Question about Kenmore Elite 45986 Front Load Washer
How can I get a manual?
How can I get a manual for the kenmore elite HE4t front loader. wash machine? How do you clean the filter?
  • 5,911 Answers
If you need to clean the drain pump reservoir, or inspect it for debris, the following link explains how:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
There is a tech data sheet that comes with your washer that lists troubleshooting advice and error code explanations. The sheet will be located behind the lower kick panel directly under the door. If not affixed to the panel, it will be located along one of the interior cabinet walls. Its recommended that you leave it inside the appliance when not in use, to ensure it does not get lost.
If you are looking for an Owner's Manual (operating instructions), managemyhome.com has a huge library of downloadable manuals for FREE. All you have to do is register. Once registered, log in and click on the "Owner's Manuals" link under the "Home Manager" drop down menu.
NOTE: If cleaning the pump does not correct your problem, it is recommended that you replace the drain pump.
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Jul 14, 2009
I want a manual for My Kenmore HE4T Front Load Washer
This site has lots of manuals. http://www.manualslib.com/products/Kenmore-He4t-110-4508-3024385.html#.VPmnI5cyiQE.mailto
Feb 14, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Kenmore Elite HE4T standing water
I also have standing water after a wash cycle, but not immediately after. Given the history of very expensive repairs to this Kenmore HE4T washing machine, I suggest you do what I do, if the machine is still cleaning the clothes. Whatever cycle you use, try to be around when the machine finishes, so that you can turn off the water supply and remove the damp clothes to the dryer or clothes line. Turn on the water supply only when you want to use the machine. This works for me because I don't do many loads per week and my laundry area is right next to my kitchen. If it was in my basement, I'd have replaced it already with a top loading machine with mechanical not electronic controls.
Aug 21, 2012 | Kenmore HE4t 3.8 Cu. Ft. King Size...
My clothes smell musty after they have been washed. I was told to replace the rubber gasket in our Kenmore front loader he4T by the sears repairman for quite an expense. How can I replace this gasket...
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Dec 30, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
New Kenmore Elite Front Loader will not get past 'Sud' cycle,
Hello wheeljc; I had the same problem when I purchased my Kenmore Elite in 2006. I have a HE4t front load. It's possible that you're using to much detergent, if you're using HE liquid it only requires a small amount and does a very good job.
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite error code
possible electronics failure. my HE4t has completly gone dead at the control panel after displaying error codes. A class action law suite is in the works on the HE3t HE4t machines.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader washer HE3 kenmore Elite
ok " there is a filter on that line ,it has to be cleaned
to locate filter, follow hose back to filter
filter will come apart for cleaning
Jan 11, 2008 | Kenmore 44832 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
563 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
