Question about Whirlpool Duet GHW9150P Front Load Washer
I was told the bearing is shot on the Whirlpool Duet Washer and it is not worth repairing, the machine is only 6 year old, any advice?
    Problem Solver:
  • 11 Answers
I would not spend a nickle to repair a 6 year old whirlpool HE. If you are going to do the bearing, you will also need to do the basket as your basket support is probably rotted to $hit and ready to snap. Bearing failure itself is a major teardown of that machine to repair. Fughedaboutit
Take my advice on this one.
Posted on Jul 16, 2009
  • 867 Answers
A 6 year old washer should not be scrapped unless it is made in china, replacing a 5$ bearing is worth fixing. even if you need to buy a drum unit.
Posted on Jul 14, 2009
How much is this Model worth? 6 years old?
Worth Not much as life expectancy on most new appliance is 4 years or less ,it called plan obsolescence or made to fail as economy is based on consumerism not quality
Aug 20, 2014 | Whirlpool Duet Front Loading Dryer Rack...
18 minutes into a 40-minute cycle, the Whirlpool Duet washer gave a loud bang and stopped. Upon opening, emptying and bailing out of the water, it was found that the drum appeared to have fallen inwards....
Duet notes from my Forum:
Duet washer started getting louder and louder during the spin cycle. When I manually turned the basket I could feel that the bearings were shot. A quick search of the internet confirmed that this problem was no fluke. I found an illustrated parts breakdown of my washer online, and saw that Whirlpool only offers a replacement rear tub assembly, at a cost of $408. Needless to say, I was peeved. I paid about $960 two years ago for this machine, and now it will require $6-700 in repairs. Unacceptable. So, having a mechanical background, I started to tear into the machine myself. I tore it all the way down to the rear tub half. I found what appeared to be the problem with my machine, hair. Hair worked its way to the bearing area, slowed unseated the seal, and then acted as a conduit for water to enter the bearing cavity. The seal itself actually looked fine. Yet the steel hub that the bearings are pressed into was badly corroded, as were the bearings, and even the drive shaft had corrosion on it. I pounded out the cheap factory bearings, cleaned up the bearing cavity and drive shaft, and replaced them with some higher quality Toyo's from my local bearings and drive store, P/N's 6206ZZC3 & 6205ZZC3. Unfortunately they didn't have a suitable replacement seal in stock. I didn't damage the factory one too badly upon removal, so I straightened it up with a couple of hammer taps, made sure it sealed nicely against the drive shaft, and reused it. The new bearings cost me $20. I made sure I sent a nasty gram to Whirlpool, they offered me a replacement rear tub for 50% off, I told them to stick it. Hopefully I get at least 3 more years out of it, I've already started looking for my next machine, I'm likely going to buy a Speed Queen. Anyways, if your tub bearings are shot and you have the will, they can be replaced yourself for a fraction of the cost of a factory rear tub half. My advice, take notes during dis-assembly, keep all the hardware from the different components you remove separated from one another. Don't be afraid to use permanent marker to write reminders directly on the components as they'll be hidden inside the reassembled washer when done. I did the repairs by myself, having a helper would've made things much easier. As for tools, I was shocked at how few I actually needed. A nut driver or torx apex, a 1/2" socket and rachet, some slip joint pliers, a wrench to remove the drive pulley, and a hammer and punch to remove/install the bearings. Service manual
Jul 23, 2011 | Washing Machines
Main rollerbearing of tub is no good and cannot buy just bearing but also tub etc.what todo? is there a recall on this model
Here you go: Plan B:
NOTE: Every production run I don't know from. Here are some notes:
Duet washer started getting louder and louder during the spin cycle. When I manually turned the basket I could feel that the bearings were shot. A quick search of the internet confirmed that this problem was no fluke. I found an illustrated parts breakdown of my washer online, and saw that Whirlpool only offers a replacement rear tub assembly, at a cost of $408. Needless to say, I was pissed off. I paid about $960 two years ago for this machine, and now it will require $6-700 in repairs. Unacceptable. So, having a mechanical background, I started to tear into the machine myself. I tore it all the way down to the rear tub half. I found what appeared to be the problem with my machine, hair. Hair worked its way to the bearing area, slowed unseated the seal, and then acted as a conduit for water to enter the bearing cavity. The seal itself actually looked fine. Yet the steel hub that the bearings are pressed into was badly corroded, as were the bearings, and even the drive shaft had corrosion on it. I pounded out the cheap factory bearings, cleaned up the bearing cavity and drive shaft, and replaced them with some higher quality Toyo's from my local bearings and drive store, P/N's 6206ZZC3 & 6205ZZC3. Unfortunately they didn't have a suitable replacement seal in stock. I didn't damage the factory one too badly upon removal, so I straightened it up with a couple of hammer taps, made sure it sealed nicely against the drive shaft, and reused it. The new bearings cost me $20. I made sure I sent a nasty gram to Whirlpool, they offered me a replacement rear tub for 50% off, I told them to stick it. Hopefully I get at least 3 more years out of it, I've already started looking for my next machine, I'm likely going to buy a Speed Queen. Anyways, if your tub bearings are shot and you have the will, they can be replaced yourself for a fraction of the cost of a factory rear tub half. My advice, take notes during dis assembly, keep all the hardware from the different components you remove separated from one another. Don't be afraid to use permanent marker to write reminders directly on the components as they'll be hidden inside the reassembled washer when done. I did the repairs by myself, having a helper would've made things much easier. As for tools, I was shocked at how few I actually needed. A nut driver or torx apex, a 1/2" socket and ratchet, some slip joint pliers, a wrench to remove the drive pulley, and a hammer and punch to remove/install the bearings.
