Question about HP ATI FireGL V3350, PCI Express Graphic Card
Entering power save
If I shut off my secondary monitor, when I turn it back on again it claims there is no input from computer and enters 'power save mode'. Only fix is to restart computer. I also lose my secondary monitor if the monitor goes into standby (which I have since disabled). I my secondary monitor is a Dell 2408WFPb
Thanks,
Matt
  • 358 Answers
The reason why your secondary monitor is showing no input from computer is because of the display resolution of your graphics card, which is higher than what the Monitor can handle.
What you can try is, when your system is powered up, just go to your display settings, then reduce the systems display resolution to--preferably 800x600, then go to where you normally select the output, and select 'Output to external monitor"...this should send the signal input to the monitor.
I have actually dealt with a no input signal before, and this was what I did.
Hope this helps.
Posted on Jul 15, 2009
My monitor won't come out of sleep mode
when the computer enter the sleep mode, it is possible that the computer remove the check mark from this output activation.
When you have multiple ouptut like a internal LCD and output on a monitor, when going into sleep then waked up, laptop reactivate the internal LCD without reactivated the secondary monitor.
you could need to go in desktop property and reactivate the secondary monitor with the check mark listed : Activate.
If you only have one monitor but still a dual output card or two separate video card same thing can happend. try to connect the monitor on the second VGA or HDMI output and see if the video goes there.
then reactivate your secondary output and make it principal.
Does also happend when your computer is connected to a UPS power and your monitor is directly on the sector. (laptop issu also)
if a brief power outage arrive then the monitor shut down (no power) and the computer continu, as there is no monitor on the output any more Windows will automatically deactivate this monitor. when power goes back, this output is no longuer providing video. I suggest putting the monitor on a UPS as well.
Jan 03, 2014 | Westinghouse Electric L1916HW 19" Monitor
Dell E207WFP Display Problem
check your system vga out put is working or not, conform this by connecting another monitor or connect monitor to another computer.
May 11, 2012 | Dell E207WFP LCD Monitor
Don't have any video everything is never been used have three different vid cards and nothing comes on but the tower i don't get any video no matter what card i put in it.
Turn the computer off, and disconnect the AC power.
If the motherboard has an "integrated" video-adapter, connect one monitor to its VGA port, and connect another monitor to the VGA port on the add-in video-card, and turn the computer on, and watch both monitors, to see which one becomes "primary" and which one becomes the "secondary" monitor.
Reboot, and enter BIOS SETUP, and "disable" the "onboard" video-adapter, then "save and exit" and reboot. Now, which monitor stays "dark" and which monitor is "primary" ???
Mar 03, 2010 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Monitor turns itself off
hi, you must have enabled power saving options. Thats why your monitor shut down. you can disable, just do the same:
1.Right click on desktop
2.Select properties.
3.Select "ScreenSaver".
4.Select "Power" under Monitor power option.
5.There select "never" from Turn off monitor (drop down menu).
Now your monitor will not turn off automatically.
Sep 19, 2009 | Dell Inspiron 531s Desktop Computer
Monitor will not turn on
First check your num lock key on key bord if it is on off when you press num lick key then your dispaly is working fine means you need to change screen resolution.
For that when you power up the computer press F8 key then enter in enable vga mode.then go to display property and change screen resolution to 1024*768 or 800 *600.
Also when you power up the computer press F1 or F2 or 'del" key to enter in bios then load optimal defaults also check your harddisk is detected .Disable your satat option in bios .then save settings then check.
I f you not able to enter in bios then Refix your ram.If still face problem you need to reset bios .
For that you have to open laptop cover in back then pull cmos cell from mother bord for 5 minutes then refix it then check.
Jul 27, 2009 | HP Pavillion dv9740us Notebook
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
My LCD monitor is going into power saving mode
Hi...there,
Your monitor enter to power saving mode to prevent further damaged. It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it...
Oct 13, 2008 | Computers & Internet
Pc entering power save mode
I am having the same problem . The system is starting up and th epc entering power save mode. I have a Hp pavilion f1503 model monitor. I hit the power off button on the power surge to shut the entire power off. I turn the power surge button back on. Sometimes it works. Or have to hit the power on button to reboot.
Dec 12, 2007 | HP Pavilion a810n (PP164AA) PC Desktop
HP ATI FireGL V3350, PCI Express Graphic Card Logo
320 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
