Question about Garden
The pull start needs rewinding, the pull start came lose and goudged a groove in the fly wheel.
  • dontbother10
    dontbother10 May 11, 2010
    We need the make, model, and serial numbers from the manufacturer?s tag to help you further. We also need to know if it is European.
  • srbaloy May 11, 2010
    what type of saw
    President:
  • 2,220 Answers
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Posted on Sep 20, 2009
My craftsman 190cc 625 series lawn mower stopped and a friend said that there is a pin that drops when the mower blade gets caught and stops, I'm really in need of help on how to get to the pin if possible...
Wow it's a lot of work it's called the fly wheel key that is sheard. In every case like this you have to make sure you remove the spark plug or uncap the spark plug. Remove the pull cord assembly and then use a pipe or wooden board to keep the blade from moving underneath the mower. VERY VERY IMPORTANT TO USE A CLAMP TO HOLD DOWN THE CLUTCH BRAKE AND DO NOT REMOVE IT TILL YOUR FINISHED OR YOU'LL BRAKE OFF THE BRAKE FOOT ON THE LEVER. Use a breaker bar to remove the bolt holding the fly wheel down. Now here is the hard part. The fly wheel is made of aluminum and can brake easily as well as the fly wheels blades. If it cracks or the fly wheel blade is cracked or broken it's junk. If you don't have a Briggs and Straton puller you can use a lug wrench and pry the fly wheel up. You must first place the nut back on the 1 inch bolt on the center shaft so the threads are not showing at the top of the drive shaft. You have to hit the nut on the center hard but not like to hard to brake anything. After you get the fly wheel off you have to use the model and serial number to get the key from a lawn mower shop. Place the key under the fly wheel and very carefully watch to see if it lines up as you push the fly wheel down. Push it down from side to side so it fits flush. Tighten the bolt. Don't start it first see if when you pull the pull cord it moves with out pulling the rope back into the mower. You'll have to make sure the top bolt is tight like maybe 60 pounds. MJ
Sep 29, 2014 | Garden
Why does my chain saw lose power and shut off as soon as it gets hot.can't restart until it cools off.
Check coil pic up or the electrical pick up in the pull string housing. Remove that and u will see the fly wheel next to that is the electrical pick up .look at fly wheel make sure magnets are clean surface ,they are in the fly wheel itself.after that remove coil and clean surface that faces fly wheel. Using a match book cover place it between fly wheel and coil ,make sure it moves but not falls out snug ,tighten coil screws and remove match book cover. If it dose it again re place coil look for small engine shop in your area and the can help get u a new one .weak spark means coil,sparkplug
Sep 15, 2014 | Poulan PP4218AV 18" Chain Saw
How do I change fly wheel key
You need to pull the blower housing off. Then remove the the starter cup from on top of the flywheel. Pry off the flywheel usually by insert a prybar under the flywheel pulling up while tap on the side of the flywheel. you will see the key in the center of the flywheel. after removing the old key, replace flywheel then insert key into grooves after you line the two grooves up.
Jul 11, 2014 | Poulan Garden
VIKI PR-GS5200 - I need to rewind the pull cord so it will work
It maybe the return spring behind the pulley has broken, be very carefull when removing the pulley as the spring can easilt fly out, new springs are in keepers so are very easy to fit.
Feb 29, 2012 | Garden
I have a 6 hp self propelled Craftsman mower with
Ok this may be a simple fix. it has a high chance that the fly wheel key has sheared, this will cuse the timing to advance and bite your hand with the rope.
remove the pull starter and the cup ontop of the fly wheel, if you look straight down at the fly wheel nut you can see a cut out in the crank and fly wheel they should be aligned up if not it has sheared. use a lever under the fly wheel and put some pressure on to to lever it up then hit the fly wheel oposite side of the lever AWAY from the the magnet. and the fly wheel should pop up. replace the key and of you go..Make sure you use the OEM brigbs and strat key it is made out of alloy. The cause of this is the blade hitting a kerb or somthing hard,
Jul 02, 2010 | Garden
The fly wheel had A tooth missing, so i changes th...
OK go to the starter and pull on the smaller red wire. This is a fusible link and can look good while you are pulling id the wire give you will need to repair it remember the wire can be burnt inside of the cover and you will not know it until you pull on it
May 14, 2010 | Cars & Trucks
Grinding sound when trying to start
lose starter or worn teeth on starter or fly wheel if motor doesn't turn over cylinder could be full of water from blown head gasket pull spark plugs to see if water comes out
Mar 02, 2010 | 1996 Jeep Grand Cherokee
Poulan pro 18" saw locked up.. help
some thing desperately wrong here, if this is happening with recoil starter off the machine then the next step will be to whip the head off,but before you do that take take the cover and chain and bar off ,the centrifical clutch may be breaking up, let me know i am interested to know what is going on
Aug 15, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I want to change the pull crd on my 6.5 hp craftsman lawnmower
remove the engine shroud. Pull the cord all the way out. Put a screw driver into the fins so it does not unwind. Cut new cord and install through hole in shroud and the rewinder. Reattach handle to cord and hold onto rope and pull screw driver out. Slowly let cord rewind. Pull a couple of times to make sure it is working. While engine shroud is off us a piece of emery cloth or fine sandpaper to clean off the magnets on fly wheel and the two little prongs close to the fly wheel.
Good luck let me know if this helps.
roundo4
Aug 14, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Pull cord came undone
sounds like the spring might have broken. Sometimes they are a pain to rewind. Might want to see about a new pull assembly. But first take off the shroud to see if the little pieces of metal or plastic that engages the assembly on top of the fly wheel are ok. If so untie the cord to the hand hold and remove rope from the pulley inside. Then turn the pulley a couple of times and let it go(but watch your fingers). If it spins pretty fast then turn it again till you get some tension and I put a screwdriver through the fins so it doesn't unwind (but line up the hole where the line goes through first) then put the line through the holes and tie a knot. Then pull out the screwdriver and slowly let the line rewind. If it rewinds reassemble and it should work fine for you.
Let me know if this helped.
Thanks
roundo4
Aug 01, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
176 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
