Question about Innovage 1604007 Corded Phone
My mom was given a phone Model No 16169360001,
My mom was given a phone:
US:SUNTE 10BST3839
USOC JACK:RJ11C
REN:1.0(B)
Item Description: Phone-LCD-Touch Panel-MS
Made in China, China Patent # 200830049047.2
U.S. Patent Pending
She has misplaced the box/instruction manual, and we are having trouble with all the settings. Is there a way we can find a manual online?
2 Suggested Answers
SOURCE: operation manual
I have a manual i'll send You a copy
charlymusic242yahoo.com
Posted on Jan 22, 2009
Kx-dt321 I have 5 phones in the system. Only 2 phones ring on in comming calls. how can make all the phones ring?
Telephone lines have a REN value ( ringer equivalence number ) this figure is usually around 4, meaning you should not connect equipment totalling more than this value or your ringers may not operate when receiving a call.
On the underside of your telephone or answer machine or fax etc. you will see the ren value on a label it will typically be REN 1 so you can plug in 4 of these units.
1 REN = 4000 ohms ( ringer impedance )
I suspect you have overloaded the line, if you need all of the equipment connected, you can buy ringer repeaters which have a separate power supply and therefor do not load the line.
Jan 10, 2018 | Lands Phones
Panasonic KX-T7668 handsets. How to make different extensions ring / not ring on an in-coming call.
The first thing to check is the total "Ring Equivalent Number" or "REN". This is a maximum number that your line will support. For example if the line REN maximum is 4, then it will support 4 phones with a REN of 1 (4x1=4). If, however, you have 3 phones with a REN of 1.5 each then it won't work (3x1.5=4.5). It may work on 2 of them and not the 3rd one, but equally it may work on one or none at all.
The REN is usually on a label on the phone or in the manual, but the line REN is set by your supplier and you will need to contact them for that number.
Jan 24, 2016 | Lands Phones
Receivers of calls from our phones all complain that the sound level is very low.
Virgin nearly always say that the problem is your end and not theirs.
The first thing to check is that the REN number is not exceeded. REN stands for "Ring Equivalent Number" and is made up of the total number of phones connected to your line. Usually each phone and extension has an REN of 1, so 3 phones would total REN 3.....no problem. However, some phones may be REN 1.5 or REN 2 and this could add your REN up to 6 (if all 3 phones were REN2) and this could exceed the maximum. To check this, simply disconnect all extensions so only the base or master phone is in operation and try a call to see if still quiet. If still a low volume then Virgin may be right and it is not their problem, but at least that rules out a possible REN problem.
To confirm or disprove you will need to do the following:
1. Pop round to a neighbour who has no problem with their phone and try your phone in their socket (doesn't have to be a Virgin line). Call someone and see if they can hear you properly. If the sound level is low as before, then it is your phone that has the problem but if fine then your phone has no issues.
2. Borrow the neighbours phone and plug it into your socket and make a call. If low volume then it is a possible Virgin problem and at the very least they should send someone round to physically check your line. Make sure that you have done all the checks as above.
Jul 25, 2015 | Cell Phones
I have lost the manuel to my phone and i have given the phones to my mom which having hard time understand how it works.. please please send my mother the booklet..her address is Peggy Lee PO Box 358...
Since you declined to specify the model of your mom's Uniden 5.8GHz system, no one can send her the appropriate manual. Please select the model from the list beginning here to download a copy.
Jul 14, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
No matter what phone I use, my magic jack wont ring!
Seems like alot of discussion around on getting phones to ring.
I think the interesting scenario here is when people want to be able to connect the MJ to house wiring to have phones connected remotely work normally (call/ring).
First, it is important to have phones which have REN's (Ringer Equivalence Number) be as small as possible (usually the REN can be found on the phone or in its technical specifications).
I started with MJ connected to my home wiring (ie connect MJ to a wall phone socket hoping to have a phone elsewhere in the house work normally). I was using a TRU8885 with 2handsets (is AC powered) - the REN on this phone is a paltry .08 . I could call normally, but not get a ring.
I had an old computer with USB ver 1.0, so I first got a cheap USB 2.0 card which I installed which did not fix the problem - it is reasonable to assume these cards have sufficient power.