Jan 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
Hello, Model Number WFW8300SW00. We need a part number for the drum bearing? Would you be able to help us? Where can we get it? Thanks, Milka
Duet washer started getting louder and louder during the spin cycle. When I manually turned the basket I could feel that the bearings were shot. A quick search of the internet confirmed that this problem was no fluke. I found an illustrated parts breakdown of my washer online, and saw that Whirlpool only offers a replacement rear tub assembly, at a cost of $408. Needless to say, I was pissed off. I paid about $960 two years ago for this machine, and now it will require $6-700 in repairs. Unacceptable. So, having a mechanical background, I started to tear into the machine myself. I tore it all the way down to the rear tub half. I found what appeared to be the problem with my machine, hair. Hair worked its way to the bearing area, slowed unseated the seal, and then acted as a conduit for water to enter the bearing cavity. The seal itself actually looked fine. Yet the steel hub that the bearings are pressed into was badly corroded, as were the bearings, and even the driveshaft had corrosion on it. I pounded out the cheap factory bearings, cleaned up the bearing cavity and driveshaft, and replaced them with some higher quality Toyo's from my local bearings and drive store, P/N's 6206ZZC3 & 6205ZZC3. Unfortunately they didnt have a suitable replacement seal in stock. I didnt damage the factory one too badly upon removal, so I straightened it up with a couple of hammer taps, made sure it sealed nicely against the driveshaft, and reused it. The new bearings cost me $20. I made sure I sent a nastygram to Whirlpool, they offered me a replacement rear tub for 50% off, I told them to stick it. Hopefully I get at least 3 more years out of it, I've already started looking for my next machine, I'm likely going to buy a SpeedQueen. Anyways, if your tub bearings are shot and you have the will, they can be replaced yourself for a fraction of the cost of a factory rear tub half. My advice, take notes during disassembly, keep all the hardware from the different components you remove separated from one another. Dont be afraid to use permanent marker to write reminders directly on the components as theyll be hidden inside the reassembled washer when done. I did the repairs by myself, having a helper wouldve made things much easier. As for tools, I was shocked at how few I actually needed. A nut driver or torx apex, a 1/2" socket and rachet, some slip joint pliers, a wrench to remove the drive pulley, and a hammer and punch to remove/install the bearings.
Jun 10, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet WFW9200SQ02 - high speed spin extremely loud!
I have the exact same washer, its also 2 years old, and this last week my bearings went bad too. I actually pulled my washer apart and replaced the stock el cheapo bearings with some better quality ones by Toyo. No, theyre not titanium, I'm a mechanic and I've never even seen titanium sealed bearings before. Not doubting they exist, but I highly doubt youll find them in any residential appliances regardless of make. Upon disassembly, I found what I believe is the issue with the seal, hair. Hair works its way to the drive shaft, slowly works its way into the seal, and then acts as a conduit for the water to enter the bearing cavity. Both sealed bearings eventually have thier grease forced out by water, and fail. This repair is time consuming, but it can save you a LOT of money. Whirlpool only sells a whole new rear tub, at a cost of $408 just for the part. I took it apart and found that the bearings are simply pressed into the steel hub on the rear tub half. I knocked them out, and a local bearings and drives shop had some replacements for me, for $20. I put it all back together, and its running fine. If you attempt this repair, make notes, and mark where everthing goes. You'll need to disassemble a substantial amount of the machine to get the tub assembly out. If youre not able to do the repairs yourself, I recommend buying a new washer, its just not worth spending $6-700 to have a shop do it.
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Help with bearing
i do hope that you have been using he detergent if not it will take the bearing out, if you have then the bearing just went bad i would call whirlpool at 800-874-4698 they may be able to offer assistance if you dont have an extended contract on the washer
May 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
366 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
