Question about TTX Computers & Internet
I have a ttx Model BM19 HL. The screen adjustment buttons are malfunctioning. TTZ Monitor 1995B
3 Suggested Answers
SOURCE: model ttx 9194 flat screen monitor
check all capacitors in the inverter section!!
Posted on Jul 29, 2008
  • 732 Answers
SOURCE: My 15" LCD monitor TTX went to sleep mode and never return back
mike_garzan, Your monitor will need some work done on it!! Do you know the "flashlight trick" that every owner of an LCD monitor with "cold cathode-fluorescent-lamps" should know how to do when the BLACK screen of death makes it presence known? Do this test first! It is a very easy test to do. 1. With a KNOWN GOOD pc fully booted to the WIN-desktop showing on a GOOD Monitor have a friend tap the CTRL key on the keyboard every 30 seconds or move the mouse to ensure that the pc won't go into sleep mode. 2. Power off the good monitor and disconnect it from the pc. Now reconnect the TTX9151 to the pc and wall outlet power. 3. Then and only then turn on the monitor and make note of what happens. Did you see or not see the WIN-desktop appear?
4. Now for the flashlight test. Even though the LCD panel appears BLACK, shine a bright flashlight about 1" from the screen's lower left corner and make note if you can see the Windows START icon even though the screen appears to be BLACK. 5. Turn off TTX9151 or yank the plug from wall outlet, and disconnect from pc. TEST IS DONE. Reconnect good monitor to pc to get back online. The test was to evaluate the current status of the "switch-mode-power-supply" and the CCFL inverter circuit DC source. If you could SEE something on the BLACK screen then you know that half of the SMPS is working and sourcing voltage (+5 or +3.3v) to power the vga/lcd interface board! It also means that the SMPS is not in FULL SHUTDOWN mode and only has a problem sourcing voltage(+12v to +18v) to the CCFL inverter circuit which generates 800v to 1200v ac to light-up the CCFL's that are hung across the rear of your LCD panel to produce the WHITE LIGHT needed to see what is on the screen. Now, if you didn't see the WIN-desktop, then the SMPS is probably in complete SHUTDOWN mode trying to save itself from a CATASTROPHIC, NONRECOVERABLE failure! (eg. smoke and fire) Put the TTX9151 in a safe place and get back to me with results of the TEST. lmistyrel and on aim.com or do a comment to your original post above on fixya and I'll give you advice as to what you need to do about getting it repaired or other actions/options you as a consumer/user of LCD displays have open to you. Bye for now. 12fixlouie
Posted on Oct 27, 2009
Hi , My monitor (Philips CRT monitor 109B50) keep showing the phrase 'LIGHTFRAME ON LIGHTFRAME OFF' why is it so? Lastly the blue configuration box with language/zoom/adjust ,eveything ... kept...
It would appear that the control panel buttons are either stuck, or malfunctioning all together. You could take a pen knife and gently lift the buttons and see if the issue stops.
If it does not then your monitor is malfunctioning and will need to be replaced. I would verify your warranty as most monitors carry a 3 year warranty.
Jun 25, 2011 | Gateway FPD2275W LCD Monitor
Oct 27, 2009 | Elo TTX 9154 15 Inch LCD BLACK W/...
LOOKING FOR DRIVERS FOR TTX 9154 USB TOUCH SCREEN MONITOR
I poked around the www.ttx.ca website for you, and found the following blurb:
"A. All models manufactured after 1999 are “plug and play” compliant, therefore “plug and play” drivers supplied with your specific system will work the same as the “TTX.inf” driver found on our website.
If so, here is the link to their "TTX.inf" driver.
http://www.ttx.ca/support/Monitor_Drivers_and_Manuals.asp
Now, a closer look on that page said "CRT Monitor", and that may not be what you have. I did stumble across another of their pages talking about Touchscreen Manuals and drivers. Find that here:
http://www.ttx.ca/support/Touchscreen_Drivers_and_Manuals.asp
This page says to match the last two numbers of the product ID on the back of the unit to their chart of drivers and manuals.
Hope that helps!
May 22, 2009 | Computers & Internet
How to angle the monitor
I have Model X203H & had the same problem. The support CD explained how to adjust the monitor:
Screen position adjustment
To optimize the viewing position, you can adjust the monitor tilt by using
both of your hands to hold the edges of the monitor.
The monitor can be adjusted to 15 degrees up or 5 degrees down.
Apr 16, 2009 | Acer 22" X223w LCD Monitor
Model ttx 9194 flat screen monitor
Jul 29, 2008 | TTX Computers & Internet
Brightness
there is two transistors in brightness section near eht so you can check all small transistors around eht
Jun 24, 2008 | TTX Advantage Series -1770 (White) 17...
Proper Monitor Cable needed and PS Cable!
Hi Maestro_mark,
These cables can be bought at a store where they deal in PC's and any such high end electronics.
No specifications needed. Just tell the dealer the model number of your monitor and ask for the required cables. If he has a manual the he should refer it if he too is doubtful about anything.
That's all.
May 04, 2008 | Elo TTX 9154 15 Inch LCD BLACK W/...
Grey Squares on the monitor
Try reducing the resolution, Since the CRT you are referring to is old monitor, it might not support high resolution.
Feb 08, 2007 | TTX Medallion Series -8570 (White) 15...
Computers & Internet Logo
21 people viewed this question
Top TTX Computers & Internet Experts
David Payne
David Payne
Are you a TTX Computer and Internet Expert? Answer questions, earn points and help others
