Question about Garden
Have a Remington 10" pole saw. mod. 106980-01. type LN1-2. Need new screw cap and bulb for chain oiler.
    President:
  • 1,124 Answers
You should be able to find it hear ---
--> ttp://www.msservice.net/desa/remington.html
Hope this helps !
rate me good ;o)
Posted on Jul 14, 2009
Remington manuals
For an electric saw, just add oil to the chain oiler, plug it in, and cut away. Do not put any body parts in contact with any of the moving parts of the saw.
Sep 02, 2014 | Remington 10" Electric Pole Saw Chain...
Remington electric Pole Chain saw - what type of oil do I use?
SAE 30 motor oil if the temperature is between 30 & 75°F.
-Colder use SAE 10 oil.
-Warmer use SAE 40 oil.
take a look on amazon: Amazon com SAE 30 motor oil
Apr 24, 2010 | Remington Electric Pole Saw
Doesthis thing need oil or some other liquid type
The bar and chain require bar oil (only) to be placed in the capped tank. The motor itself is air cooled, and should be blown out with compressed air often to remove the accumulated sawdust. Make sure the chain is tightened just enough to prevent the lower part of the chain from drooping from the bar and can be turned by hand. Make sure to keep the chain teeth sharp by properly filing for best cutting. Test the chain oil pump operation by running the saw with the chain tip near a piece of cardboard--it should throw off a thin line of oil after a moment or two of running. Hope this helps!
Apr 05, 2010 | Remington Electric Chain Saw
Need new chain for remington pole saw, model 106890-02, part # 091371-03s[ 10" bar, 25.4 cm chain ]. lowes has replacement 10", 25 cm chain for remington pole saw # 106821, cant find that model anywhere,...
It should, I have been on this earth to long for a definate answer. Both saws have 40 drive links, are 3/8s, and a gauge of 0.050. Please verify my findings here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Have you contacted a local saw shop? With your chain as a pattern they can make a replacement in couple of minutes. Inquire by phone about a price you may be pleasantly surprised. Give them Oregon number 91VG040G (low kickback, most likely what your saw is fitted with). If you feel adept you might try a slightly more agressive chain but the odds of kick back increase. HTH
Lou
Feb 06, 2010 | Remington Polesaw Wizard
Where can I find a bar & chain for a remington
You provide no model number for your saw. What is pictured is a RPS96.
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" (RPS96) into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
There are 8, 10, 12 and 14" chains on the IPB depending on the actual model pole saw. RemingtonPower is no longer in production, and parts are often difficuilt to find. All 4 chains listed are available and range form $12.92 to 15.95 plus shipping and handling. You can take your saw (or just the chain) to a local saw outlet and have one fabricated in about 5 minutes. It is rarely more expensive at a local outlete and you save shipping and handling fees. HTH
Lou
Jan 25, 2010 | Remington Polesaw Wizard
I have pole saw model 108526-01 I need a new chain and a cap and bulb assembly where can I get these parts?
The good news is:
Your manual containing a parts list can be found here:
http://lawnandgarden.manualsonline.com/manuals/mfg/remington/100089-04_5.html
There is an IPL near the bottom, please save copy to your hard drive.
The part number for the oil cap & bulb assembly is 107319-02, I found it here:
http://www.remingtonpowertools.com/products.cgi?cat=11
I make no guarantees about availability. If you take the existing chain to a local chainsaw seller/mechanic they can almost certainly use it as a pattern to make a new chain
The bad news is:
Remington Power Tools have ceased production. Parts availability is limited to what is on hand. I recommend rather than purchase parts for this discontinued brand you put the funds toward the purchase of a new saw. Poulan offers 8 different electric models, have been in business for a very long time and are a subsidiary of Husqvarna. HTH
Lou
We can provide no further help for your saw.
Oct 08, 2009 | Remington Electric Pole Saw
Chain fell off chain saw remington 10" pole saw, need directions to put back on.
Look from the side of the saw the motor/engine to left and the bar nose to the right. The thinnest part of the chain (sharpened edge) on the top of the bar is to the right.
Sep 26, 2009 | Remington Electric Pole Saw
Does my remington chain saw model #m15014AS go with the remington ext.pole model #rps96
No, the largest electric pole chain saw that can be attached to a pole with the Remington Pole Saw kit, is a 10" saw.
You can go to Master Distributors to find out more detailed info about your situation and speak with one of their reps.
http://www.remingtonchainsaw.com/
Hope you found this very helpful, best regards!
Aug 07, 2009 | Remington Electric Chain Saw
Lubrication
The cap on top with the bulb, screws off. Use bar oil. Give the bulb a pump every 30 seconds of operation or so. This will keep your chain and bar lubricated.
Regards, --WoobieDog--
Jul 10, 2009 | Remington Electric Pole Saw
Remington Pole Saw Model # 106890-020 - Chain Oil Cap broke
Call Master Parts at 1-800-446-1446, or go online at www.masterparts.net. They have the part (107512-01) you need. I hope this helps...
Apr 26, 2009 | Remington Electric Pole Saw
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
