The clock is not working, but the back light still turns on. I've got the panel over the interior fuse box off, but can't figure out which fuse will fix my issue! Any help?
There will not be a fuse that is isolated only to the clock. If the clock is the only item that is not working the problem with the clock will not be fixed by replacing a fuse. The back light on the clock is working so you are getting power to the clock itself.
(In any event the fuse locations for various functions are covered in your owners manual. If you don't have one then get on to one of the G35 forums and offer to buy one. It's important to have the details of where all the fuses and relays are for various functions.)
SOURCE: glove box light and visor mirror lights are out
Are your headlights turned on? My visor mirror lights only work when the headlights are on.
SOURCE: Service engine soon light
in your manual inside your glove box it will tell you how to restet the service due soon message, or the mechanic should do it when he/she services your car.
SOURCE: change belts on g35
Here is a DIY (Do It Yourself)
http://forums.nicoclub.com/zerothread/342311
Loosen the bottom 2 bolts that loosen the belts, take off both belts, put new belts on, tighten the belts to specifications. Done.
SOURCE: Infiniti G35 trunk won't open
I had this problem as well.
The wiring harness in the trunk is a bit short and some of the wires fray. when this happens, the car doesn't recognise that the fob is close by so it fails to open.
Just pull back the boot near the trunk hinge on the passanger side and look for frayed wires.
SOURCE: where can I find 2005 infiniti g35 fuse box
There are 3 fuse location. One next to your feet, second next to the battery and the 3rd one behind the battery.
