Question about Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor
Blue Line I have a blue line appearing on the monitor. I have fixed this once before but forgot how. I have updated the graphics card and screen drivers to no avail.Ideas please??
  • 3 Answers
CAble connecting the monitor or the LCD screen itself is damaged . tighten the port behind the PC , make sure it is well conected , wile the dis play is on try softly twisting the cable a bit if the blue line flickers then cable is faulty . otherwise LCD screen needs to be checked
Posted on Nov 20, 2007
  • 3 Answers
There might be problem with the input cable of monitor .... please verify the cable ... try replacing it and then check... this might solve the problem.....
Posted on Nov 18, 2007
My computer has blue lines all over the screen. If I open the computer normally, it doesn't continue from the windows charging bar, it ends up in a black screen doing nothing. If I start with Safe...
Run the software coming with the computer or download from your computer supplier, and fix it.
Try to use the Menu from monitor, and make factory default.
God bless you
Oct 14, 2013 | Packard Bell iMedia Computers & Internet
Blue vertical lines
Hi, I am sorry you are having issues with your graphics card.
Yes the oven trick does work but it is only temporary and you will have to do that process over and over until the card just all out quits responding. Once a GPU begins to display multicolored or blue lines across the monitor its time to put it out to pasture so to speak.
Aug 31, 2013 | MSI NX8800GTS-T2D512E Geforce 8800 GTS...
The left side of my laptop screen wet all white with red green yellow blue lines running veretical lines running through it. looks like someone spilled paint on it
Vertical lines are usually caused by 2 things, either your graphics card is going bad or your screen is going bad. How you check if it is your graphics card is by plugging it into an external monitor (if you have one).
If the lines still appear on the external monitor then you know its the graphics card going bad, which isn't probably worth fixing these days if you take into account how must laptop pricing has dropped.
I hope this helps.
Best of luck!!
Mar 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have vertical lines on screen I have changed the whole screen assembley but lines are still thers , exactly in same place
Hey There,
The reason this happens is because the graphics card is either loose burned out or jsut needs to be cleaned... to clean it use a pencil rubber in the gold tips that connect it, blow on the card to remove any dust build ups and reconnect the graphics card when done (make sure its clipped in properly).... different brands of computers will do different things such as the different coloured lines and screens flashing red. My dell latitude 630 had green and blue verticle lines. Just follow what i said and it should be fine
Hope this will help you in Resolving the issue with the vertical Lines on the screen.
Feb 14, 2010 | HP Compaq nx6325 Notebook
A thick blue horizontal line appeared in my LCD screen and won't go away. I can still take pictures and they print out fine, but how can I get rid of the blue line?
This is probably a problem with your LCD monitor or the connections to it. Does the blue line show in all situations such as record, playback, and menu mode?
Test your monitor by plugging into your camera the TV cord that came with your camera. Connect to a TV and use it as a monitor when your camera is on. be sure to switch to the TV to channel three or video to get a picture. Check the different screen modes: record, play, and menu. If the blue line does not appear on the TV then there is damage to your monitor or its connections. My guess is you won't see the blue line on your TV since you get good prints. If you are on warranty, get it fixed. Otherwise, you have a choice between paying for a repair or living with it. Good luck.
Nov 27, 2009 | Olympus Cameras
return to the retailer and exchange it. if it's a green line from top to bottom, the retailer should be able to exchange it. some retailers have a minimum of "stuck pixels" before they will take it back (ie. 10 pixels), but if it's a line, that should be more than the min.
Oct 22, 2009 | Samsung 204T 20" LCD Monitor
Line on the screen
hi there if you can try another monitor on your pc, if it works ok its your screen, if it dosnt it could be your graphics card or onboard graphics good luck
Aug 05, 2009 | HP Pavilion F1703 17" LCD Monitor
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
Blue Vertical Line on the display.
hii varathri.
plz check ur RAM memory.
remove it .clean it . and insert it proprly.
also reinstall the display driver from drivers cd u might have recieved with the pc.
also if u r using graphic card .reseat it and also reinstall the driver fro the same.
Nov 03, 2007 | Computers & Internet
Dell UltraSharp 2405FPW 24" Flat Panel LCD Monitor Logo
231 people viewed this question
Alun Cox
