Question about Pool & Spa
I have a robo-kleen pool cleaner which stops
I have a robo-kleen pool cleaner. The power supply still lights up and filter water is initially pumped through the top of the unit, the unit then moves along the bottom of the pool for a brief time and then stops.
  • 78 Answers
If debris is entering the bag, it may be as simple as that. The bag is clogged. We typically recommend hand cleaning a pool before using an auto cleaner specifically for that problem. You might have to remove and clean the bag 50-75 times. Much easier to hand vac first. If no debris is getting into the bag before it stops, it could be a problem with the motor. we have seen them "short cycle" and require replacement. Rob
Posted on Apr 23, 2010
My robo kleen is oily
that is pool water mixing with some kind of lube
take off the metal plate and drain plug
let water drain out
Sep 05, 2013 | Smartpool Dolphin Robo - Kleen Above...
Robo kleen pool vaccum- not sucking- wheels move - prop on top turns very slow
if you hear a buzzing sound
there is water in the motor
if it drives ok, the power supply should be ok
try draining the water out of the small plate and plug shown
when you take out the filter bag
it will probably happen again
but a motor can be expensive to replace
Jul 31, 2012 | Smartpool Robo Kleen
I have a Robo Kleen robotic pool cleaner, it still moves around but is no longer picking anything up. The bag is clean. Can I purchase a pump for it?
You should be able to purchase pumps for these automatic pool cleaners from a pool supply company, but I would take it to a professional first. It could be something that is easily fixed without purchasing an expensive part.
Aug 24, 2010 | Smartpool Dolphin Robo - Kleen Above...
What is the output amps on robo kleen transformer
Here is the users manual for these pool cleaners. You might be able to locate the information you are looking for there in the parts specification manual.
http://www.backyardcitypools.com/Pool-Cleaners-Automatic.htm
Jul 03, 2010 | Smartpool Dolphin Robo - Kleen Above...
Robo kleen stopped sucking
Make sure that your filter bag is clean and free of obstructions. You will also want to check your impeller to be sure that nothing has jammed it. A jammed impeller actually occurs pretty frequently on these automatic pool cleaners.
Apr 24, 2010 | Smartpool Dolphin Robo - Kleen Above...
Need a motor. were can I buy. motor is frozen (robo kleen)
if it drives but does not pick up anything
then thats the motor with the prop, water gets in it
but there are two screws with metal plate on back of motor
and a round plug then a green plug to let the water from your pool out
Sep 26, 2009 | Smartpool Dolphin Robo - Kleen Above...
Robo Kleen pool cleaner troublshootong
One thing that you might want to try on these pool cleaners is removing the limit screw on the axle for greater angle of tandem wheels. Make sure your filter bag is not clogged or partially clogged because this cause restrict movement. Check for debris jammed in your drive system (wheels, axles, etc.)
Aug 16, 2009 | Smartpool Pool Hog Ig Robotic Automatic In...
Pool & Spa Logo
219 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
