J
Joe Rampulla Posted on Dec 17, 2015
Why can't I stop alarm and power buttons from flashing?
I bought a watch for my grandson. It had no instructions. It is from China MFG# FMDAW549. Are there directions available
Possibly these instructions:
http://forums.watchnet.com/index.php?t=tree&goto=110449&rid=0
DIGITAL WATCH USER INSTRUCTIONS May 27, 2006 - 05:59 PM On 5/26/2006 I bought from Walmart a $6.43 watch, on the back of which is written "AH 1175, 52, Battery CR2025, China Module, FMD, Base Metal Bezel, Stainless Steel Back, 100ft Water Resistant". It has no control buttons on top (where buttons may be accidentally pushed), the display is larger and more visible, and the color is dark, so I bought it even though I prefer models that have a fabric/velcro wrist-strap.
Four buttons on this watch are labelled: Light, Mode, Reset, and St/Sp. The instructions which I found inside its container refer to the Light button as A, the Mode button as B, the Reset button as C, and the Start/Stop button as D, but otherwise do not pertain to the watch, so I determined the button's functions by trial and error, as follows:
TO SELECT THE DISPLAY MODE
Push the Mode Button in order to select one of the following four display modes in the following order: Normal Time, Stop Watch, Alarm Reset, Time Reset.
In the Normal Time Mode, the Day of Week, the Hour, Minute and Second are displayed (none flash). If the Alarm and Hourly Chime icons are not displayed, the Alarm and Hourly Chime are turned off.
TO DISPLAY DAY OF WEEK, HOUR, MINUTE, SECOND AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
Push the Mode button until no icon is flashing. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed beside the Second display.
TO DISPLAY THE DAY, MONTH AND DAY OF WEEK AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
In Normal Time Mode, push the Start/Stop button. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed.
TO DISPLAY THE ALARM TIME
In Normal Time Mode, push the Reset button. The P or A beside the Alarm Time indicates PM or AM time. The P or A below the Alarm Time indicates a 12 hour clock; an H indicates a 24 hour clock.
TO STOP/START THE ALARM AND HOURLY CHIMES
In Normal Time Mode, hold the Start/Stop button down and push the Reset button (the Date and Day of Week will be displayed) to turn the preset Alarm and Hourly Chimes on, or off (to save the battery). To test the alarm, hold the Reset button down. The alarm and chimes are off when the alarm and chimes icons are not displayed.
TO STOP THE HOURLY CHIME
In Normal Time Mode, hold down the Reset button (the Alarm Time will be displayed) and push the Mode button until the Day of Week display is no longer highlighted; otherwise the hourly chime drains the battery.
TO SET THE TIME
To Fast/Forward until the correct number is displayed, hold the Start/Stop button down.
To set the Month of the Year, select the Time Reset Mode and push the Reset button until the Month of the Year number flashes; push the Start/Stop button until the correct Month of the Year is displayed and push the Reset Button.
To set the Day of Month, select the Time Reset Mode and push the Reset button until the Day of Month number flashes; push the Start/Stop button until the correct Day of Month is displayed and push the Reset Button.
To set the Day of Week, select the Time Reset Mode and push the Reset button until the Day of Week display flashes; push the Start/Stop button to until the correct Day of Week is displayed and push the Reset Button.
To set the Hour, select the Time Reset Mode and push the Reset button until the Hour number flashes; push the Start/Stop button until the correct Hour is displayed and push the Reset Button. For a 24 hour clock, push the reset button until an H is displayed. For a 12 hour clock, push the reset button until an A or P is displayed.
To set the Second, select the Time Reset Mode and push the Reset button until the Second number flashes. The Second number resets to Zero everytime the Start/Stop button is pushed. If the Start/Stop button is pushed as soon as the Second hand on your computer and watch are the same, the watch will be accurate to one second (to set your computer time to the second, log on to the Internet, right click on your PC's time display, select ADJUST DATE/TIME, INTERNET TIME, UPDATE NOW). The setting of the Second number will not be affected by setting the Minute number afterwards.
After the Second number is set, set the Minute number by selecting the Time Reset Mode and pushing the Reset button until the Minute number flashes; push the Start/Stop button until the correct Minute is displayed and push the Reset Button.
TO SET THE ALARM TIME AND TURN ON THE ALARM
Choose the Alarm Reset Mode. The alarm is turned on everytime the Alarm time is reset.
