Question about RTO Atwood DSI-RV Water Heater-6 Gallon
I have a 6 gal Atwood hot water heater. I can
I have a 6 gal Atwood gas hot water heater. I can light the pilot and it will stay lite and then it lights the main burner. The main burner burns for a minute or so and turns off and the pilot goes out. Not sure whether the pilot is being turned off or blown out by the burner shutting down abruptly. I need help troubleshooting the problem. Kenny
  • kennybraxton Jul 14, 2009
    I haven't made any changes. Wasn't sure where to start. Would this cause both the burner and pilot light to go out?
  • 297 Answers
Kenny did you change the thermo coupler?
Posted on Jul 14, 2009
  • Bill Johnson Jul 21, 2009
    yes it may be possable for this to happen.
I have an RV atwood hot water hearter, model #G6A-8E, comes on for about 5 to 6 seconds, starts it for again till it dont come on again, can you help?
Posted on Feb 07, 2011
I have a Jayco pop up with an Atwood water heater, serial # 37C14U-5. My problem is two-fold. The water heater pilot doesn't stay lit after initial run, and propane is leaking out of the vent on the...
Leaking propane is red flag #1 and fire hazard.
Immediately update your insurance and then turn off gas.
If pilot is not staying lit, then gas leak can be cause of pilot problem since pressure on the line is reduced.
Other causes include bad gas control valve, air in the gas line, bad thermocouple, burner parts need cleaning, or all the above.
After fixing leak, replace thermocouple, clean combustion chamber and burner parts, and bleed gas line to remove air.
More resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Jun 28, 2011 | RTO Atwood Water Heater - 6 Gal LP
Burner lites but goes out after 2 or 3 min.
the white rodgers gas control needs to be replaced;
the way it works is: the thermocouple opens the pilot gas circuit and, holds it open
when it heats up by creating a magnetic field in the gas control then: when you turn
the knob on the gas control to "on" a valve inside the gas valve opens the main gas circuit and, electricity supplied by your RV keeps it open.
the main gas coil inside the gas valve is defective and, can not hold the main gas circuit to the burner open anymore.
Jul 24, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have an Atwood 6gal hot water heater with a 37c14u-5 controller. The pilot light will not stay lit. I have replaced the thermal coupler twice and the pilot tube with orfice once. It's still not...
Try removing the thermocouple where it attaches to gas control, and spray a little WD-40 in the hole, then spin a rolled up small piece of steel wool in the hole as well, then blow it out with compressed air if you can. Then reconnect thermocouple. Make sure thermocouple tip is getting good flame under it, and if that doesn't cure it, then it's time to replace gas control.
Jun 23, 2010 | RTO Atwood Water Heater - 6 Gal LP
Installed new thermocoupler heater still will not stay lite
Make sure the pilot light is hitting the thermocoupler, even when burner kicks in. Sometimes a dirty pilot tube will cause a weak pilot and it wont continuely hit the thermocoupler. I use air to clean mine. Hope this helps.
May 26, 2010 | RTO Atwood Water Heater - 6 Gal LP
The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
10 gal. atwood water heater in 1994 Prowler-Park model.After the water is heated, the pilot light goes out and has to be re-lit. this happens every time. Lately, put on pilot, re-light, turn to on and will...
the gas valve is what you need to replace, the thermocoupling only tells the gas valve that it is ready for a flame and lets a little gas out, but the gas valve is not letting the gas out,, there is a screen in the gas valve it may be clogged not letting the gas thru, but at the age of your unit I would even consider changing the unit insted of investinf more money into this one
Jun 14, 2009 | RTO Atwood Water Heater - 6 Gal LP
After a few minutes of burner heating the water, gas shuts off.
A couple of things to check:
If possible, remove the pilot gas assembly and clean the gas jet and thermocouple - they can get carboned up and stop working properly. Make sure the pilot flame and deflector is aimed properly and making the thermocouple glow red hot. If the problem persists, you may want to replace the thermocouple and also check the propane regulator.
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
2,680 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
