Cannot start the car with remote or valet button. programmed several times but no luck. car was stored for four years. I can start the car from the starter solenoid. please advise thank you
    President:
  • 1,129 Answers
Try reseting the controller pull out the battery for a minute and reinstall and reprogram, check the connections for the antenna and the electrical component assemblies there may be a corroded connector.
Posted on Jul 14, 2009
2011 ford escape limited the remote start stopped workng
Remote starter in valet mode Symptoms: Lock and Unlock buttons work as normal, but pressing Start does not produce any response from the vehicle.
Causes: Someone accidentally pressed the combination of buttons to put the car into valet mode, usually when the remote is in a purse or pocket. Also, many remote car starters will revert to valet mode when the vehicle is disconnected for service.
Hood Pin Has Broken or Failed Symptoms: Pressing Start results in several flashes of the parking lights but no start. If equipped, Lock and Unlock still function.
Cause: In most cases, the under-hood pin switch is broken or corroded.
Remote Control Loses Programming Symptoms: Pressing any button on the remote results in no response from vehicle.
Cause: It is rare, but does happen - in most cases, this is caused by a dead battery in the vehicle or the battery having been disconnected when being serviced.
Remote starters usually have some type of non-volatile memory to retain things like programming features and remote control codes. Like any "computer" device, sometimes they lose memory. When this happens, simply call the store that installed it for you. In some cases, they may be able to tell you how to reprogram it over the phone. Other times, you will have to return to the store for a technician to program it. In any case, this is rare with higher-end remote starters.
Remote is in Second-car Mode Symptoms: Pressing any button on the remote results in no response from vehicle.
Causes: A combination of buttons were accidentally pressed, which put the remote in second-car mode.
Again, this is very rare, but happens from time to time. Many remote car starter remote controls have the ability to start two vehicles. If the remote is accidentally placed into second-car mode, it will not start or operate vehicle #1.
Simply read your owner's manual or call your installer for directions on how to revert the remote back to car #1.
Dec 08, 2016 | 2011 Ford Escape
Where did they put the valet/program buttom on my 2004 Rendezvous?
This is somebody else's so;ution, but it might give you an idea on where to start. I always thought the valet switch was just a key that you gave to the valet. But inn this case out of my legue, my old dodge pickup doesn't hAVE AND MOST LIKELY NEVER WILL HAVE A VALET SWITCH. So check this so;ution oout and see if it gets you going in the right direction.
There should be a key specifically for a valet.
1) Open one of your vehicle's doors and turn the ignition, using the car key, to the "Run" position. Check to see that the dome light comes on. Make sure that you have the dome light set to the position where it powers the light when the door is opened, as there are usually three settings: one for "On," one for "Off" and one for when a door is opened.
2) Press the valet remote push-button to access the channel that you want to program: once for "Arm/disarm," twice for "Trunk Release" and three times for "Remote Start." The valet push-button is usually located under the driver's side panel, and it must be pressed within 15 seconds of opening the door. The push-button may also be installed underneath the kick panel.
3) Press the valet push button once again and wait to hear a chirping or a honking sound. If you do not hear either of these sounds, your vehicle might have a jumper installed that has turned the valet programming feature off. Refer to your vehicle's instructional manual to learn how to set the valet programming feature to the "On" position. Keep holding the valet button pressed as you continue onto the next step.
4) Push the button on the remote that you wish to assign to a particular valet channel. Press the button on the hand-held valet remote that you wish to assign to a particular valet channel. If you wish to program multiple remotes, repeat this step for each of them. If you program four or more remotes, the old programming will be erased.
5) Let go of the valet push-button and exit your vehicle. Your handheld remote is now ready to use.
Tips & Warnings- Some valet remote channels require different programming individually, so refer to the owner's manual or to the link provided in the "Resources" section of this article, for specific instructions.
- Valet remote programming methods may vary, depending on the vehicle's make and model.
  • By avatar11.jpgBraunson Y309 days ago
    Braunson Y Level 2
    • 467 Solutions
    • 282 Score
Dec 19, 2011 | Viper Security and Remote Start System...
Crimestopper SP501 car alarm/remote starter will not respond. The 2 way one doesn't work, the sidekick does.
You need to program your crimestopper sp-501 key fobs, you need to program both the 2-way and the 1-way key fobs, during the same key fob program session. First find your valet button/switch, when you have found it, turn your ignition on and press the valet button four times, if you have a toggle type switch for a valet switch, toggle it up and down four times, when its in remote key fob program mode, it will honk your horn 4-times followed by 4-parking light flashes. Once your have done this press the lock button on the 2-way key fob, horn will honk and the 2-way will sing a little song to confirm programed, then press the lock button on the 1-way key fob the horn honk will be your confirm programed. turn ignition off this will exit you from program mode. then shut all doors and test key fobs for operation functions....hope this helps you out
Dec 03, 2011 | 2006 Hyundai Sonata
Where is the valet switch on a 2004 chevy malibu LS?
