Question about Black & Decker Lawn Hog 18-Inch 12 Amp Electric Mulching Mower
Lawnhog sounds like metal tometal won't cut grass
Lawnhog not cutting grass sounds like metal to metal hitting, tried to screw bottom in tighter won't tighten, what do I do
2 Suggested Answers
riceski
  • 1851 Answers
SOURCE: 18" Electric LAWNHOG™ Mulching Mower from Black
Most likely the motor 'brushes' need to be replaced now.
These wear over time and most likely should be replaced by a professional.
Gary @ Fix Ya
Posted on Sep 05, 2010
18" Electric LAWNHOG™ Mulching Mower from Black and Decker idles very low then revs up but fails when cutting grass
Gary @ Fix Ya
Sep 05, 2010 | Black & Decker 19" Electric Lawnhog...
I am using the 19' electric lawnhog from black and decke so I can
Either the mulching attachment is in place or the chute is clogged with grass - happens to me when the bag overfills or the grass is too damp
Jun 19, 2010 | Black & Decker 19" Electric Lawnhog...
Rear bag not collecting grass
Check the blade is on right side up - this is about the only thing that makes a difference - the blade - if a mulch blade may be making the cuts too small to toss them into the bag ?
Hope this helps - please vote me as helpful and leave a comment - if you need more attention I will answer back -asap - also be sure the blade isn't worn out - -
Gary
May 11, 2010 | Black & Decker 19" Electric Lawnhog...
My B&D's blade cut right into the deck today, slicing the deck open and scarring the pants off me: fortunately i was not hurt! Not sure what happened: hit a bumpy patch of ground? No large rocks......
I would check to see if the blade came loose. If not you may have hit something pushing the metal in and causing the blade to hit the deck. Happens to me on my rider when I hit a root of some trees I have in my yard. The blad is up a little higher than the deck and is makes an ungodly racket!!! I usually get a adjustable wrench and bend the metal back in shape.
Jan 25, 2010 | Black & Decker 19" Electric Lawnhog...
Why does my electric mower lose power in high grass? After waiting a few seconds &/or tilting it up, the engine revs back up and can continue to cut. It is a older model. Doesn't have a fan attacted to...
The high grass causes more drag than shorter grass. This means more friction. The tilting lessens the drag, so less friction, the speed increases. It ma need a sharpening but it sounds as though it is running correctly. As you say, it is older so you can't expect new performance. Good luck...Lee
Sep 16, 2009 | Black & Decker 19" Electric Lawnhog...
New black and decker lawn mower, MM875 starts but I cannot get it to cut, what am I doing wrong?
did you sharpened the blade. checked the blade if not installed reverse.B&D clean the blade. info in the blade say's facing the grass
Aug 17, 2008 | Black & Decker 19" Electric Lawnhog...
B & D mulcher mower stop while mowing
electric & battery operation mower are not suppose to be use when grass are too long & wet, it draws lot of power that appear to runs slow.when you see try to restart i think the brake is trying to kick in.
Jun 15, 2008 | Black & Decker 19" Electric Lawnhog...
Mower won't start
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Jun 11, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker Lawn Hog 18-Inch 12 Amp Electric Mulching Mower Logo
81 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