I tested the phone directly attached to the MJ (4ft phone cable) and it rang. I tested likewise with a 20ft cable and it worked. I reconnected to my house network and it did not work with the phone attached to phone jack at my desk. icon_sad.gif
I traced the lines in my basement (I was already disconnected from outside landline connection) contemplating eliminating unnecessary wiring and lo and behold I discovered in a corner of my basement that an old bell-ringer phone was connected to my house network! When I disconnected this phone (and the obvious voltage load associated with it), my phone rang perfectly.
Here's my conclusion:
1. use a phone with lowest possible REN (less than 1 certainly, closer to .1 desireable).
2. don't worry about powered hubs if already connected to computer's USB since it is likely sufficiently powered.
3. don't get into power boosting phone systems (see #1)
4. eliminate high-REN other devices from phone network
5. run a test of of phone direct connected to MJ - if this doesn't work, likely your phone is not AC powered or is too high a REN.
Jul 06, 2009 | Uniden Lands Phones
No ring on incoming calls
I found this in statement in a review of Magicjack on Amazon, hope it helps.
The one problem I did encounter was at the beginning when I found that one of my phones wouldn't ring when someone called me. By googling the problem, I found out that this problem is due to the ringer equivalency number (REN) of the phone you are using (google "phone REN" to find out what it is). Most phones have their REN listed at the bottom of the base unit. From my experience, I believe Magicjack will only work for phones that have REN of up to 1.0B (add up all phones in your system to get your total REN. Mine had a corded base with 0.6B REN with 2 more cordless handsets. I figured that made my phone system total to 1.8B REN). Magicjack did ring on a phone that had 0.98B REN. To fix the problem, I bought a multi-handset GE DECT 6.0 (model 28223 Series) which basically has REN 0.0B. Magicjack had no problems ringing with this phone. My phone system was over 3 years old anyway so I didn't mind replacing it.
Jun 30, 2009 | Uniden Lands Phones
I have lost the instruction manual - is there an online version?
Hi
here is a downloadable version of the instruction manual...
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=CORDLESS_PHONES_CA&sct=DECT_PHONES_SU&grp=PHONES_GR&session=20090426060330_93.97.209.201&ctn=TD6626/BB051P&mid=Link_UserManuals&hlt=Link_UserManuals
Regarding using the base on its own, I cannot see why not if you have all the working buttons to control functions you need on it.
If you are going to use other phones with this please take into account REN values on your line. Most lines will support upto and including 4 REN value. Nearly all phones will have a REN value of 1. So ideally only have a maximum of 4 phones (may get away with 5 if you are near an exchange?)
Hope that helps?
Apr 26, 2009 | Philips Zenia Voice Cordless Phone
No ring
First, it is important to have phones which have REN's be as small as possible. I started with MJ connected to my home wiring (ie connect MJ to a wall phone socket hoping to have a phone elsewhere in the house work normally). I was using a TRU8885 with 2handsets (is AC powered) - the REN on this phone is a paltry .08 . I could call normally, but not get a ring.
I tested the phone directly attached to the MJ (4ft phone cable) and it worked. I tested likewise with a 20ft cable and it worked. I reconnected to my house network and it did not work with the phone attached to phone jack at my desk. icon_sad.gif
Mar 18, 2009 | General Electric 25982 5.8 GHz 1-Line...
SX-50 Attendant Console Failure
The console uses 3 pair USOC wiring from the console to the jack on the control card. Look at the Mitel provided cable from the console. It should be 6 pin and you can make sure the console is functional by moving it to the cabinet and plugging it in. If it works, you need to cable 432516 straight through on a 6-wire modular plug and terminate it in the same order on a jack where the console is. They must be paired for the long run.
I have a huge non-indexed pdf of an SX-50 if you need it. The console explanation is figure 5-14 of the -200 practice if you have it.
Carl
Mar 15, 2009 | Lands Phones
Operation manual
Jan 06, 2009 | Innovage 1604007 Corded Phone
Innovage 1604007 Corded Phone Logo
400 people viewed this question
Top Innovage Lands Phones Experts
wiccan8thhouse
wiccan8thhouse
Computer Repairing
Computer Repairing
k24674
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
