Question about Westinghouse Computers & Internet
Westinghouse Computer Monitor LCM-20v5 Posted by: Daryl Tanner monitor is not wanting to come on right away when i turn on it takes some times 8 time to turn it off and on before it will come on When I turn my computer off for the night. The next morning when I turn it on the i can see the picture for just a second and then it goes black and want come on so I can see what is on my computer. Every time I hit the on button I see the picture on my computer for just a second and off it
  • dtanner449 Jul 14, 2009
    Actually, Ginko, this is the same information I got off the "badcaps.net" forum. I was hoping to get more detailed help if I paid for it.
    For example: If I have to replace the caps, what are the specific capacitor model numbers in my particular model of Westinghouse monitor and what are the equivilent numbers for a better brand of capacitor?
    Daryl
  • Westinghouse Master
  • 19,396 Answers
Common reason for this kind of trouble is a faulty circuit, where a defective component cause electrostatic charges accumulating on capacitors.
When you keep clicking the start, or leave the monitor resting overnight, you drain power, and unit restarts.
Try leaving the monitor unplugged from main overnight and see if this can help.
Also test the monitor on a different computer, as a shorted video cable can cause similar problems.
Parts that can commonly given this kind of problem are the Power supply board and the Inverter board. Sometimes a faulty digital controller board can cause the same problem.
If the power adapter is external , this is easy to test using a multimeter to read DC voltages. Volts must be within halv volt difference from value stated on power adapter label.
An internal PSU is more difficult to test, and for safety reasons the job should be done by a tech.
Test starts with a visual inspection, looking for bulged or leaking capacitors. If there is nothing at a glance next step is testing voltages out and then testing components.
Same operations must be done on the inverter.
Inverter and PSU are high voltage boards.
Regards.
Posted on Jul 14, 2009
  • Ginko
    Ginko Jul 14, 2009
    Hy Daryl if this is the same info that you received in the forum, that means that the forum guys gave you the right info.
    This is what we do at a repair shop in this case.
    To access the board you need to remove the plastic cover at the back, unding few screws.
    You immediately see the (5 I think) big electrolitic caps when you access the PSU board. Value of capacitors is written on the components, I think they should be 1000uF and 220uF, 25V caps. PSU board part number is printed on the board.
    The PSU board has 4 wires connected.
    Resoldering capacitors requires experience and precision, or the repaired part can short out.
    If you have not done similar repairs before you should not attempt DIY. Capacitors must be allowed discharge before testing or replacing.
    The schematics for the monitor are available on service manual from factory, but manual for this model is difficult to find, I could not find it online.
    Repairing a PSU board is a relatively simple job for a technician, for this reason we would not use schematics in this case.
    Hope this helped.
    Regards.
The screen goes on for a second and then turns off. If I then turn the power on and off numerous times it eventually stays on. I put the screen off to 60 minutes. Every time the screen is allowed to turn...
Hello Geoff,
The problem you are having is caused by a power supply board that is failing. Your monitor uses the Delta DAC-12M033 power supply board. We have a repair guide for the Westinghouse LCM-20V5 monitor that uses the same power supply board posted o our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ Check out the web article, it should get you back going again. If you don't want to do the repair yourself we do offer a repair service. We can get deatils on this service here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 26, 2010 | ViewSonic VG2021m LCD Monitor
My Viewsonic VG2021m Monitor recently cut out every 5 or so seconds (the display came up and then went off) again and again and now it seems as though i cant turn it on at all even though the blue on light...
The intermittent image, dark picture or no power are all indications of a failing power supply. If you can solder you should be able to repair your monitor. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ The post is about repairing the Westinghouse LCM-20V5 but they both use the same power supply board, the Delta DAC-12M033 so the information is the same. If you don't want to do the repair yourself we do offer a repair service for this model for $32 plus return shipping. More information on this service can be found here. http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this information helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Sep 19, 2010 | ViewSonic VG2021m LCD Monitor
After pressing the power on button it starts to turn on but then makes a hissing sound and goes into standby mode. It takes several attempts before the screen wont make the hissing sound and finally stays...
You have a monitor with a failing power supply. The Viewsonic VG2021M monitor uses the DAC-12M033 power supply board. After several years of use the capacitors in the power supply start failing and not keeping a charge. The capacitors are on the output side of the power supply and help filter and stabilize the voltages. When they fail the power does not settle when you turn it on so you have to do the on/off/on/off to get it to start. If you can solder then you should be able to repair your monitor. Check out the article on our site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ it is for the Westinghouse LCM-20V5 but they both use the same board so the repair information is the same. If you don't want to do the repair yourself we do offer a repair service for this unit, it runs $32 plus shipping. You can get more information on this service here:
CCL Tech
Corporate Computer
www.ccl-la.com
Jul 01, 2010 | ViewSonic VG2021m LCD Monitor
My lcd monitor model lcm-19w4 i have to plug and unplug the monitor a few times for it to go on help
This is a classic symptom of a failing power supply. There are parts called capacitors in the power board that will start failing and not filtering the power correctly. The regulators on the power board will not work until the power is filtered correctly and when you keep powering it on and off it fill finally start and run until you power it off, then you have to start over again. We have a step by step repair guide posted in an article on our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ This model is a little different from yours but the power supply parts are the same. If you have any additional questions just ask.
Buddy
Corporate Computer
www.ccl-la.com
Mar 29, 2010 | Computers & Internet
Screen goes black after fraction of a second
More likely to be bad capacitors in the power supply, see LCM-20V5 (almost the same chassis as used in LCM-19V5) example: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you further.
Mar 15, 2010 | Westinghouse LCM-19v5 Monitor
Westinghouse Monitor Repair
you can look for other caps that are bad on the board that may have failed later.
hear is a list of replacements for all the caps on the 20v5 i have
http://www.fixya.com/support/t2576306-two_westinghouse_20v5_monitors_also_just
Apr 01, 2009 | Westinghouse LCM-19v5 Monitor
Blue Screen
chak the signal cable of u r monitor
Nov 30, 2008 | Westinghouse Computers & Internet
Monitor SEttings
Probably 1280 x 1024 at 32bit color depth assuming those are the settings you are asking about. If not, please be more specific with a follow up post.
May 09, 2008 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
71 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Iqbal Husain
Iqbal Husain
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
