Question about Samsung HP-R4252 42 in. Plasma HDTV
Sound works. Why is screen black?
Screen had black horz. Lines then went all black. Sound still works.
5 Suggested Answers
SOURCE:
freelance-au
  • 131 Answers
SOURCE: Screen went black, no picture
Hi
This is more than likely your (upper Y buffer board) that has failed, turn your Tv off then remove the back and stand, once the back is off then look to your far left hand side you will see 1 x big board which is your Y SUSTAIN and further left of that you will see 2 x boards ( long rectangular shaped ) connected to that and to the screen via ribbon cables.
You need to replace the one at the top left.
They have a number on the board that you should right down then Google or Ebay it for a replacement.
99% of the time this will cure the problem.
If this helps please comment and vote.
Thanks
Posted on Apr 07, 2010
FaceTheFacts
  • 245 Answers
SOURCE: my 32" lcd screen went black but the sound is ok.
Problems with these TVs not turning on are usually capacitor related. Take the back off then look on the power supply where the power chord goes look at the fuse next to the plug. See if it's physically dark if so, the fuse is most likely blown and you should just look up the board number on E-bay for a new power-supply for a more costly, but easier fix than a repair shop. While the back is off, look for capacitors that are puffed and see if they need to be replaced. There are usually 2 caps by a heat sink that look bulged.
http://cgi.ebay.com/10pcs-Electrolytic-Caps-KIT-16V-50V-0-1uF-1000uF-/290505738749?pt=LH_DefaultDomain_210&hash=item43a37dc9fd#ht_1734wt_905
and
http://www.youtube.com/watch?v=Mm51C_RDIZE vid one http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related vid two.
http://cgi.ebay.com/Samsung-LN-T3242H-Backlight-Inverter-Board-BN81-01786A-/140535907159?pt=LH_DefaultDomain_0&hash=item20b897c357#ht_500wt_1156
This is the inverter board if this is the case. Try swapping one at a time because usually only one is bad.
Posted on Jun 20, 2011
diodeic
  • 1622 Answers
SOURCE: Samsung LCD black tv screen
hello,
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken....
Posted on Sep 12, 2011
gopakumarg43
  • 76046 Answers
SOURCE: after 10 to 20 mins left half of screen goes to white vert lines
Sounds like power supply regulator board fault. Check all the electrolytic capacitors for any leaked or bulged one. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Posted on Jul 01, 2014
What causes my LG 55LS4600 55" tv to have sound but no picture.
It is a common problem for the LG model. The problem
is defective LED back lights ASSY. You have to open the display panel & replace the burned LED strips.
Jan 13, 2018 | LG Televison & Video
How to diagnose my led tv issues
You most likely had a capacitor let go, they make a pop when the go out, inspect the PCB for a burned mark.
Oct 12, 2016 | Toshiba Televison & Video
MAY HAVE BEEN HIT BY LIGHTNING. BLACK SCREEN AND 2 COLORED LINES
Replace the deflection board. Sounds like the vertical deflection was knocked out thats why you still have sound. You can get replacement deflection boards from www.tvrepairworld.com
Aug 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Black screen with 3 colored lines going across
Ur tv convergence ICS are dead.U have tools to do soldering,and know how to do soldering?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 28, 2010 | Hitachi 53UDX10B 53" Rear Projection...
LG RU-42PX10C Plasma TV picture had colored lines & went black...
This will be your Y SUSTAIN board on the left hand side when you take the back off.
Plenty available on ebay, Very easy fix
Mar 05, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
Hi, Two sets of lines have appeared on the screen
are these lines vetical or horz if they are vertical your panel has failed and will need to be replaced big bucks if they are horz , then it could just be the T-con board and you will need a tech to confirm this I have seen this problem cause by a poorly seated connection
Dec 07, 2009 | Televison & Video
The screen went black and now it has alot of lines across it
Sounds like a bad video card.A video inverter could cause distorted graphics but usually it turns out to be the graphics card.
Jul 30, 2009 | Computers & Internet
Black screen
ccd malfunction!
YOU HAVE THE INFAMOUS CCD RECALL .
The screen is black and sometimes horz lines appear scrambled ?
This would be it.
The cost to fix by SONY is 175 - 200. They stopped fixing for free until Oct 2007.
I pulled off the fix by myself. Cost = 49$
Whats needed to Purchase: CD489 ( CCD main board ), ICX101 ( CCD IC )
Required: Surface mount soldering skills, Patience, and disassembly skills.
With this you can fix it like I did !
Apr 07, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Main display went black on enV
Yeah same with mine... the front screen went black.... it started to get lines up and down... then all of a sudden just the front screen turned off! :-(
Jun 02, 2008 | LG enV VX9900 Cellular Phone
Samsung HP-R4252 42 in. Plasma HDTV Logo
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
