Question about Kenmore HE2 Plus Front Load Washer
Stops at 23 min in cycle have to restart
How do I get the codes
3 Suggested Answers
SOURCE:
richroth
  • 9472 Answers
SOURCE: washer stops at 23 min. Error code f1.Must restart til timer passes 22 min.
Check the air dome transducer hose first,
(the clear plastic tube that goes from the control board to the right side of the outer tub connection)
for kinks, clogs, twists,etc.
If the hose is OK,
Yes, you will need to replace the control board.
Here is the control to order.
Posted on Dec 03, 2012
richroth
  • 9472 Answers
SOURCE: washer stops "code F1" at 23 minutes.
See other post.
Top drawer stops, will restart if I push start
Sounds like a micro switch problem to me, telling the dishwasher that the drawer is open when it is not actually open.
Dec 26, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Kenmore Elite Washer Oasis Model: 11027042603 I have been getting a F1 code error with all wash cycles for the past month. It occurs as soon as I start the wash cycle and with 23 minutes remaining in the...
depending on its age take a look at the motors brushes. sounds like 23 mins would be spin cycle when the motor picks up speed. they may need replacing.
Dec 08, 2013 | Washing Machines
Dd603 stops at 56 min
Try to confirm if the unit works ok with the Rinse cycle. If that is ok then most likely the heater element is faulty. Feel water temperature when it stops.
Jan 09, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washer stops at 23 min. Error code f1.Must restart til timer passes 22 min.
If the hose is OK,
Dec 02, 2012 | Kenmore Washing Machines
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
Stops in middle of cycle at 26 mins
Does it pause?... and if you press the run button again does it restart?... if this is the problem, try cleaning the sensor prism on the top right of the housing, If its dirty you get these type of problems when the unit heats up....
Dec 05, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Stops at 23 mins with error code e 20
E20 is a draining problem. the first thing to check is the filter at front of machie as there may be something blocking the pump.
Before removing filter tilt machine back and place a bowl under as there will be water inside.
Thanks for using Fixya.
Jan 08, 2009 | Zanussi ZWF1430W Front Load Washer
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Kenmore HE2 Plus Front Load Washer Logo
87 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
