If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
SOURCE: i need step by step
The code for a JVC TV is 0053 (non-combination TV). To program the remote, turn on the tv manually. Then press the TV button once. Then press and hold Set until the LED blinks twice. Then release Set. Aim the remote at the TV and enter the four digit code. The LED should blink twice again. Press the power button on the remote. The TV should turn off. Turn it back on and check if the remote does the other functions that it should for the TV.
There is a manual code search option. Press TV once, then press and hold Set until the LED blinks twice. Release Set and enter 9 - 9 - 1 . Then aim the remote at the TV and alternate between pressing Power and TV. When the TV turns off, press Set to save the code. Turn the TV back on and check if the remote performs other functions. If not, repeat the above steps until another code turns off the TV.
The manuals for All-for-One Remotes are available here: http://www.oneforall.com/support/manual . Choose universal remote control in the top drop down and then the URC-4220 in the second.
Please note that universal remotes only have codes for devices released 6 months of more before the remote was programmed. If your TV is newer than your TV, then you may need a newer remote.
I hope this helps.
SOURCE: I need jvc tv codes for the lm-1079 universal
2695,2650,2641,2660.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
SOURCE: I have a lm-1079 universal remote and lost the
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
