Question about KitchenAid Superba KFRS361TSS Stainless Steel Propane Grill
Kitchenaid superba side by side refrigerator over temperature...
I have the same issue.  The over temperature reset keeps beeping and the temperature keeps getting warmer. We left for 10 days all of our food has gone bad.  If you have the same problem and need to leave for more than few days, make sure and take all of the Meat and junks out of your refrigerator.  And get it fixed after you return from your trip. You dont want to know what a 10 day old spoiled meat smells like. (trust me) I have a technician coming this afternoon to take a look at the problem.  I will update you guys on what is wrong and will tell you the solution this afternoon.
I think I may have the solution, after having suffered through the same problem for months. I have a Kenmore Elite side-by-side which is really the same as KitchenAid and Whirlpool. Having thought of complicated solutions first, I have finally gotten back to step 1, simple solution. Tape the switch on the top of the freezer compartment and see if that works for you. I believe the door while seemingly closed is not pushing the switch in far enough. If that works for you, you can probably glue something to the top of freezer door so it can push in the door switch a little better. The reason that it beeps is that the switch is not pushed in enough and the light is still on inside while the door is closed. The refrigerator then thinks the door is still open. I really hope this works for you as I can sympathize with you having listened to the beeps for months. I feel sorry for people who have changed one circuit board after another to no avail. And there are so many stupid repairmen out there offering dumb advices and perform needless repairs.
Posted on Jul 16, 2009
Kitchenaid superba ksra22fkss00 side by side fridge. The freezer temperature too cold.
Even though the freezer thermistor passes the test, it's bad. The test only sees if the thermistor is open circuit or grounded. These thermistors can send bad information to board. Replace the freezer thermistor and I think that will solve your issue. Good Luck
Aug 27, 2017 | KitchenAid Refrigerators
Control lights are out
If the unit is dead and there are no lights or cooling, you will need to replace the control board on the back of the refrigerator. Here is the part you need.
Oct 21, 2012 | KitchenAid Superba Architect KSCS25INSS...
My Kss048fmx refrigerator is beeping
Usually when a refrigerator is beeping it is due to the door being ajar or something caught in the seal or lastly a fault in the electronics which is rare but possible. It could also be due to the hinges being worn and being warped as well due to weight put on the door over an amount of time. Is it consistently beeping? How many times is it beeping? If you push the door closed completely does the beeping noise stop? I await your reply.
Thank you,
Rick
Jul 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
Over temperature alarm on KitchenAid Superba Refrigerator
Remove the screws from the bottom grill cover. Use a vac brush to clean out that area. You should also pull the frig out from the cabinet and vac behind.
Also, you can go on kitchenaid.com and download a product manual to replace your lost manual. Click on customer care and select "Locate Manuals & Guides."
Mar 31, 2009 | KitchenAid Superba 21.6 cu. ft. Top...
Beeping or Chirping
probalby not relates, but the beeping is ususally accompanied by an indicator light as to why its blinking, perhaps the door open alarm???
Mar 28, 2009 | KitchenAid KSCS25FKSS Side by Side...
Over temperature reset button keeps ringing and blinking
I called the KitchenAid customer support number. Found out that control goes off when the temperature of the fridge is above 48 degrees (i.e., over a few days, the food would be spoiling). This is not the case for ours, since everything seems to be working fine. They said there is probably something malfunctioning with that button/control, and there is no manual turn-off mechanism. We have to call someone to come and fix it.
Jan 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
Over tempature reset keeps beeping
its registering a warm temp, you reset it but when it checks again in 2 hours or so its still seeing a warm temp whichi s why the alrm is going off, id look at the contents of the refrig for signs of defrosting, icecream not hard enough, ice maker not producing and melting, moilk spoiling premature, butter too soft.
Nov 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Freezer not freezing completley
sounds like you might have a sealed system issue(ie.compressor, sealed system. check your user guide for warr inf you might stil be covered by manufacture for this issue
Jan 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba refrigerator not keeping cold
press reset botton for five times and it will reset kiki
Oct 12, 2007 | Refrigerators
KitchenAid Superba KFRS361TSS Stainless Steel Propane Grill Logo
1,077 people viewed this question
Top KitchenAid Grilling Experts
Paul Carew
Paul Bade
Bill Boyd
Are you a KitchenAid Grilling Expert? Answer questions, earn points and help others