To select the Hour, push the Start/Stop button while the Hour is flashing and until the correct Hour is displayed, then push the Reset button (the Alarm and Hourly Chime icons will appear).
To select the Minute, push the Start/Stop button while the Minute is flashing and until the correct Minute is displayed, then push the Reset button.
Push the Mode button after the correct Alarm Time has been selected. The Alarm and Hourly Chime icons will be displayed beside the Second numbers.
The P icon indicates PM. The A icon indicates AM. The H icon indicates a 24 hour clock.
TO USE THE STOP WATCH
Choose the Stop Watch Mode. Push the Start/Stop button to begin the lap time. To pause the Stop Watch push the Start/Stop button to stop it and push it again to continue. To reset the Stop Watch to zero, stop the lap time by pushing the Start/Stop button, then push the Reset button (otherwise the Stop Watch will continue counting after other Modes are selected).
Apr 20, 2018 • Watches
2answers
1helpful
Alarm light flashing
First I would manually push (force) a A4 sheet transparent piece of perspect plastic through your printer. It needs to be thick enough so it does not bend but not thick enough to fit.!!
A very light smear of vasoline or petroleum jelly (very light) will pick up and remove and debris in your printer.
Then hold you finger on the alarm (resume) button for as long as it takes for the lights to stop flashing.
Error 5100 on/off flashing and alarm flashing
Hello
Remove the error code 5100 1. Turn off printer. 2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color. 3. let go button Stop/Reset, continuing to hold POWER. 4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons. 5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key) 6.turn off printer by POWER button, then turn on. 7. You should be set. If it didn't work, try it again, slowly. It WILL work!
Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
2helpful
How do you set the time?
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "ST./STOP" button on the watch.
Jan 13, 2010 • Watches
16helpful
3answers
My Canon Pixma MP170 printer is showing error code 5800, What must i do to fix this?.
MP170 (5b00) Ink Tank Full Error Reset
1,power off.
2,hold stop/reset ,hold ON/OFF
2,release stop/reset, push stop/reset twice, quickly, then release ON/OFF
3,wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
4,then push power twice, quickly
5,power off and power on.
1helpful
Setting alarm
Alarm can only be set or disabled when the power in "Standby" mode. The manual refers to it as power "off" mode, but the LCD display will still be readable only darker. To set the alarm push the Standby button until the sound stops and the LCD is dark. Then push the AL SET button (which doubles as the volume down button when the power is "on"). The hour should start flashing. Adjust the hour by using the two buttons at the bottom on the right side just above the IR sensor. Once you've set the hour, push the AL SET button again and similarly adjust the minutes until you have the right time that you want the alarm to go off. Now push the AL SOURCE button (which also doubles as the function button when the power is "on") to toggle between Radio, CD, iPod or buzzer for your alarm. After you're satisfied that the time is right and the source is right push the AL SET button again. The LCD should still be dark, but should also show the word "ALARM" in the upper left hand corner.
To set the unit so the alarm doesn't go off push the "Standby" button until the sound stops and the LCD is dark. Push the AL SET button until the hour is flashing. Don't bother to adjust the time, just push the AL SOURCE button until none of the following appear: CD, iPod, Radio, Buzzer. As you push the AL SOURCE button it will toggle between these options. Once you're sure none of them appear on the left of the display, click the AL SET button again. The LCD should still be dark, and you should not see the word "ALARM" in the upper left hand corner.
62helpful
13answers
Prospirit watch
in order to SHUT OFF THE ALARM:
go to the normal time setting, where nothing is flashing. then press and hold reset. then the time you want the alarm on shows up. in order to turn the alarm off press start...press start again to turn it on
May 15, 2008 • Watches
1helpful
ALARM!
make sure printer connect to power source/cable power then
press power button while press stop button,release stop button while still press power button.
press stop button twice and release.
after power button stop blink press stop/resume four times then turn off printer.
Alarm
Alarm Setting:
1st: Press the mode button to go to the alarm screen.
2nd: Press the adjust button for the time to flash
3rd: (For the Hourly Alarm) You can adjust the time here while it is flashing by pressing the start/stop button. Cycle through this until you have the time you want. The setting will have the P in the left side of the screen for PM (night time).
4th: (For the Daily Alarm) Do steps  1-3 once the time is flashing use the Mode button to cycle through to the date field of the watch. Once it is flashing you can use the Start/Stop Button to chose which date Month/Day, after chosing the month just press the Mode button once more to go to the day field.
k24674
ADMIN Andrew
ADMIN Andrew
