Question about Imperial IFS40 Deep Fryer
Pilot wont start - Imperial IFS40 Deep Fryer
    Problem Solver:
  • 3 Answers
Make sure gas is on. pilot oriface is clean
Posted on Jul 18, 2009
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
It will start but wont idle
If its been sitting you will need to pull the carbs and clean or replace the pilot jets, and clean everything else too. The pilot jets control idle fueling and are easily clogged.
Jul 22, 2014 | 1981 Honda GL 1100 Innerstate Gold Wing
Raypak problem, Pilot is lit, can jump TH to TH to lite, goes out when jumper is removed.
check how many millivolts the pilot is generating. if pilot stay lit and burners wont fire u have a problem with one of the safties, lose wire connection, tstat control
May 28, 2013 | Raypak Pool & Spa
Pilot wont lite. miller spectrum 701
check the cables in the plasma torch.
If the problem continues, theres no enough power to start it.
Jan 04, 2010 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
No hot water
pilot may be blocked therm/coupling may need replaced
Oct 09, 2009 | Bosch Water Heaters
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Hard start, wont idle 2000 kaw 300 r
if your pilot jet is pluged it will not idle. the pilot jet controls fuel from o-1/8 throttle setting only
Mar 16, 2009 | 2002 kawasaki KLX 300 R
Whirlpool gas dryer motor wont turn over
If the drum is not turning, then the belt may have broken and could be (because of the noise I think your describing, partially wrapped around the motor pulley.
Modern gas dryers do not have standing pilot lights. They are electronic ignition.
Chances are, you solve the belt problem, you'll solve the (I guess your having) heat problem.
Please respond with more detail of the problems you are having, and advise if the belt is broken.
Jan 18, 2009 | Whirlpool GGQ8831L Gas Dryer
Imperial IFS40 Deep Fryer Logo
27 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Joseph Hoffmann
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
