Question about Yamaha Water Sport
2005 Yamaha FX jet ski not accelerating
I have a 2005 Yamaha FX jet ski, it has been in the water a couple of weeks - kept on a jet ski dry dock. It was running well all weekend then when I pushed it into the water it idled fine and pushed water through the back but when I tried to accelrate the RPM's would increase but there was no power and it vibrated substantially. I could barely get enough power to get it back on the dry dock. Topping out at 4 mph. When I revved it on the dry dock it did not vibrate. Any thoughts?
  • perrotta Jul 14, 2009
    Can this problem be fixed by someone with little experience or is it a pretty straightforward repair?
  • perrotta Jul 20, 2009
    There was a rope sucked into the impeller that was binding up. thanks for your help
  • 583 Answers
First of all check out the motor starter --------- The starter is held on with 2 bolts. To get to it you take off the exhaust manifold, or pull the engine out of the hull. the other problem is the short circuit in the power section.the fuse is blown.due to this its not showing power.this requires servicing.plus some fuse and engine power wires repolacement.as the enfine is proper as you said the RPM rises so its not a costly issue and this is a good thing.but a time consuming and requires the time. thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on Jul 14, 2009
    Top Expert:
  • Yamaha Master
  • 76,070 Answers
There is a problem with the jet, it either is plugged or the shaft bearings are worn out.
  • yadayada
    yadayada Jul 14, 2009
    this is not a straight forward repair, I fixed mine and for that I needed a bearing press and a welding torch to free the seized bearing's for the jet drive impeller shaft, have been a tech for 40 years and this was an 8 with 10 being the hardest job.
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
Jet ski troubleshooting
what make of ski ?? does it get water in the engine all the time ? more info please ?
Feb 15, 2014 | WSM 1998-1999 Yamaha Gp 800 Cc Jet Ski...
Won't start
Fuses in the electrical box?
Jul 18, 2013 | Yamaha 2006 WaveRunner FX Base
2010 Yamaha FX Crusier jet ski
sparks ? compressions 100psi or more ? water in fuel ? injecters clean ?
Jul 14, 2013 | Boating
Rear seat removal, fx yamaha jet ski, latch will not release the seat
As bad as this sounds its the only way. Grab yourself a 2x4 and a nice size prybar.
Lay 2x4 across the back grab handle as to not damage it then put prybar directly under seat latch and pop it up.
Oct 29, 2011 | Yamaha 12V Air Pump
I have a Yamaha FX Cruiser HO (2010). The jet ski died in the water on me last week. I determined it to be a fuse. Replaced the fuse with the extra one and it burned out again. Any suggestions?
i have a 08 yamaha fx sho it keeps on freezing up in the water and dying of, i was almost 10 miles into the ocean and had to be towed by one of my fellow riders. whats causing this problem?
Jul 16, 2011 | Yamaha 12V Air Pump
Water Sport Logo
239 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
