Re: My sd card slot on my acer aspire 9300 is not...
It sounds like you need a new driver for it search for one online but make sure you know what make and model of card reader it is, this is probably harder to find out as it is inside the computer
If the correct driver is installed, you should be able to go to my computer, double click to open , and your SD drive should be listed. If not, let me know and we can troubleshoot.
Take a can of air and blow some into the slot to make sure dust or dirt isn't getting the way of that reader trying to read the sd cards.
If you still get the same message try another SD card in that reader or try to see if another computer will read your SD card, if another computer will read the SD card and the slot still won't recognize the sd cards properly, then you know at that point the reader is bad. If the reader is bad, thats integrated into the motherboard so the motherboard would need to be replaced.
Try to put your sd card to the slot, and check device manager.
check if there is yellow question mark on the device manager.
if it is, it's driver problem, just update the driver.
if not, try with another sd card and if this still not working, it's your sd card slot has problem.
Just choose "drivers and downloads" Then "notebook" Then "Aspire 9300"
On the right window, you will see available drivers. Once you highlight each one, you will see what operating system it is for in the "download details" window.
Your computer doesn't support compact flash cards. Your SD slot is a 5-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), Memory Stick® (MS), Memory Stick PRO? (MS PRO), xD-Picture Card? (xD). The big slot is for PCMCIA devices.
