Question about HP Office Equipment & Supplies
How do I find what the lights mean on the hp color laserjet 250L
5 Suggested Answers
  • 134 Answers
SOURCE: HP Color LaserJet 2550n
Are you using generic toners or HP branded? Try to reseat the yellow toner. The page counter can't be reset and should not be. This unit uses chips to recognize the toner level. Generic toners don't always have good chips on them.
Posted on Jul 09, 2008
mdsaeed67
  • 849 Answers
SOURCE: Hp color laserjet 2600n ''black print down form its orignal place''
an allignment need to perform on printer with proper placement.
Posted on Nov 27, 2008
pdouglasss
  • 125 Answers
SOURCE: Very Light Printer on HP Color LaserJet 3500
Table 7-33. Causes for distortion or blurring
Cause Solution
Transfer unit is defective. Replace the transfer unit. Calibrate the printer
after replacing the transfer unit. See Calibrate
Now, later in this chapter.
Defective secondary transfer roller If it does not rotate smoothly or it is deformed,
replace the secondary transfer roller.
DC controller PCB is defective. Replace the DC controller PCB. Calibrate the
printer after replacing the DC controller. See
Calibrate Now, later in this chapter.
Calibrate Now
Use the following procedure to calibrate the printer whenever you replace the DC controller,
the formatter, the color misregistration sensor (PS12), the transfer unit, or the laser/scanner.
1. Press to enter the MENUS.
2. Press to highlight configure device.
3. Press to select configure device.
4. Press to highlight PRINT quality.
5. Press to select PRINT quality.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
hope this helps
pdouglasss
Posted on Jan 10, 2009
  • 468 Answers
SOURCE: HP Color LaserJet 3800n with 49.4C02 Error. What
Try to switch different drivers PCL5e driver or PCL6
Posted on Nov 06, 2009
Hp laser jet 300/400 10.1000error
10.10 error means it does not recognize the chip on the cartridge or that the seal is still in cartridge need new cartridge
Feb 24, 2015 | HP LaserJet Pro 400 color M451dn - Printer...
A light is flashing next to the yellow dot??
Make sure you don't have anything qued up in the printer, flashing usually means something is printing...
Jan 20, 2011 | HP Color LaserJet 2550n printer + HP Color...
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
Paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Mar 01, 2010 | HP Laserjet CM 1312NFI Color Printer
Green horseshoe light is continually lit
If it is solid on, it means the printer is ready to print; no action is required. If it's flashing, it means the printer is processing data and should print soon.
If you are printing from your computer and nothing comes out, with the "Horseshoe" light staying solid, I suggest checking the connection between your computer and the printer, or at least the printer configuration. Most of the time, unplugging, then plugging cables back in does the trick.
Jul 06, 2009 | HP Color LaserJet 2550n printer + HP Color...
Drum Light On
You will need to replace the drum soon. It can be purchased directly from HP here: http://www.shopping.hp.com/supmodel/product/Q3704A%2523ABA?jumpid=in_r329_search//laserjet+2550n_Q3704A
Or, you may be able to find it cheaper in Google. Type in "Laserjet 2550n drum" and see what results you get.
Mar 25, 2009 | HP Color LaserJet 2550n printer + HP Color...
Nov 27, 2008 | HP Color LaserJet 2600n Printer
The printer keeps saying ''choosen personality not available''
This means the printer encountered a request for a personality that did not exist in the printer. The job is cancelled and no pages are printed. You need to try a different printer driver.
According to the HP manual: "For the HP Color LaserJet 3600 Series printers, you must use HP JetReady 4.2, the driver that was specifically designed for these printers."
Nov 12, 2008 | HP LaserJet 3600dn Printer
179 people viewed this question
Seeker5211
Seeker5211
