Question about Acer Aspire One PC Notebook
Not getting electricity to power computer or
Not getting electricity to power Acer One or charge battery. All connections checked. Computer is only a few months old.
    Problem Solver:
  • 10 Answers
Sounds like a fried battery. Unfortunately, they are not covered by warranty. If you buy a new one, get a lithium - or it'll just fry again.
Posted on Jul 14, 2009
Power light flashing amber
Follow the steps given below. (Please be careful when handling computer electrical components like batteries and AC Adapters)
  • Remove the battery and hold down the power button for few seconds (to drain all remaining power)
  • Power up the computer without the battery with the A/C adapter plugged in.
  • Wait for few seconds and plug the battery back in
After a few tries the computer should start charging normally. The amber battery stops blinking and turn green when fully charged.
Feb 13, 2015 | Acer Aspire One Kav10 Netbook
How long for battery recharging D610 ?
when the computer is turned off, the AC adapter charges a completely discharged battery to 80 percent in about 1 hour and to 100 percent in approximately 2 hours. Charge time is longer with the computer turned on. You can leave the battery in the computer for as long as you like. The battery's internal circuitry prevents the battery from overcharging. So About 2 to 3 hrs
When you connect the computer to an electrical outlet or install a battery while the computer is connected to an electrical outlet, the computer checks the battery charge and temperature. If necessary, the AC adapter then charges the battery and maintains the battery charge.
If the battery is hot from being used in your computer or being in a hot environment, the battery may not charge when you connect the computer to an electrical outlet.
Jun 06, 2014 | Dell Latitude D610 Notebook
My acer wont start up
Acer laptops allow you to take your work and entertainment on the go.
You can work on a presentation during a long flight or watch a DVD in the middle of a park.
Acer laptops can do this because they are powered by batteries, allowing the laptop to run without having to be plugged into a power source.
Normally, the battery can be recharged by plugging the laptop back into a power socket.
But certain problems can keep the battery from charging.
Electrical Connection
For laptops to charge, they need to be connected to a power source.
Although it may look like you have the cable plugged in correctly on the Acer, make sure that the cord is firmly plugged into the power socket.
There should be a light on the Acer keyboard as well as a power symbol on the taskbar for your operating system that tells you whether the laptop is running off electrical or battery power.
If it is plugged in, make sure that this icon shows that it is on electrical power.
Also check the socket where the Acer is plugged in and make sure that it isn't turned off at the main circuit breaker.
Battery
Turn the Acer over and make sure that the battery is properly placed in the battery compartment. Most laptops will have locks that keep the battery securely in place.
These locks can sometimes come loose.
Use a piece of strong tape as a temporary measure to keep a loose battery in place.
Clean the terminals on the battery to ensure that there is a good connection.
Remove the battery from the battery compartment.
Apply rubbing alcohol to a lint-free cloth. Rub this cloth over the shiny metal terminals on the battery.
Over time, batteries lose their ability to be recharged.
If neither of the aforementioned steps works, you may just have a bad battery.
Check with Acer or other vendors to find a replacement for your model.
BIOS Update
The BIOS (Basic Input Output System) controls a number of basic functions for a computer, such as assigning the hard drives and other system functions.
The BIOS also controls the battery charging function.
Certain Acer models have a bad BIOS that operates the computer normally but doesn't charge the battery.
To solve this problem, you need to perform an operation called Flashing the BIOS where you download a new version of the BIOS and upload it to your Acer.
Check on the Acer support site to see whether your computer model could possibly be affected by this.
Adapter
The power adapter, the part that plugs into the Acer from the power socket, can go bad.
Check for a power light on the adapter.
If the light is not lit, you probably have a bad adapter.
Replacement adapters can be purchased from Acer or other online vendors.
http://support.acer.com/us/en/default.aspx
http://www.solarum.com/2010/01/03/acer-aspire-battery-not-charging/
Mar 16, 2014 | Acer Extensa 5635Z Drivers Recovery...
Won't start
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty.
Although it would be very rare for the sata lead to be faulty.
Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
also
There are several possible reasons the computer may not be powering on.
The connections may be loose or damaged.
The AC adapter or power cord may no longer be functioning.
The battery may be defective or no longer working; or the battery may need to be reset or recalibrated.
