Question about Vodavi Starplus SP7314-08 Corded Phone
How do you turn ringer volume up on a starplus sts phone
CORDLESSGURU
  • 106 Answers
SOURCE: Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Posted on Mar 23, 2008
  • 11 Answers
SOURCE: Ringer volume
Adjusting the ringer will depend on the type NEC system you have. On the PRO II, Elite, and IPK just press the Speaker button and dial 601. The Phone should begin to ring and you can then adjust the volume with the up and down arrows.
Posted on Apr 21, 2007
SOURCE: Ringer Volume
I am assuming this is on a DTU 16D nec phone. On the right side of the phone is a volume up and down button. If someone calls you, you adjust this while the phone is ringing. If you adjust it after you answer it controls the voice volume (what you hear through the ear piece) if you adjust it while the handset is down but there is no one calling you it adjusts the display contrast on the phone.
Posted on May 10, 2007
  • 3 Answers
SOURCE: How is ringer volume adjusted?
VOLUME
While talking, press the VOLUME buttons (left and right
arrows) to control the volume of the handset's earpiece.
There are four volume levels. Press the right arrow (+)
button to increase the volume level, and press the left
arrow (-) button to decrease. VOL 1 is the lowest level and
VOL 4 is the loudest.
Posted on May 16, 2008
AvioriX
  • 689 Answers
SOURCE: lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Posted on Nov 11, 2008
Looking for phone line template for Starplus STS for the actual unit
Desi doe templates for just about any phone. You can find them on line. and you can download their software to allow you to print the tempates with cutom info.
Feb 27, 2013 | Vodavi Starplus STSe Universal KSU 3501-01
On a Vodavi STS Starplus STS... Is there a way to lockout outside lines an a few stations but keep the intercom?
Sure. Restrictions are governed by the station Class of Service. COS6 is intercom only, or you can build tables and give a station some calling capabilities. There's also a traveling class of service and verified account codes to override your restrictions for users with a proper code.
COS descriptions are on pdf page 85 of the STSe manual http://www.wedophones.com/Manuals/Vodavi/Vodavi%20Starplus-STS/STARPLUS%20STSe%20Programming%20and%20Operations%20Manual.pdf
Carl
Jan 06, 2011 | Vodavi Starplus SP7314-08 Corded Phone
Hi. We need a wiring diagram for the Vodavi
http://www.wedophones.com/Manuals/Vodavi/Vodavi%20Starplus-STS/Starplus%20STS%
Jun 24, 2010 | Lands Phones
Can't access Vodavi STS Starplus voicemail to program it
THE VOICEMAIL OF OUR PHONE SYSTEM IS NOT WORKING RIGHT...
Nov 05, 2009 | Vodavi Starplus SP-7314 Corded Phone
Our church has a vodavi starplus sts phone system. one of the phones does not ring, can someone please tell us how to fix the problem.
You must go into CO line programming and put that station into the ring assignments for each outside line you want to ring at that station. It's Flash 40, page A, button 10.
Sep 23, 2009 | Vodavi Starplus SP7314-08 Corded Phone
Starplus STS Need breakout info for Analog x148 and 149
I am a Vodavi tech. Not sure about break out info but if you plug a standard house phone into the plugs on the side of the white phone box in either port and it will work as a phone in the system. Press 9 and get an outside liine. You want to know more, I can make it do a lot.
Jul 08, 2009 | Vodavi Starplus SP7314-08 Corded Phone
Vodavi Starplus STS Caller ID not saving numbers
Please tell me how to change the number of rings on my Starplus STS before it goes to VM. I'm dying! It goes to VM after 3 rings and were missing tons of calls. Thank you!
Feb 25, 2009 | Vodavi StarPlus 2706 Corded phone
Starplus Phones
Is this still open? If it is, please go live. I said I was a Vodavi tech, you may have more questions that we can answer real easy. If you have Starplaus, XTS, DHS, or STS
Jan 13, 2009 | Vodavi Starplus DHS 7314 Executive Phone...
Starplus STS answering in night mode during day
Phone system voicemail directory set to play night menu.
Nov 05, 2008 | Vodavi StarPlus 2706 Corded phone
Vodavi Starplus STS
If this hasn't been solved, I am a certified Vodavi tech. Please give me a call
Aug 04, 2008 | Vodavi Starplus SP7314-08 Corded Phone
Vodavi Starplus SP7314-08 Corded Phone Logo
1,549 people viewed this question
Top Vodavi Lands Phones Experts
george  peters
george peters
Matthew MacWilliams
ray gallant
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
