Cant load canoscan scanner using vista with 64 arch
  • 19,396 Answers
Ensure that you have the right version of the software for Vista 64.
You can try downloading Vista 64 drivers selecting your model on Download Library - Canon
Before installing the new driver do a system restore to a date before you started the failed installation. This will get rid of files left by last setup.
To run the install file , instead of double clicking do the following:
Click the right mouse button on the installer file, and chose "Run as Administrator" from the drop down menu.
Also remember to disable security software and allow all requests from file installation.
Regards.
Posted on Jul 14, 2009
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Jan 01, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
CanoScan N1220U Scanner Windows 7 64-bit Driver
You may use Hamrick VueScan Pro, it installs a driver that makes 1220 to work. Or, if the version of Windows 7 you use support XP Mode, install it.
It's still a good scanner, and mine is working in 7 x64 using XP Mode!
Sep 17, 2009 | Canon CanoScan N1220U Flatbed Scanner
I have an HP laptop OS Vista i tried to
Hi There,
there are no 64 bits drivers available on the cannon website(x64) and you cannot install it using the 32 bit vista driver
Sep 03, 2009 | Canon CanoScan 5000F Flatbed Scanner
I am trying to install canoscan fb630u scanner with vista 64 bit. the scanner does not support vista
Try Vuescan from Hamrick. I have used it to successfully scan from FB636U on a XP 64 installation and Vista with no drivers needed. A free trial is available. www.hamrick.com/
Aug 14, 2009 | Canon CanoScan FB630U Flatbed Scanner
Canon lide scanner vista 64 drivers
This is the link to the drivers and CanoScan Toolbox.
Click on the
Drivers & Downloads on this page then choose Vista(64) as your OS
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=235&modelid=6623#DownloadDetailAct
Apr 11, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Driver for Canoscan N640P for windows vista home premium 64 bits
You may be out of luck; here is a version for XP/NT that you could try to force-feed to see if it will work;
# Model: CanoScan N340P
# Size: 3.73 Mb
# Version: 3.8.2
# Date added: 09-Jan-2007, 10:36
# Manufacturer: Canon
# Device type: Scanner
# Operation system: Windows 98/ME/2000/XP
# MD5: 582d83ae6df3ea4bd0a3465a2750c020
http://www.nodevice.com/driver/CanoScan_N340P/get36948.html
You can download the driver from this IP address (72.56.181.99) within 24 hours. After 24 hours you will have to use the driver request form once again. Thank you for understanding.
Dec 15, 2008 | Canon CanoScan N340P Flatbed Scanner
Canoscan does not work on vista 64-bit
I'm not sure if this will work on the lide 20. I have an lide 35, and there are no 64 bit drivers for it. I downloaded and installed the drivers for the lide 60, told the computer to manually find the lide 60 drivers for my scanner, and installed the canoscan toolbox for vista 64 bit. Works like a champ.
Nov 07, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Windows vista 64 bit driver
Hi mtrump1,
Thanks for your posting in FixYa.
The driver are available on the Canon Website, use this link to get it:
http://software.canon-europe.com/products/0000441.asp
or
For Vista 64 Bit you can try:
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/CANON/Canon-CanoScan-D1230U-611c.shtml
But i think both should be compatible to run in any 32 or 64 bit environment.
Regards
ELLIN
Sep 20, 2008 | Canon CanoScan D1230U Flatbed Scanner
CanoScan 8600F
Download the Scanner Driver here for Vista
http://driverscollection.com/?H=CanoScan%208600F&By=Canon
Click Windows Vista and then Download the right choice one for you.
If your don't know if your Vista is either 32-bit or or 64-bit download the second one which will work for either of the 2.
Good luck
Jun 18, 2008 | Canon CanoScan 8600F Flatbed Scanner
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
