Question about Pitney Bowes 9920 Plain Paper Fax
Printing error Code#2AB4 Already restarted machine and same problem is occuring.
  • Nike Merritt May 11, 2010
    where do you see this error code? This code is nowhere in my error code list. Is it on the screen?
3806 error code on konica minolta c6500
Restart the machine or call your technical services representative, Thanks
Feb 05, 2013 | Konica Minolta Office Equipment & Supplies
I got PE error code in my whirlpool white magic F65
The PF error code indicates a power failure on many different machines. This might occur while machine is working due to an external disturbance like a storm or power outage in the area. If the PF error code is displayed, turn off the power to the washer, unplug it for 10 seconds, and restart the wash cycle.
Aug 13, 2012 | Washing Machines
HP color laserjet error code 49, we turn off the printer when it asks us to but still has an error on it. No clue what is wrong
From the HP Website
ERROR 49.XXXX
A critical firmware error has occurred that caused the processor on the formatter to abort the operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some instances, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or specific software programs. Remove all EIO devices and firmware DIMM if installed. Restart printer. If error is gone replace each EIO device until error appears. Replace device which triggers error. May also be formatter. Firmware updates are available for some machines at http://hp.com and clicking on the drivers and software tab. Also try printing from a different application. If that works go back to the first application and try printing a different file to determine if the problem is file related. You may need to reseat the memory DIMM's or replace the firmware DIMM or formatter board.
Jul 15, 2011 | Office Equipment & Supplies
49, 4c02 error in hp 4250
This is what the result for that error code is:-
ERROR 49.XXXX
Feb 08, 2011 | HP LaserJet 4250dtn Printer
How to fix Error code C6020
I have The Km C2520 with the same C6020 code. Is the solution the same?
Jan 26, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
MP800R: Error code:201 - Printer can print but not Scan!MP800R: I can use the printer for printing al right, but when I try to scann I get a message that I should close the printer, and read the manual...
Error code:201 occurs due to USB conflict or software not running properly....
Solution#1: Take out the scanner from USB port... shut down the computer.... then restart the computer and plugin your USB plug in anyother USB port(not the ealier one).. Then check if that works.
Solution#2: Click on Start > Click on Run > Type Services.msc press ok.... on the services window check for "Still Image Service" right click on it and select properties .. then click on stop then start(if it is already stoped then click on start).... also make sure the Startup Type: Automatic....
Jul 17, 2009 | Canon Office Equipment & Supplies
Please rate!!
Jul 17, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Paper has jammed showing error code 0000064 and inform to restart
canon3000 err code 64 restrt machine 10 to20 copy after code please help me
Dec 16, 2008 | Canon MF8180C Color Laser MFC Printer
Only printing the first half of the page
Try,
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select PRINT DIRECTLY TO THE PRINTER.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Aug 24, 2008 | Canon PIXMA MX310 All-In-One Printer
Pitney Bowes 9920 Plain Paper Fax Logo
170 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Victorman
Victorman
richie46
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
