Question about Iwill VX133 (MAVX133) Motherboard
IWill VX133 ver 1.1 motherboard
Trying to figure out how to make the front panel connections to the motherboard. Power switch/leds/etc. The labeling on the board is hard to figure out.
  • ks6p Jul 24, 2009
    Thanks for nothing....you couldn't give me the link!?
    I can't find it.
  • ks6p Jul 24, 2009
    I can't find it.
  • 33 Answers
Check the manual or download the manual at the net!! just type on the brand name!!
Posted on Jul 16, 2009
Msi ms 7297 ver.2.1 front panel help
With the motherboard in the case and the back of the case away from you the front panel pins are on the front left of the motherboard. They will have simple labels;
PWR power
RST reset
HLED hard dive LED
PLED power LED
You can get it wrong without breaking it so just keep trying until the right buttons and lights work.
Jan 06, 2013 | Intel Motherboard
I am looking for the mother board connection diagram so i can connect the towers front panal ie power switch /reset ect
Connect the front panel leads to the motherboard connector marked "JFP1" using the following pins as indicated by the markings on the motherboard and the front panel leads: HDD LED on Pins 1 and 3; power LED on Pins 2 and 4; reset switch on Pins 5 and 7; and the power switch on Pins 6 and 8.
Good luck.
Mar 03, 2011 | MSI 865GM2-LS Motherboard
How do i wire-up the: ( eg. power l.e.d., HD led, reset led ect. to the board
The various wires from the case front panel should be labeled to indicate power LED, HD LED, etc.
The motherboard front panel jumper pins should be grouped together and the pins should be labeled to indicate PWR, HD. RST etc.
You can go to the motherboard manufacture's WEB site to download a diagram of your model motherboard and it will show all the locations of the connecting pins.
Jan 30, 2011 | Chaintech MP4M266A Motherboard
Hello I need driver sound card iwill vx133u thanks
You can download the device drivers from this WEB site :-
http://www.motherboard.cz/mb/iwill/VX133.htm
Jan 28, 2011 | Iwill VX133 (MAVX133) Motherboard
Need pin configuration for power switch, HDD LED, power LED, front USB, etc.
Hi, just like you I purchased two of these motherboards and I have very good news for you. Above the blue PRIMARY IDE ATA connector is a set of 18 pins labeled PB/LED P5 and pin 1 is labeled.
17 15 13 11 9 7 5 3 1
18 16 14 12 10 8 6 4 2
Pins 1 and 3 = HD LED
Pins 2 and 4 = POWER LED
Pins 6 and 8 = POWER SWITCH
pin 14 has no
pin
Feb 02, 2010 | Compaq (283983-001) Motherboard
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Emachines t3830 I need the schematic for MB I umployed the wire for the push bottom without looking at the way they were plug. Now I do not know the correct aligning of the push bottom wires.
If you look at the motherboard there is usually a diagram labeled "FRONT PANEL HDR" that will tell you which pins are for: HDD LED, PWR LED, RESET, PWR ON. etc.
The chart / diagram may be a few inches away from front panel header.
the following example is from my emachine T2893 that I had opened because it won't power up.
the motherboard at the header connector labels pin #2 and with that you can figure out the other
pin numbers
example of diagram on motherboard (Confirm the pin numbers on your motherboard)
J9G1 PINS
| HD LED | 1 - 3 |
| PWR LED | 2 - 4 |
| RESET | 5 - 7 |
| PWR ON | 6 - 8 |
Hope this helps you figure which pins to hook you switch up to.
Jan 18, 2009 | E-Machines eMachines T3830 PC Desktop
FITTING MOTHERBOARD
If you have not removed the old motherboard from the case, then you can identify the various front panel connectors as you disconnect them and label them. Some front panel connectors have labels printed on the connectors which makes it easy for you to identify its purpose. If you have already removed the old motherboard then you will need to trace each of the leads to the front panel to see what they are connected to (eg. the LEDs and switches etc).
You will also need to identify on the new motherboard the various connectors for each function, eg power LED, hard drive LED, reset switch, power on switch, internal speaker etc. If you are lucky It may be printed on the motherboard, if not you will need to refer to the manual.
NOTE the LEDs are polarity sensitive, if the LED does not light, then swap the connector around the other way.
Nov 16, 2008 | Packard Bell Computers & Internet
Front panel connections
PWR > PWR (aka PWR SW), HDD LED > HDD LED, RST > RST (aka RST SW and Reset)
May 31, 2008 | Iwill XP333-R Motherboard
Iwill vx133 manual
WHAT DO U NEE DTO KNOW JUMPERS OR cpu info i looked on line dont see any manels on yorus so old but maby i can help u ?
Jan 26, 2008 | Iwill VX133 (MAVX133) Motherboard
Iwill VX133 (MAVX133) Motherboard Logo
424 people viewed this question
Top Iwill Computers & Internet Experts
Steven Burn
Steven Burn
David
David
Willem.
Willem.
Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