If these methods do not solve the issue with your Acer Aspire, contact Acer support for further troubleshooting options.
Inspect the AC adapter to be certain it is fully connected to the computer.
If the connection is loose, contact Acer for repair service (see Below).
Online Product Supporthttp://acer.custhelp.com/app/answers/detail/a_id/4/kw/battery
Check the AC adapter connection to the power cord. If the cord will not stay connected , there may be a defect in the power cord.
Contact Acer for service options or replacement parts.
If the adapter is connected to a power strip, make sure the strip is powered on and is fully connected to the wall socket.
Connect the adapter to a different electrical outlet if necessary.
After verifying all connections, attempt to power the computer on.
If the computer does not turn on, try power reset.
Reset
Disconnect the battery, and detach the AC adapter from the notebook.
Push the power button, and hold it for 30 seconds.
Reattach the battery.
Reconnect the AC adapter to the computer and a functioning electrical outlet.
Press the power button. If the computer does not power on, attempt to power on without the battery.
Power on Without the Battery
Shut down the computer.
Remove the battery from its compartment.
Connect the AC adapter and power cord.
Verify that the power cord is connected to a functioning socket.
Press the power button. If this method is successful, the battery may need replacing.
Recalibrating the Battery
Attach the notebook to the AC adapter, and allow the battery to fully charge.
Detach the AC adapter, and restart the laptop.
Fully discharge the battery.
Reattach the AC adapter to the laptop.
Fully charge the battery.
Jul 18, 2013 | Acer Aspire One PC Notebook
Low battery warning
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Fix a Broken Laptop Charger
If your laptop charger seems broken, it's most likely because the battery will not charge.
You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly.
When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop.
It should fit firmly in the DC jack without wiggling.
If it is loose, use electrical tape to hold it in place so the charger can receive power.
This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury.
A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible.
Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open.
The battery should pop out; give it a tug if it doesn't.
Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors.
Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery.
Slide the latch to secure it and plug in the power cord to test it.
See if the laptop powers on with the charger only and battery removed.
If it does, the battery is the likely culprit and should be replaced.
If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number.
Call the laptop manufacturer for a replacement charger or search for the part number on eBay.
If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems.
Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
But certain problems can keep the battery from charging.Electrical Connection
Battery
BIOS Update The BIOS (Basic Input Output System) controls a number of basic functions for a computer, such as assigning the hard drives and other system functions.
To solve this problem, you need to perform an operation called "Flashing the BIOS" where you download a new version of the BIOS and upload it to your Acer.
Adapter
Jul 14, 2013 | Acer Computers & Internet
I have teshiba L650 I PUT NEW BATTERY IN IT NWE BATTERY CHARGER CORD AND COMPUTER COMES ON BUT FOR SOME REASON BATTERY WILL NOT CHARGE UP EVEN PLUG IN TO ELECTRIC SOCKET
Try removing the battery and use your charger only in powering up your computer to check if your charger still works. If it doesn't power your computer then you need to replace the charger.
David
Mar 20, 2013 | Acer Aspire 3000 Notebook
I have an Acer aspire 4530 laptop. When I power it on it just keeps clicking like it wants to power up but never does
the clicking noise could be your operating system trying to connect to your computer and cant find it because of a faulty connection
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
hope this helps
Jul 15, 2011 | Acer Computers & Internet
Just bought a second hand acer travelmate 4200. I have never owned a lap top. How do I change from using battery power to outlet power
On the left side, towards the rear is a DC jack. Plug the power cord in there. It should automatically start operating on AC power, and charge the battery.
Feb 24, 2010 | Acer TravelMate 4200 Notebook
Is there any way to charge an ACER computer battery other than through the computer. The computer has a burned out recharging jack. Can you recharge it through a USB port.
No, not through a USB port.
Can you find a similar ACER computer for "cheap" on eBay?
It would not need to run -- it just has to accept the identical battery,
and connect to an AC adapter, and to charge the battery,
even when the laptop is powered-off.
Nov 25, 2009 | Acer Aspire 3680 Laptop
How do I charge the battery on a new Acer Aspire One Series?Netbook
Just plug the computer into the wall with the supplied power cord (while the battery is in the computer). This will charge your battery.
Sep 22, 2009 | Acer Aspire One A150-1006 Notebook
Acer Aspire One  PC Notebook Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
