Question about Kenmore Dryers
My Kenmore dryer squeels when drying. It is an electric dryer, about 4 years old.
    Problem Solver:
  • 5 Answers
Two things the dryer drum is turned by a belt that goes around the motor, drum and a tench pulley. The tench pulley could be making the squeal. Or the drum rides on two wheels on the bottom side of the dryer they go bad and need to be replaced.
Posted on Jul 14, 2009
Kenmore elite dryer is not generating heat to dry clothes. The machine is less than 4 years old
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 01, 2010 | Kenmore Elite HE4 Electric Dryer
Wet and cold clothes after cycle
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 31, 2010 | Kenmore 72062 Gas Dryer
Our kenmore eliite HE4 gas dryer keeps shutting off after a few minutes of running no mattter what heat setting we put it on. On air dry mode it works. Is this a high heat sensor problem? The unit is 4...
You didn't mention if the dryer is getting hot.
If is getting hot, then shutting off, I agree with you.
If it is NOT getting hot, I would suspect the IGNITER ASSY
Dec 13, 2009 | Kenmore Elite HE4 Electric Dryer
15 year old Kenmore dryer not working
Sounds like you thru the breaker. If not, it is the door switch.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Feb 20, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer takes to long to dry
You may have to get inside the exhaust assembly ...somtimes there are lint buildups that occur and cause long drying times. Also make sure you don't have a DUAL heating element model. I had one and only one of the elements worked when I repaired the second one it worked great. Most likely is the exhaust block however. Hope this helps.
Jan 18, 2009 | Kenmore 659 Electric Dryer
Dryer making horrible squeeling noise
this is normally a problem with rollers that have gotten dry bearings , take the drum out check the rollers if they turn hard or act sticky you may clean them up and and oil with turbine oil , do not use wd-40 or 3in 1 as these will dry the bearing, check the idler pulley while you have this apart also oiling it if need be
Dec 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore Elite HE4 electric dryer locked on express dry only......
Shut the breaker off for several hours. Turned it back on.
Nov 30, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer only heats on delicate
how to install rubber belt on kenmore gas dryer number 110.72712101 ?
Jun 14, 2008 | Kenmore Dryers
Dryers Logo
61 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
