Question about Dishwashers
It is not filling up with water enough to dissolve the soap pack or clean dishes properly
  • 297 Answers
If this is a new washer you must prime by hand first. meaning put some water in by hand first,about 1 gallon.
Posted on Jul 14, 2009
Samsung DW80J7550US not filling with water, strange noises, leaving dirty dishes
Just answered a similar question. Check the float switch at the bottom of DW. There should be a float switch that can be pressed down and should pop up. It should have a cap that can be removed to clear any debris. The switch monitors how much water is used so that it does not flood.
Sep 18, 2017 | Samsung Dishwashers
Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Dishes are not clean, soap is not dissolving, we have tried several brands
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 23, 2009 | Maytag MDB9600A Jetclean II Built-in...
Does not cleans dishes
Hi
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
Hi our dishwasher goes through its cycle but does not dissolve the powder blocks and does not clean the dishes
Hi
Thanks
Rylee
Nov 09, 2009 | AEG 18 in. Favorit 54750Vi Slim-Line...
The dishes especially on the top are not cleaning. Soap doesn't completely dissolve. Not rinsing clean?
sound like plugged spray arms or not proper water fill when the starts is there proper water in the tub if so cancel it and start again if the valve fails to fill again at least 3 times in a row then the valve is bad and the winding make contact after it cool once for one fill and fails through out the normal wash cyc
Sep 01, 2009 | Whirlpool Dishwashers
Dishwasher
I have seen this problem before on a couple of dishwashers.
How are the dishes doing? Are they coming out clean, or do some of them "fail".
If you rinse the dishes before putting them in the dishwasher, it may be hard to detect "failure" to clean. Try not rinsing the dishes once and run them through a cycle. My guess is that the "failure" rate will be high.
The problem I have seen is that the dishwasher water input filter is either clogged or the water-full sensor is "telling" the unit that there is enough water in before it actually fills properly.
So, some water can get in, but not enough to properly wash the dishes and dissolve the soap.
On the appliance repair sites they have parts breakdown details and what you are looking for is an input valve assembly -- the point just after the water line connects to the dishwasher.
Now the valve may be OK, but the feedback system could be bad.
(On a Bosch dishwasher the valve IS the feedback system and the filter.)
Any filtering or "water full" signal will feed back to that valve.
If you get inside that front lower panel, be sure to turn the electricity off first 'cause if you get crosswise in that area you could end up with a 'shocking' experience!
good luck
May 09, 2009 | Dishwashers
Dish washer not filling
I had the same problem. It was a clogged water inlet valve. Packed with sediment. Accessible from the bottom if you have the right tools. Just clean out and replace. Or the valve could be bad.
Apr 10, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwasher detergent does not dissolve entirely. Gel is still on side and powerball tabs doe not dissolve. Dishes are not clean. It sounds like it goes through the cycles properly.
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Dec 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