Tips & Warnings - Some valet remote channels require different programming individually, so refer to the owner's manual or to the link provided in the "Resources" section of this article, for specific instructions.
Feb 17, 2011 | Keyless Entry Remote Fob Clicker for 2004 ...
Need to know how or get instruction to program new auto page xt-100 oled remote starter.
REMOTE TRANSMITTER PROGRAMMING Enter: 1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in ON position. Within 15 seconds. 2. Push the Valet switch 2 times and hold in on the 2 nd push, when a long chirp is heard then release the valet switch. You are now in the Transmitter programming mode. Program: 1. Press the Lock button on transmitter 1 until the siren responds on Car with a confirming chirp; the first transmitter is now programmed to Car. Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. 3 long chirps will confirm exit. Note: If more than 4 transmitters programmed, the system will only keep the last four. The Valet switch is a little Red Push Button that should be mounted under the lower left side of you dash or in the lower left kick panel near the E-brake pedal.
http://www.autopageusa.com/resources/2%20Push%20transmitter%20PROGRAMMING13.pdf
This sis atndard programming for the 900,915,1000,and 100 units.
Feb 12, 2011 | RS1000 OLED 2Way OLED Remote Start w 6...
Program remote
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
2. Push the Valet switch 2 times and hold in on the 2nd
Program:
Jul 09, 2010 | RS855LCD AutoPage MultiChannel 2 Way...
How to re program my pager? (autopage 1000
Enter:
Program:
Jun 03, 2010 | RS1000 OLED 2Way OLED Remote Start w 6...
Program replacement remote
Enter:
Program:
May 21, 2010 | RS1000 OLED 2Way OLED Remote Start w 6...
Programming the APS02BT2 remote
TO PROGRAM ADDITIONAL TRANSMITTERS:
1. Enter the vehicle, and turn the ignition key to the "on" position.
2. Press and release the valet push-button switch three times.
3. The dash LED will flash once, and the siren will "chirp" once, indicating the system is ready to accept programming for channel 1 or the arm/disarm and panic functions.
4. You can assign any of the three transmitter button functions listed below to channel 1.
a. Pressing button #1 on the keychain transmitter.
b. Pressing button #2 on the keychain transmitter.
c. Pressing both buttons simultaneously on the keychain transmitter.
5. Press and hold the selected choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 1 was successful.
6. Press and release the valet push-button switch one time.
7. The dash mounted LED will flash 2 times, and the siren will "chirp" indicating that the system is ready to accept programming for the unlock/panic channel.(If you desire one button to control lock & unlock, move on to step 9)
8. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of unlock channel was successful.
9. Press and release the valet push-button switch one time.
10. The dash mounted LED will flash 3 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel2, or the pulsed ground output for remote trunk release, remote car starter, etc.
11. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 2 was successful.
12. Press and release the valet push-button switch one time.
13. The dash mounted LED will flash 4 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel 3, or the additional pulsed ground output if available on your model. NOTE: If the program switch is operated again, the circuit will recycle through the program mode. In other words, press 1 time to access the lock function, 2 times to access the unlock function, 3 times to access the start function. When programming is complete, simply turn off the ignition switch to exit the program mode.
ERASING TRANSMITTERS IF THEY HAVE BEEN LOST OR STOLEN: NOTE: Before you begin to erase the lost or stolen transmitter(s), have all transmitters available that you wish to remain programmed. These will be used during the program process to identify transmitters that will continue to be used.
Enter the transmitter program mode:
1. Turn the ignition switch to the “ON” position.
2. Within 10 seconds, press and release the valet/program switch three times. (Siren emits 1 short chirp indicating channel 1 has been entered)
3. Within 10 Seconds, press and hold the ARM or ARM/DISARM but-ton of the first transmitter you wish to remain stored into the control unit until a single chirp is heard from the siren.(Repeat this for each transmitter you wish to remain stored in the control unit).The receiver stores up to four transmitters. To be certain all transmitter slots in the receiver are occupied with transmitters you wish to continue to use, and all others are erased, you will have to fill all four receiver slots. If in step 3 you identified one transmitter, you will have to fill the additional 3 slots. If in step 3 you identified two transmitters, you will have to fill the additional two slots, etc...
4. Press and hold any unused button or combination of buttons until a long chirp is heard from the siren. Release and press the button or button combination again and again until all remaining slots are full. NOTE: The button or combination of buttons entered will also control the armor arm/disarm function until additional transmitters are added. All unwanted transmitters are now deleted.
Feb 28, 2009 | Car APS02BT2 Transmitter for...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
