at the bottom. Press SEL/AUTO to select the FACTORY2 menu. 4 Press the to select AUTO COLOR. 5 Press the to run AUTO COLOR. Wait until finished. You will see the colors changing and then become stable when finished. About 10 seconds. 6 Press the and select COLOR UPDATE. 7 Press the to run COLOR UPDATE. It will finish quickly. < 1second. 8 Press MENU to exit the menu. Power off/on.
Nov 05, 2007 | NuTech QL-711V 17" Flat Panel LCD Monitor
Mitsubishi VS-60111 60" Rear Projection Television Logo
127 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
