Question about Dewalt Tools & Hardware - Others
DEWALT 16 GAUGE ANGLE NAILER WONT FIRE BUT THE LIGHTS KEEP FLASHING
  • 1 more comment
  • lolandstu Jul 15, 2009
    hi there
    it is the right angle and gauge it is a dc618
    thanks
    hi there amte,change the nails to pasalode and it seems to be working fine,thanks for your advise
    stewart
  • David Ford
    David Ford May 11, 2010
    did you check for a jammed nail first? are you using the right guage nails for this tool and the right angle? Give me the model number and I will try and find a breakdown for this and see if I can help.
  • 313 Answers
If the light keeps flashing then the battery is not charged enough to fire the gun. recharge the battery or buy a new one if it continues.
Posted on Sep 08, 2009
D51275 dewalt nailer quit working
O ring or stuck pin valve. Id check here for more info DEWALT com
Aug 15, 2015 | Dewalt Nailer. 1 in. - 2-1/2 in. 16 Gauge...
Dewalt 51256 finish nailer, 16 gauge. Shoots two brads at same time. Using Porter 16 gauge brads. Any suggestions
Replace the trigger valve part # 647956-00 to solve this problem. If you have access to very small orings (2mm x 1.5mm), try replacing the two orings on the trigger valve stem. Dewalt uses vinyl orings on the trigger stem and they fail causing malfunction. Easy fix however and not expensive . Good luck
Feb 24, 2014 | Dewalt D51256K 16 gauge finish nailer kit
I have a dewalt dc618 finish nailer When I go to shoot the lights on the gun start to flash and will not shoot ?
Continuous flashing indicates low battery charge or poor battery connection. If lights flash 4 or 5 times indicates possible control module fault.
Oct 28, 2013 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Dewalt dc618 wont fire
firstly its always better to change both of the bands even if one is broken this always keeps the drive trim.all seems well clean all the contacts ie battery and gun (do not use any cleaning products this will cause grease)just wipe clean with paper towel.
Nov 11, 2012 | Dewalt DC616kn 18 - volt 16 - gauge...
Describe your 2 - 1/2"
Not sure what you question is however Porter Cable and Bostitch are now part of Dewalt. Parts and owners manuals as well as other documents are available at the web address below.
http://servicenet.dewalt.com/
Aug 24, 2011 | Porter Cable 2 - 1/2" 15 - Gauge Angle...
When battery gets plugged in lights come on but nailer wont fire
Does the motor run but does not fire a nail? If this is the case chances are the belt came off the flywheel. This is one of the most common problems when these will not fire.
If the headlights go on but the motor does not run it could be a bad switch or contact trip.
This a PDF of the owners manual, Page 9 had some trouble shooting tips. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/644429-00,DC612.pdf
This is an exploded view of the tool http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=34790&typeId=9472&documentId=23898
From www,dewaltservicenet.com you can get the contact info for you local Factory Service Center if needed.
For safety remember to always remove the battery when performing any service to this tool.
Oct 10, 2010 | Dewalt DC616KA 18 - Volt 16 - gauge...
Nail gun wont fire
First - the air pressure has to be high enough - check the regulator on the tank to make sure it is delivering in excess of 60-70 psi (which I am sure you have already done).
If you have dry fired these guns (i.e. shot them off with no nails in them while you were lubricating them maybe) the mechanism inside could be damaged. I had that happen to one of my nailers (same brand). That was when I learned not to dry fire them...
Since both of them are not working though I would be more inclined to look at the air supply first.
Jun 05, 2009 | Dewalt D51256K 16 gauge finish nailer kit
Gun failure
bertobryan45
Have you been lubricating it regularly with nail gun oil. We use framing nailers every day at the commercial tree farm I work at and one of the operating instruction is to put 6 to 8 drops of oil in the air hose connection on the nailer before every use. I suspect the O ring on the piston is worn out/
Hope this helps Good luck Loringh PS Please leave a rating if appropriate Thks
Nov 15, 2008 | Dewalt D51256K 16 gauge finish nailer kit
I have the above dewalt gun just its battery powered, and it doesnt fire the nails
if the nailer is for 18 guage nail use 18 gauge nail if not 16 guage will jam. if it is not the problem is the profile return asyy may jam in side.
Sep 18, 2008 | Dewalt DC616kn 18 - volt 16 - gauge...
Tools & Hardware - Others Logo
1,079 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
