Question about Panasonic KX-TG1033S Cordless Phone
Model KX-TG7432C The main base unit keeps beeping (ABOUT EVERY THREE MINUTES) I am currently trying to recharge the batteries on this unit. it seems very slow, could new batteries be the answer (this is bran new unit from Staples, Pitt Meadows B.C.
SOURCE: Panasonic KX-TGA101S base not charging.
PyroPC Man is right! Thanks!
Posted on Mar 18, 2008
  • 3 Answers
SOURCE: Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
Posted on Aug 13, 2008
SOURCE: Panasonic base unit went dead
THROW IT AWAY.  I HAVE THE SAME PROBLEM AND PANASONIC AFTER SALES "SERVICE" PEOPLE  HAVE BEEN COMPLETELY USELESS!
Posted on Mar 23, 2009
SOURCE: No KX-TGA101S communication with KX-TG1033S
The additional handsets must be registered to the base unit. Here are the instructions from the manual:
HANDSET
1. [menu}
2. "handset settings" - OK
3. "Registration" - OK
4 "HS registration" - OK
BASE UNIT
Press and hold [LOCATOR] until the registration tone sounds.
-if all registered handsets start ringing, press {LOCATOR] to stop, then repeat this step.
-after the base unit beeps, the rest of the procedure must be completed within 1 minute and 30 seconds.
HANDSET
Press [OK], then wait until a beep sounds and Y stops flashing.
Posted on May 05, 2009
jse2005
  • 103 Answers
SOURCE: I have a KX TG2356 cordless, when I hang up the
typical fault is bad or no connection between charging terminals and hand set charging terminals...try to clean them using emery cloth or fine sand paper....sometimes even though the contacts look clean they still have bad connections because of an oxide layer that builds up....that oxide layer can easily be taken off with a light sanding......if that doesn't work, then have your hand set checked for internal open solder lines or regulator circuitry faults that regulates power feed to the battery to monitor charging status...
good luck
silvio
Posted on Jul 08, 2009
I charged my KX-TGA652, it keeps saying use rechargeable battery. Does not seem to hold charge
It does take rechargeable batteries. Remove the back and change batteries for Ni-cad or similar rechargeable batteries. Trying to recharge normal batteries is dangerous. Any rechargeable make of battery will normally work and they recharge when phone is in cradle
Feb 21, 2015 | Panasonic KX-TGA652B Cordless Phone 2 Pack
Why five rapid beeps and screen saying "charge battery"? I had turned on and was charging, and 1 day later phone off and charge gone.
The batteries are defective, your local supermarket should have rechargeable batteries or try an online auction site, look for the highest 'mah rating you can get something like 2800mah, the higher the rating generally the longer the battery will hold charge
Sep 25, 2014 | Panasonic KX-TD7896 Cordless Phone
Have new headset, why is the base unit keep beeping at me
Here is an explanation of the beeps you are hearing:
• One beep every 10 seconds is caused by a low battery
warning. Recharge battery by returning it to the base charge
cradle for one to three hours until charge light stays lit or
quits blinking.
• Two beeps is an out of range warning. Move closer to the base.
• Three rapid beeps every 30 seconds indicates your mute is
on. Press the mute button once to turn mute off.
• When an optional lifter is connected, three repetitive beeps
indicate a call is coming into the headset. Press the call
control button on the headset to answer the call.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
May 19, 2011 | Plantronics CS70 Wireless Headset
Phone keeps saying move closer to base
The handset may have unregistered from the phone. The instructions to reregister it are in the manual, but I'll list them here for you.
1. On the handset, press MENU 001
2. On the base unit
For models KX-TG6021/KX-TG6022/KX-TG6023
Press and hold LOCATOR until the IN USE indicator flashes.
For models KX-TG6051/KX-TG6052/KX-TG6053/KX-TG6054
Press and hold LOCATOR/INTERCOM until the IN USE indicator
flashes.
After the IN USE indicator starts flashing, the rest of the procedure
must be completed within 1minute.
3. Press OK on the handset, then wait until a beep sounds.
4. Press OFF on the handset.
Aug 29, 2009 | Panasonic KX-TG6021 Cordless Phone
Panasonic KX-TGA711E
this sounds like you are either out of range of the base unit or your base station isnt plugged into the mains, ensure you have the base station plugged into the power and the phone line from the wall socket is plugged in, the base station controls all the handsets, if it isnt plugged in they wont work, good luck
Aug 05, 2009 | Panasonic KX-TG1033S Cordless Phone
It always losing the line during the cordless calls
* CHECK YOUR AC OUTLET WITH NO LOOSE CONNECTIONS.(remove multi adapters mostly caused problems)
* FULLY RECHARGE THE BATTERIES.
* CLEAN DE BATTERY CONTACTS IN & OUTSIDE THE HANDSET & THE BASE UNIT.
* IS THE BATTERIES DON'T GET CHARGED FULLY IN OVER NIGHT.PLEASE REPLACE THOSE.
* REPLACE WITH ONLY RECOMMENDED RECHARGEABLE BATT"S.
* PLACE THE BASE UNIT AT CENTRALIZED AREA FOR THE MAXIMUM HANDSET RADIATION.
* KEEP THE BASE UNIT AT SAME FLOOR.
Mar 30, 2009 | Panasonic KX-TG1100 Cordless Phone
HANDSET
1. [menu}
BASE UNIT
HANDSET
Jan 31, 2009 | Panasonic KX-TGA101S Cordless Handset
Base Unit does not work
Turns out the A/C adaptor was bad. Replaced it and all is good!!
Dec 17, 2008 | Panasonic KX-TG4500B Phone
Panasonic Phone KX-TG6700B base unit Problem
FROM PAGE 38 of the manual:
If "No link to base. Move closer to base, try again" is displayed, even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit..
HAVE BOTH THE HANDSET AND THE BASE UNIT NEARBY DURING REGISTRATION.
FOLLOW STEPS 1 AND 2 LISTED BELOW. YOU HAVE ABOUT 1 MINUTE TO COMPLETE THEM.
1-Base unit:
Press and hold [HANDSET LOCATOR] until the CHARGE indicator flashes.
2-Handset:
Press and hold [FLASH/CALL WAIT] until "Handset Registering" is displayed.
-When registration is complete, a beep sounds from the handset.
-Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
If... the handset beeps three times and "ERROR!" is displayed, an error occurred. Try again from step 1.
You can stop registration by pressing [OFF] on the handset, and pressing [HANDSET LOCATOR] on the base unit.
Jan 10, 2008 | Lands Phones
Signal indicator flashes constantly
The following worked when I had what appears to be the same problem. Solution :- Remove batteries, remove power connection, wait 30 minutes, re-connect power and replace batteries then press button on base until it beeps. Both handsets started continuous beeping which eventually stopped and everything was returned to normal. Admittdly this sounds almost identical to the process used by 'versailles' above, but at least it confirms that the technical info given by the BT Helpline does work
Nov 28, 2006 | British Telecom Freestyle 2200 Trio...
Panasonic KX-TG1033S Cordless Phone Logo
433 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
